Old December 26th, 2017, 02:30   #1
FRITS91
Default dq500 dsg7 4x4 with edc15 afn/teves mk20
good afternoon.
I collect the information for the installation of the gearbox Dq500(dsg7) 4x4 in the body of mk1 1.9tdi afn edc15.
abs mk20. haldex gene1 work on the factory scheme through the can.
is interested in how the dq500 works. Will it understand the signals from the EDC15 on the can bus and what other problems can there be in installing the dq500 paired with the edc15v and the teves mk20 abs
VW Passat B3 TDI Syncro
http://www.drive2.ru/r/volkswagen/1132946/
FRITS91 is offline   Reply With Quote
Old December 26th, 2017, 07:09   #2
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
check with macradiators.com on this site. He has done a dq500 conversion and may be able to help.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old December 26th, 2017, 10:19   #3
FRITS91
Thank you. in private messages asked.
according to the SSP vw scheme, abs is required with esp. I have a simple abs, without ESP
Old December 26th, 2017, 15:00   #4
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
I doubt an EDC15 will be good enough for dq500... It doesn't have a torque based strutcture to allow torque requests from the gearbox etc.
m1ketdi is offline   Reply With Quote
Old December 28th, 2017, 11:41   #5
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
Olso can is older ,so you will get no comunication between engine ecu and dq ecu.
Best you could try with edc16 ecu ,that will do
Lucian189 is offline   Reply With Quote
Old December 28th, 2017, 11:50   #6
m1ketdi
TDI(s): Leon BKD
EDC16 with VP pump? - Don't know anyone doing that?
Old December 28th, 2017, 12:10   #7
Lucian189
TDI(s): 3.0 TDI CR
Install pd...not vp then with edc16 you could get that dq working.
Old December 28th, 2017, 13:04   #8
m1ketdi
TDI(s): Leon BKD
How does that help the original poster who wants to run dsg on a vp?
Old December 29th, 2017, 06:55   #9
sam-
Probably a dsg standalone controller like Boba use :
https://www.youtube.com/watch?v=FCzv4x13B34
"DSG controller from Andrenalin Tuning"
http://www.adrenalintuning.de/
You might email them as there isnt any informations on their website.
sam- is online now   Reply With Quote
Old December 30th, 2017, 01:50   #10
ryanp
ryanp's Avatar
They rarely reply to emails about that stuff
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old January 4th, 2018, 22:35   #11
FRITS91
dq500 until the installation is debugged.
while we put the dq250 in another mono-drive golf 1.
it turns out that it is necessary to make a data converter on the bus - that would turn milligrams into a torque ... does anyone have any experience of manual correction of the firmware dsg? Is it possible to simply scroll the mechatronics to work without an engine - only in terms of the speed of rotation of the shafts? these projects are designed for drag . The main fast switching up and strong clutch pressure
Old January 8th, 2018, 00:00   #12
Alexey ACV
Alexey ACV's Avatar
Look like its none possible let it work without main data by canbus. So a german guys make a right choice to convert analog inputs by controller to can . And for sure they can map it when it need. (pressure,lauchcontrol..etc.) I make it with stock dsg contorlers few times and its realy have nm likes edc/med17,16
powerTDI4ever!
Alexey ACV is offline   Reply With Quote
DSG 02E to DQ500 7speed SWAP, ratios needed Macradiators.com Upgrades (non TDI Engine related) 0 September 29th, 2016 14:10
Issues with Teves 20 upgrade on Corrado Purple Tom Upgrades (non TDI Engine related) 1 August 10th, 2013 04:58
Polo 6R 2012 TDI DSG7 or Manual daniell Other VW Group TD(I)s 4 May 9th, 2012 19:43
Teves 04 G101 Sensor & 01276 ninedee_golf_tdi VW MKIII-A3/B4 TDIs 6 August 24th, 2011 03:53
Help! ABS Woes... 96 B4 Teves 20 ABS/EDL Nate_Grauvogel VW MKIII-A3/B4 TDIs 8 July 6th, 2006 08:54
Page generated in 0.16589 seconds with 10 queries
[Output: 108.71 Kb. compressed to 91.71 Kb. by saving 17.01 Kb. (15.65%)]
