Old December 26th, 2017, 19:32   #1
corsabala
Default Big nozzles 0.360mm 1.9 TDI VE AGR - Video
Hi everyone,
I have a 1.9 TDI 90hp AGR engine with GT2260VK + 11mm pump head rotor + 0.360mm nozzles installed. I would like know what's the best configuration bar to this nozzles to the first and second stage.
Currently they are calibrated to 240 bar, but i'm not sure if this is the best configuration to big nozzles.
Last month has been hard to start the engine with the low temperatures. When starts, the engine dropped a lot of white smoke.
Please see the video: https://youtu.be/VJgjS_lpRvg
I thought the problem was the fuel pump, so I replace her last week by another one but the problem remains.
Can the problem be the configuration bar of the injector nozzles?
PS: The problem just remains in cold start. When the temperature is high the engine starts perfectly.
corsabala is offline   Reply With Quote
Old December 26th, 2017, 21:17   #2
[486]
TDI(s): 02 golf ALH
this is normal amount of smoke for cold pistons
how many degrees is it where you're parked? mine smoked worse than that with stock nozzles when below -5C, much much worse below that
ETA: my dss .360s on a 12mm de110 pump do that up to about 10c
[486] is online now   Reply With Quote
Old December 26th, 2017, 23:12   #3
Yucca
Have you ever tested those 0.360 Nozzles in dyno? I think they make less power than smaller 0.320 size nozzles.
Yucca is offline   Reply With Quote
Old December 27th, 2017, 08:09   #4
corsabala
The smoke smells like diesel and burns in the eyes. I'm not sure if is normal, because I feel a loss of power since it began to happen.
Every morning are around +5.
Before this nozzles I had a 0.275mm DDS Ultime II and this didn't never happen.
I forgot to mention, I bought these nozzles 0.360mm on ebay from Germany.
What more worries me isn't the smoke, but the difficult to start engine every morning.
I never test it in dyno. But my chip tuner tell me excatly the same. He told me he couldn't reduce smoke with 0.360mm nozzles.
If I can't fix this problems with a different configuration bar nozzles, I'm thinking about buying a 0.320mm nozzles to test.
Old December 27th, 2017, 08:09   #5
corsabala
Two weeks ago I use a endoscopic camera to check cylinders inside, and this is what I haqve found:
https://ibb.co/itJ8ew
https://ibb.co/kehC6b
https://ibb.co/ix1pmb
I think the nozzles not spray properly.
If anyone has suggestions I am grateful.
Thank you
Old December 27th, 2017, 15:55   #6
-zamppa-
I bought these cheap ebay-nozzles too few months ago. At first I got one nozzle replaced by the seller because it had very poor atomization, and the opening pressure was impossible to adjust no matter what I did.
After 2500km my AVG started to idle with 3 cylinders. It worked decently still over 1200rpm. Dont know if nozzles need to be cleaned or what. I swapped oem injectors back and now car is working properly again.
I never got problems with cold starts (under 0C) or had so much smoke than you have.
My advice is that save your time and money and use them for better quality nozzles, before you break your pistons. Ive tried to find those better nozzles too. Seems to be hard to find... hints and offers are welcome.
-zamppa- is offline   Reply With Quote
Old December 27th, 2017, 18:12   #7
corsabala
What's the size and How many bar you have configure your nozzles?
Same problem here.. When I started the engine it works with 3 cylinders.. Just works fine when still over 1300/1500 rpm or when I drive after 2/3km.
I'm going to test another 0.360mm ebay nozzles from a friend.. I'm losing my mind with this problem..
You can find a brand nozzles from DSS-R (old DSS Ultime), h-flox from darkside or Firad. But the price is little different.
Old December 27th, 2017, 21:33   #8
Yucca
Try 0.320 from Gibonta.
Old December 28th, 2017, 04:21   #9
corsabala
Gibonta are the new h-flox?
I researched it and took me to the darkside site.
Does anyone have feedback from the DSS R nozzles?
Old December 29th, 2017, 05:53   #10
-zamppa-
Size is same as yours. I'd remember that I set those for 280/360bars.
I wish there was h-flox's available somewhere, but as mentioned, darkside offers gibonta nowadays. Im not really after gibonta yet, as it is "new" manufacturer and there isn't much data and long term experiences with these nozzles in high power engines(well over 300hp).
Does Firad have any big nozzles? Ive understood that they have only small ones to offer and they are not suitable for my Golf.
Dss-r would be one option. My first big nozzles(at the time) were Ultime 2's and they are still running good after maybe 8 years. They have been with 10mm pump and 300hp for 6 years now.
Old December 29th, 2017, 07:48   #11
sam-
Yes firad do up to 0.360, here a picture i took from a polish seller with reference & size.
sam- is offline   Reply With Quote
Old December 29th, 2017, 12:31   #12
corsabala
In my opinion the H-flox was the best nozzles manufactured to VE engines, give very good results. If you google it is still on sale in some online stores, but the price is too high.
Firad have a good nozzles but the feedback that I have received from some friends is that is good just to PD engines.
My first big nozzles were too a DSS Ultime 2 0.275mm. I sold them last month.
Old December 29th, 2017, 16:32   #13
-zamppa-
I dont find those firad nozzles at all. Maybe i cant find the right word for search.
I have also seen hflox's sold in one place, but when I asked for them i got told that they are out of stock. Dont know why they were still for sale.... If someone who has 4pcs of 0.341 hflox's for sale are reading this, feel free to make an offer via pm.
Well, I've managed to keep myself busy with my other projects so I dont have any hurry with my Golf. Its still driveable with Ultime 2's. Just bought a V6 and it has to be re-repaired soon. Maybe there is coming some "funfun" for that thing too.
Old December 29th, 2017, 17:43   #14
sam-
The seller is called cobreti from poland, user jabcok20 is using 0.330 from firad
you can find them also on santerchips.pt, directly by firad if you have a company registered number or can contact their official reseller on their site, it looked cheaper than by tuning site but still not much VP build with those nozzles
Old December 29th, 2017, 21:49   #15
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Do you know what your IQ is set at? I had a friend that had his IQ less than 1 and the motor would barely run then as I adjusted it up to 2-3 it smoothed right out.
2K jetta gl tdi 5spd 401k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
How to video: On car VE injection pump seal replacement video runonbeer TDI 101 352 January 20th, 2019 17:25
New TDI owner here with BIG problems help? Whistle with video and A/C problem. Scottyegg TDI 101 18 July 2nd, 2013 02:20
Video of TDI with only chip and nozzles Bojje TDI Power Enhancements 3 August 8th, 2007 13:24
Changing nozzles on an AGR code engine jeallen TDI Power Enhancements 3 May 15th, 2007 13:32
Page generated in 0.16527 seconds with 10 queries
[Output: 129.84 Kb. compressed to 108.97 Kb. by saving 20.87 Kb. (16.07%)]
