Old December 23rd, 2017, 17:37   #1
armycanuck's Avatar
Default Mk6 Light Bar
Just mounted a Rigid Sr-Series 6" Combo PN# 906313 to my MK6 Golf TDI. Mounted on Smittybilt PN# 2815 - licence plate Light Mount.
Throws a nice beam about 800m, floods a decent amount surrounding also. The aftermarket Projector Headlights don't have good high beams... So this is a nice supplement.
It's not very obtrusive. I'm just using supplied switch run to cabin for now, will eventually run it through euro switch, to rear fogs maybe. Have some research to do yet in order to finish that bit up. I'll add some more pics next week with light throw, wiring, etc
Sent from my LG-H831 using Tapatalk
armycanuck is offline   Reply With Quote
Old December 24th, 2017, 08:04   #2
Fuel Economy: Dismal
Unobtrusive, which I like. Any reason you chose the 313 over the 312? Rigid has too many lights, which makes it confusing...
Out of curiosity, what’s the amperage draw? Looking forward to pics.
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is online now   Reply With Quote
Old December 24th, 2017, 12:45   #3
Moderator at Large
You should be able to power this from the existing high beam circuit, then it will automatically work when it should and be off when it shouldn't. These don't have a beam pattern suitable for fog lights.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is online now   Reply With Quote
Old January 4th, 2018, 16:21   #4
Thunder Chicken
Thunder Chicken's Avatar
Here (maybe) a picture of my 30" light bar in my lower grille.
Its on a relay spliced to my high beam wire to trigger when high's are on.
Works great! Semis will always dim lights at night now!
Thunder Chicken is offline   Reply With Quote
Old January 7th, 2018, 18:41   #5
VincenzaV's Avatar
Fuel Economy: Better than a tank, worse than a cyclist.
Thumbs up
That looks so clean! Kudos to you for being the 1 in 10,000 that buy the American made light, as opposed to the knock-offs.
VincenzaV is offline   Reply With Quote
Old January 9th, 2018, 21:39   #6
Nice! like the mounting. Cant wait to see how you wired it.
toastyjosh is offline   Reply With Quote
FS: Hotchkis Rear Sway Bar MK5/MK6, New in Box jonferns Private TDI Items for Sale/Wanted 4 January 2nd, 2018 15:56
WTB Westfalia Tow Bar for MK6 Golf ThatGTI Private TDI Items for Sale/Wanted 8 August 3rd, 2017 22:31
DieselGeek Panzer Skid Plate (Mk5/Mk6) + APR Rear Sway Bar TR10 Private TDI Items for Sale/Wanted 3 August 4th, 2016 12:45
FS: Cincinnati-16" wheels+tires; MK6 GTI springs; BFI rear sway bar Robimplicit Private TDI Items for Sale/Wanted 7 December 3rd, 2015 08:12
Golf MK6: Glow plug light gone, DPF clogged light on rsquared Ontario 0 July 30th, 2012 09:27
Page generated in 0.10887 seconds with 10 queries
[Output: 72.95 Kb. compressed to 63.74 Kb. by saving 9.21 Kb. (12.63%)]
