Old December 27th, 2017, 09:04   #1
going4broke_24v
Default 02J Transmission Fluid Type???
Looking to perform a transmission service on my 2003 VW Jetta GLS with the 02J transmission. I've been looking around, but I am having no luck finding any decent reviews. I live in upstate NY, right now it's 6 degrees out, so looking for the best fluid for better shifting during colder temperatures. I've only put a few thousands miles on the car since bought, but for piece of mind, I would like to change the fluid for my safe keeping. What do you guys use in your 02J 5-Speed transmissions during the winter months? Also, any recommendations for fluid during the warmer months of summer? Thanks!
going4broke_24v is offline   Reply With Quote
Old December 27th, 2017, 09:06   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I run the Motul brand 75w90 synthetic GL4 lube (OE spec). Seems to work fine for all the ones here. I started my car up this morning at 7 F, sitting outside, and drove off right away, and have never had any issues shifting.
All year round, hot, cold, towing, triple digit speeds , never a problem.
oilhammer
www.cardocautomotive.com
Old December 27th, 2017, 10:02   #3
going4broke_24v
Thanks for the information. Have you ever ran Redline MTL Gear Oil? Its a GL-4 70W80? Think that is too much to run all season?
Old December 27th, 2017, 10:08   #4
otm646
Fuel Economy: 54/48.5/43
What's wrong with the VW G070?
I've used G060 in the frozen MI winters and 100 degree summers for years without complaint. The G070 is nearly identical in viscosity to the old G060
76 300d 475k
97 750IL V12 working SLS 187k!
98 Jetta AHU 330k! PD150 intake 2.5 SS straight pipe- Sold to Papa Validius
05 WRX 5 speed wagon 220k + flow mods ~270 HP
81 Lancia Beta Zagato
otm646 is offline   Reply With Quote
Old December 27th, 2017, 11:53   #5
OlyTDI
TDI(s): '04 Golf
Interested in knowing what made you switch from using VW G070.
Cost? Performance?
Thanks!
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old December 28th, 2017, 05:26   #6
oilhammer
oilhammer's Avatar
Never switched from it, it was never used in that transmission.
oilhammer
Old December 28th, 2017, 06:25   #7
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
G070 is too thin for my liking. Looks like water when you pour it in.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old December 28th, 2017, 07:53   #8
Powder Hound
Powder Hound's Avatar
Up here in NY, Redline MTL is a great choice. If I was back in Phoenix or living in the deep South, then the heavier 90 weight product might be a better choice, but MTL has worked for me in Phoenix as well.
Redline has some other products called 'shockproof' which might work OK in a dedicated differential gearbox, but would be a disaster in a transaxle. (Just putting this note out there just in case anyone thinks it would be a good product for a clutch causing rattles.) If the transaxle worked OK before a clutch change and rattles afterward, and you want to fix the rattles, fix the clutch and/or the flywheel, not the transaxle lube.
The only snag most people find is availablility, but the internet resolves that issue.
Cheers,
PH
Old January 4th, 2018, 08:20   #9
jettawreck
jettawreck's Avatar
GM/Penzoil SyncoMesh.
2004 Cadillac SLS (wife's)
02j type of metal?? Chazztastic94 VW MKIV-A4 TDIs (VE and PD) 2 November 1st, 2016 04:16
manual transmission fluid type??? williambill VW MKIII-A3/B4 TDIs 24 February 22nd, 2014 15:23
Type of p/s fluid? Brockflock TDI 101 18 April 14th, 2010 08:51
GL-5 fluid in a 02J trans. turbocharged798 Fuels & Lubricants 5 March 3rd, 2010 17:49
Manual transmission fluid and engine coolant-type TDITN TDI 101 9 October 30th, 2003 09:09
Page generated in 0.16193 seconds with 10 queries
[Output: 95.54 Kb. compressed to 82.08 Kb. by saving 13.46 Kb. (14.08%)]
