Old December 25th, 2017, 09:37   #16
Mongler98
AL so its important to note that you get snow tires in a less wide tire size. For example if the tire you have is a 105/75/16 you would get say a 95/75/16, Just an example and just about all tires whops and cars have the tire size for what you need. Tirerack.com has this automatic for you too.
Old December 25th, 2017, 11:31   #17
jettawreck
jettawreck's Avatar
The OEM size for the "standard" wheel is a 195/65/15 and in a decent tread pattern do a great job in the snow.
2004 Cadillac SLS (wife's)
Old December 25th, 2017, 21:17   #18
boodles
boodles's Avatar
Hi everyone, thanks for all the tips, looks like 90% of my problem is probably the directionality of the tires and their pressure.
Will have to see if I can find anyone tommorrow to swap the tires for me as I have nowhere and no tools to do it myself, plus it’s -20 below to be doing it in a parking lot on all four tires right now.
Just to be clear, does it matter if the “Left” labelled tire ends up on the right side of the car, and vice versa? Or just that the arrows are front/forward facing.
If only people listened to me
boodles is offline   Reply With Quote
Old December 25th, 2017, 21:26   #19
Mongler98
Yep, lefts go on rights. as long as the arrows point the right way, your good. What area you in, maybe one of us can give you a hand? if you were close enough to me i would help you out. A trick to jack up your car. look in the trunk, find the jack that is in the spare tire. now go drive to a car wash and do it under the shelter of that. OR just Bring a 6 pack of beer and 2x $20 ($20 for each guy if its two of them) bills to a local tire shop ,not a chain like NTB or Mr. Tire, some gas station mechanic and ask the guys in the shop, not the guy in the front, if they can swap your tires around. I used to work in a tire shop and i have seen stunts like this happen a few times now and again.
Old December 25th, 2017, 21:38   #20
Mongler98
The shop i was at would do stuff like that for free as they value return business. no shop ever makes money on tires and tire service. its all the mark up crap like brakes, filters, and what not so its adventitious for them to do things like this for free or for a few bucks. I know $20 plus $7 for beers is a bit much for this but its cold as hell, snow, and its worth it IMO for being able to drive safe ASAP as your in a jar of frozen pickles!
Old December 25th, 2017, 23:37   #21
turbobrick240
turbobrick240's Avatar
Before you swap the tires side to side, a photo/s less zoomed in, that shows more of the car (but still shows the arrows) would be helpful. I'd just reduce the pressure to 30 psi until you get confirmation that they are indeed on backwards.
What model of Toyo tires are these? Some manufacturers are making winter rated tires that are both directional and asymmetrical- sort of an all season and snow tire hybrid. They are probably not as good in the snow as a dedicated, directional only snow tire.
I just put a set of Nokian Nordman studded snows on my golf, and they are AMAZING in deep snow. Even better than the Hakkapeliitta's I've had in the past. They're a bit loud on clear pavement, but the noise is worth the winter performance, imo.
Old December 26th, 2017, 03:50   #22
boodles
boodles's Avatar
Unfortunately I’m heading out of town tonight. I’m located in Toronto, Ontario, and headed up to Thunder Bay to visit family for the holidays tonight as soon as I get off work. Hopefully as you said I can find a shop that will swap them real quick before I leave but it being Boxing Day a lot is closed unfortunately.
Here’s a bit of a backed of picture, hopefully you can still see the tire markings, that’s the right front.
Old December 26th, 2017, 06:30   #23
whitedog
Look at the tread. If you draw a line around the circumference, is the left side of the tire, the same as the right? If they aren't, then they are asymmetrical and should be put on the correct side of the car in the correct rotational direction.
Old December 26th, 2017, 06:45   #24
turbobrick240
That looks like the front left/driver side to me. I can't quite make out the arrows in that photo though.
Old December 26th, 2017, 06:54   #25
jmodge
Maybe they are not arrows but just graphics. If the tire says mount on left or right side of vehicle, that is where they belong.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old December 26th, 2017, 07:11   #26
boodles
boodles's Avatar
So sorry yes that’s the front left lol
I’m not sure what you mean about the tread... I know right is on the right but those arrows are the wrong way. Could they be on the rims, i dont know, inside out?
Old December 26th, 2017, 07:35   #27
KLXD
I agree with jmodge. Those look like graphics to me too. Any arrows I've seen on tires are unmistakably arrows.
Did your picher get reversed? That looks like the left to me also.
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
Old December 26th, 2017, 07:59   #28
Mongler98
no way. im 100% sure that is a directional arrow. My Michelin exalto's had the same arrows on them. i worked for 3 years at a tire shop in 2009 to 20011 and i have seen plenty of variations on the arrow design.
Old December 26th, 2017, 09:02   #29
KLXD
Maybe but if the sidewall says right or left it doesn't need an arrow.
Old December 26th, 2017, 09:03   #30
boodles
boodles's Avatar
I really hope it is, and I looked up the brand/model and it says they are supposed to be directional. If not i can’t see what else causes the car to slide 4ft info traffic at the tinniest patch of slush. I’ve hopefully found someone to take a look and swap them tonight. Fingers crossed.
Snow Tires & Factory 2003 Jetta Wheels Bliddy Bladdy Private TDI Items for Sale/Wanted 2 February 14th, 2014 16:56
How does a 2003 Jetta handle in the snow? 79TA7.6 TDI 101 43 December 7th, 2008 13:37
Recommended snow chains/cables for 2003 Jetta GLS TDISurfer Upgrades (non TDI Engine related) 4 February 18th, 2004 02:42
2003 Jetta TDI Wgn Snow Screen? Alster VW MKIV-A4 TDIs (VE and PD) 2 January 5th, 2003 00:42
Studded Snow Tires or any snows on 2003 Jetta Wagen Brian Y VW MKIV-A4 TDIs (VE and PD) 7 November 25th, 2002 23:50
Page generated in 0.19512 seconds with 10 queries
[Output: 129.66 Kb. compressed to 108.04 Kb. by saving 21.62 Kb. (16.68%)]
