Old December 26th, 2017, 19:07   #1
BigTurboAlh
Fuel Economy: 525 mi to tank
Default Alh Edc15 wastegate control
Iíve been tuning my car for a while running a old Holset turbo for a while and have been using a mbc. Instead of leaving the car on full boost all the time. I would like to just flash a daily tune with less boost using a 1.8t n75. Anyone have any knowledge on doing this? I know with the ahu people convert to vnt all the time. Thanks
2000 ranger alh swap
Holset powered, fueled, sb drag clutch
BigTurboAlh is offline   Reply With Quote
Old December 26th, 2017, 20:01   #2
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
Considering installing my he221 on my ALH and learn how to tune it this spring.
How are you doing the tuning now? Just turn off the ECUs control of the turbos boost?
I would assume you coukd just start from the AGR engine code maps and adjust accordingly but I'm interested to see if anyone gives you more detailed info.
2003 Jetta TDI - Boring daily driver for now...
1996 Passat TDI - "Red Death" RETIRED but still owned. Had a Malone stg 1 tune, 11mm pump, R520, GT15/17 hybrid and more
1997 Passat TDI wagon - Im not really sure why i bought this... anyone want a running donor car??? body is rough.
ketchupshirt88 is offline   Reply With Quote
Old December 26th, 2017, 20:15   #3
BigTurboAlh
I still use boost requested and everything so it don’t get in limp mode. But some times it still gets it like when your going up mountains and air changes and boost changes. I currently use a agr file and had a n75 wired in but could never get it to work. I still don’t know if a agr file will work. I’m wondering if anyone else has tried it. I got my car tuned in almost perfect but it still don’t seem right with out the ebc.
Old December 26th, 2017, 21:10   #4
[486]
TDI(s): 02 golf ALH
I don't see the need.
more air the engine sees, the happier it is
cut fueling in smoke maps if you want a gentler remap
you could easily do something with a mechanical pneumatic switch in the wastegate line to have a "dual boost" type setup. run your spring type boost control and then bypass it with the switch, so it runs the lower pressure. But running less boost just seems like you're shooting yourself in the foot.
ETA: on mine I just disabled the trouble codes for overboost and underboost.
I'm sure it still tries to do vane stuff, but it doesn't monitor the results.
[486] is offline   Reply With Quote
Old December 26th, 2017, 22:05   #5
BigTurboAlh
I run 40psi on my hot tune and no traction in third. But It’d be nice to just flash to that tune when I want to have fun and have my street tune.
Old December 27th, 2017, 10:12   #6
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
AGR software should work fine for wastegate control - but will need the correct plumbing for the wastegate etc. Did you just carry on using the N75 etc from the alh when you tried to convert?
028906283j - is the Control valve for an AGR - which is a pressure driven control valve not a vacuum one as per the ALH.
m1ketdi is offline   Reply With Quote
Old December 27th, 2017, 13:19   #7
BigTurboAlh
I tried using a 1.8t n75 valve. I’ll order one from a agr and try it. Thanks
Old December 27th, 2017, 19:23   #8
ketchupshirt88
Originally Posted by BigTurboAlh View Post
I tried using a 1.8t n75 valve. Iíll order one from a agr and try it. Thanks
Please dont think im patronizing you or talking down to you, just trying to get clarification...
Did you have it plumbed in like an ALH's N75 or like an AHU's? Hooking the 1.8T N75 to the vacuum lines like an ALH instead of to boost pressure will apply vacuum to the wastegate actuator, which will not do anything to open it...
Old December 27th, 2017, 21:56   #9
BigTurboAlh
Same way as 1.8t using manifold pressure then n75 then turbo
How to: CAN bus from the EDC15 ALH ECM to an Arduino (and beyond) mcneil TDI Conversions 18 June 26th, 2016 10:45
OBDII readiness values for a EDC15/ALH? mcneil TDI Conversions 3 May 3rd, 2016 04:25
EDC15 (ALH) in MK5/B6? Dorkage TDI Conversions 8 September 21st, 2014 00:13
Need advice with my maps - EDC15 ALH 700900 VW MKIV-A4 TDIs (VE and PD) 1 May 8th, 2014 08:41
HELP!! Need '01 ALH EDC15 engine computer! BuzzKen Ontario 13 December 7th, 2011 07:39
Page generated in 0.14331 seconds with 10 queries
[Output: 90.20 Kb. compressed to 77.11 Kb. by saving 13.09 Kb. (14.51%)]
