Old December 24th, 2017, 08:09   #1
Stromaluski
Stromaluski's Avatar
Default O-Ring on Turbo Oil Feed Line?
I've been collecting parts to upgrade the turbo on my AHU to a VNT-17 and ended up with a question about the feed line. I purchased an aftermarket, braided feed line and realized that the end of it has an o-ring in a groove that was cut into the fitting. This seems out of place to me... I would think the fitting should seal without the o-ring, as it is the same idea as the flare on brake lines or AN fittings, for example. The aftermarket ones I find online all seem to have this o-ring; but as far as I can tell, the OEM feed lines do not. To be fair, though, I have no first hand experience taking off the feed line from an ALH. All my experience has been on a 1.8T which uses a banjo bolt and I am simply going off of second hand knowledge and diagrams. I don't see a seal shown in the part diagram.
So my questions are whether that o-ring should be there or not? If it should, is it the right size? And if so, how do I get it into the union on the turbo without slicing through the o-ring?
-Andrew
Stromaluski is offline   Reply With Quote
Old December 24th, 2017, 08:43   #2
Mongler98
Looks out of place. My gt2052 on my AHU is the same fitting as all other turbos, a 1/4" NPT threads. Put that to -6an or -4an, can’t remember right now and just got a braided hose and modified the banjo on the oil output I got a banjo -4an (if that was the size, can’t remember) and used the stock banjo bolt. But I did port the banjo to allow more flow in the inside so it was more similar to the stock. I have never seen an o'ring on a turbo ever. That fitting gets HOT and I mean HOT. I would think that o'ring would fail very easily.
Old December 24th, 2017, 10:01   #3
oldpoopie
oldpoopie's Avatar
Where did you get it?
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old December 24th, 2017, 10:02   #4
oldpoopie
oldpoopie's Avatar
Also i doubt that nut will even fit btween the compressor housings..... looks like the nuts interfere
Old December 24th, 2017, 12:47   #5
Nevada_TDI
I have one of those o-ring oil lines as well, and the fitting mine goes into has a larger I.D. than the one you have. I have thousands of miles on mine and have had no oil issues with it, in spite of the fact it has been removed and re-attached 5 or 6 times.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old December 24th, 2017, 13:26   #6
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Looks like the wrong fitting altogether. This is the only type of compression fitting that I've ever seen on a VW TDI turbo...
-George Bernard Shaw
Old December 24th, 2017, 17:25   #7
[486]
TDI(s): 02 golf ALH
the taper should seal on its own, but w/e
there's a groove in it for an o-ring, so leave the o-ring in there
if it doesn't clear the bolt holding the compressor housing on, you can toss that bolt, as there are 5 more holding it on. Or you know, clock the housing a little to put it away from the oil fitting. Whichever is easier.
[486] is offline   Reply With Quote
Old December 24th, 2017, 17:30   #8
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
ive used ebay flexible feed lines with that o-ring in there on 3 different TDI's now without any issue.
2 of them are still fairly fresh installs but one has over 3 years on it now without noticing a leak.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old December 25th, 2017, 05:23   #9
Stromaluski
Amazon. https://smile.amazon.com/Turbo-Jetta...turbo+oil+line
Also i doubt that nut will even fit between the compressor housings..... looks like the nuts interfere
The picture is deceiving. It fits ok between them. I didn't think to make sure that I could get a wrench on it, though. I'll have to check that.
Glad to hear that there have been no issues using them. I would have thought that the turbo would get way too hot for the o-ring and it would end up melted?
-Andrew
Old December 25th, 2017, 09:59   #10
Nevada_TDI
Generous oil cooling prevents ruining of the o-ring.
_______________
Old December 25th, 2017, 10:50   #11
[486]
TDI(s): 02 golf ALH
and that there's another o-ring between the compressor cover backing plate and the center housing
much closer to the heat
Old December 25th, 2017, 10:59   #12
QuickTD
The fitting appears correct, but the o-ring cross section is too large. The fitting style is DKOL, it should have the same dimensions as the stock compression DKL ("olive" style) fitting but the hose crimp fittings in this series have an o-ring added to make up for the lack of conformability of the formed one-piece fitting.
It may seal without the o-ring but for insurance, I would find a smaller cross section o-ring and go with that.
QuickTD is offline   Reply With Quote
Old December 26th, 2017, 06:10   #13
Stromaluski
Sounds like a good plan to me. Thanks!
-Andrew
Old December 28th, 2017, 16:59   #14
corsabala
I've never seen this O ring before. But the feed line isn't like that
corsabala is offline   Reply With Quote
05 TDI Golf turbo replacement pics and oil feed line replaced w/ steel braided line. Kruso VW MKV-A5 Golf/Jettas 6 May 8th, 2013 20:52
Turbo Oil Feed Line microsoot VW MKIV-A4 TDIs (VE and PD) 10 May 10th, 2012 11:49
Broken oil feed line fitting. All for a water pipe o-ring! Redneck Truck VW MKIV-A4 TDIs (VE and PD) 11 September 15th, 2011 19:40
Turbo oil feed line. Do u have one? willyraz TDI 101 7 January 23rd, 2008 18:32
have a look at your turbo's oil feed line because laminated VW MKIII-A3/B4 TDIs 3 October 22nd, 2004 14:10
Page generated in 0.15653 seconds with 10 queries
[Output: 125.13 Kb. compressed to 104.71 Kb. by saving 20.42 Kb. (16.32%)]
