Old December 26th, 2017, 09:34   #31
Mongler98
Think of it this way. if you had a material, like a carpet, when you vacuum it, its easy to go in one direction vs the other as the grain is going one direction. this is how your snow tires work. your running them the wrong direction. The high point of the angled tread is supposed to go into the wheel against the road, causing the rubber to deform and cause excessive grip. If its backwards the tread deforms with the grain and not against the road surface and would act like a slick tire. For now just drop your PSI down to 25psi and hope for the best until you get it done. Go to pick up some bags of sand or something heavy and put it in your trunk if you can to add some traction.
Old December 26th, 2017, 09:41   #32
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
According to the photo and your description,that would be the left side of the car...
1.9ZOOK is offline   Reply With Quote
Old December 26th, 2017, 09:58   #33
turbobrick240
turbobrick240's Avatar
I think it has more to do with channeling slop away from the contact patch.
Old December 26th, 2017, 10:12   #34
GoFaster
Moderator at Large
Originally Posted by KLXD View Post
Maybe but if the sidewall says right or left it doesn't need an arrow.
It does if there is a distinction in the tread pattern between the inside and the outside. Having both also helps for situations in which people can understand symbols but not words, or vice versa, and there are more than enough of both!
In this situation, it's simple to fix, because the tire not only has the rotation arrow the wrong way but it's also on the wrong side of the car, which presumably means there's at least one the other way 'round on the other side of the car, so it's fixable simply by getting the whole car off the ground and putting the wheels marked "right" on the right and "left" on the left, and (hopefully) the rotation arrows will be all sorted out.
I had a similar issue with the summer tires on my current car, which aren't directional but are "inside/outside" sensitive. It had a vibration that I couldn't track down ... until I noticed one of the tire sidewalls that I could see from outside the car, clearly had the word "inside" written on it! I took it back to the tire shop, had them flip it around, the vibration went away and never came back.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old December 26th, 2017, 13:39   #35
boodles
boodles's Avatar
At Canadian tire now! They said they could “squeeze in” a last minute rotation... so. Here’s hoping this fixing averything!!
If only people listened to me
boodles is offline   Reply With Quote
Old December 26th, 2017, 14:10   #36
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Besides rotation, instruct them to make sure the tires are on the correct side of the car and that the direction of rotation is also correct.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old December 26th, 2017, 14:30   #37
Mongler98
fantastic.
Old December 26th, 2017, 16:12   #38
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Check that your parking brake is releasing. It’s common on these cars for it to stick on.
On dry pavement there’s enough traction to make the wheel spin even if the rear brakes are dragging. Imagine what it would do on ice.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old December 26th, 2017, 18:38   #39
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
Originally Posted by maxmoo View Post
Keeping your tire pressure on the low side of the recommended range increases traction, especialy in snow! eg. 29psi in the front and 26 in the rear.....check your fuel door sticker.
Quality snow tires make these cars awsome to drive in the snow....as long as the snow isn't so deep that the car's underbody rides on top of the snow and the tires can't reach down to solid pavement.
Best snows that I have had on these cars is the hakkapalitta R's...
https://www.nokiantires.com/winter-t...kapeliitta-r2/
As stated above, proper alignment makes a big differance.....you don't want the tires already "skidding" when driving in a straight line.
Also a dragging brake or brakes, especially on the rear can cause huge traction issues, obviously.
I'll second both your statements, nokians R2s are awesome. I have them on my 2014 and they are best winters I had. I thought they were lousy at first but found the pressures were at 40 psi. Dropped to 28 psi on fronts and it took on quite a bit of winnipegs snow storms. Only had problem with bottoming out during very heavy stuff. Even 4x4s had problems then
Dannyboy is offline   Reply With Quote
Old December 26th, 2017, 19:41   #40
VincenzaV
VincenzaV's Avatar
Fuel Economy: Better than a tank, worse than a cyclist.
"Best snows that I have had on these cars is the hakkapalitta R's."
-I'll "third" maxmoo/danny boy. I used hakkapalittas in the snow when I lived in Connecticut. The Jetta wagon drove as well (almost) as my 4WD Cherokee!
The company "Nokian" is from Finland, they GET some snow-so they now how to build and test winter tires.
VincenzaV is offline   Reply With Quote
Old December 27th, 2017, 06:32   #41
najel
Just to add another little hint, I have found that turning the traction control off helps as well (when there is snow/ice continuously). Wouldn't do it on partially covered roads, though.
najel is offline   Reply With Quote
Old December 27th, 2017, 07:29   #42
20IndigoBlue02
20IndigoBlue02's Avatar
Traction control is a mixed bag.
On one hand, you have EDL, which brakes the slipping wheel to regain traction.
But you also have ASR, which is a fuel cut.
If you're going to go a climb a steep hill, turn it off, as you need all the momentum you can muster to get up a steep hill
none of this applies to MK4 TDI's, since we didn't have traction control. Late MK4 TDI's had optional ESP though.
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old December 27th, 2017, 10:25   #43
pdq import repair
Fuel Economy: 38.5
This may get derisive comments sent my way, but on my 2WD cars I install the best tires I can find for winter. My favorites being the Hakkapetia, Blizzak, and x-ice. A good tire makes a lot of difference.
If the tires are directional I install them according to the arrows on the front (driving) wheels. If I install them on the rear, or undriven wheels, I reverse direction so the the directional traction scheme is used for braking. In actual usage the braking wheels take better advantage of the traction tread when installed backwards.
When I rotate them as they wear I cross rotate them to keep the tires going the way I want.
On my Quattro, it goes without saying they all run the direction of the arrows, though the same argument could be applied there as well.
I do this on my dual sport motorcycle too, and have for years. The idea of that actually occurred to me there as I noticed some brands actually reversed the arrows of the same tread design, depending on whether it went on front or rear. I now look at the tread and run them backwards to the arrows if applicable.
pdq import repair is offline   Reply With Quote
Old December 27th, 2017, 11:27   #44
UhOh
UhOh's Avatar
Interesting!
Wondering, however, are winter tires' directionality also not related to belt orientation (in addition to tread pattern)? I might be out of touch with what "directional" is now days, but I recall in the past it having to do with belt orientation (not sure if tread direction was also involved- I suppose it depended on what era).
Old December 27th, 2017, 13:12   #45
pdq import repair
Fuel Economy: 38.5
I think belt orientation in relation to direction is a myth. My preferred method of tire rotation on non directional tires is cross rotation, which also changes direction of tire after rotation.
Have done this for many many years on all manner of tires, including motorcycles. I think tread pattern is the determining factor.
As mentioned earlier, some tires have and inside and outside mounting, and that should be followed, but that would not change with cross rotation either. That is also tread pattern related, and not internally different.
Snow Tires & Factory 2003 Jetta Wheels Bliddy Bladdy Private TDI Items for Sale/Wanted 2 February 14th, 2014 16:56
How does a 2003 Jetta handle in the snow? 79TA7.6 TDI 101 43 December 7th, 2008 13:37
Recommended snow chains/cables for 2003 Jetta GLS TDISurfer Upgrades (non TDI Engine related) 4 February 18th, 2004 02:42
2003 Jetta TDI Wgn Snow Screen? Alster VW MKIV-A4 TDIs (VE and PD) 2 January 5th, 2003 00:42
Studded Snow Tires or any snows on 2003 Jetta Wagen Brian Y VW MKIV-A4 TDIs (VE and PD) 7 November 25th, 2002 23:50
Page generated in 0.18520 seconds with 10 queries
[Output: 131.42 Kb. compressed to 110.32 Kb. by saving 21.09 Kb. (16.05%)]
