Old December 22nd, 2017, 17:20   #1
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Arrow Tuners ~~ Cost of TDI Power Enhancements
For those who wish to do some tuning from mild to wide, what is the range on prices?
And for an example, what might be results (HP and Torque) on my 2015 Golf TDi DSG?
Thanks in advance for any info
2015vwgolfdiesel is online now   Reply With Quote
Old December 22nd, 2017, 18:10   #2
DerekG
Fuel Economy: Towing:26-32.6 City:34-38 Hwy:45-54.2
https://malonetuning.com/
http://www.kermatdi.com/
https://www.rawtekinc.com/
http://www.fixmyvw.com/
DerekG is offline   Reply With Quote
Old December 22nd, 2017, 19:20   #3
Mongler98
plan on $350-400 depending on what you get, The tune will not change the price, the materials will, like a loader, or a 3 bar MAP etc..
Old December 23rd, 2017, 07:04   #4
740GLE
350-400 may be of the older tunes, the current prices have climbed with inflation.
I don't think you can get an ECU tune a '15 for under $5-600.
Also, ECU tunes only really work if you drive the car and utilize the peak numbers, 90% of the time you can accomplish the same feeling buy just pressing more on the go pedal.
What you may enjoy is a TCU tune, cost is about the same but you use the DSG and its shifting way more than peak HP numbers.
Old December 23rd, 2017, 07:40   #5
Mongler98
^^^ This.
Your your nozzles a few sizes and up your boost by 3-4PSI will do the same thing as a tune and wont really effect your mileage any. Not sure what your ECU's Map will let you get away with in more boost but its cheep and will benefit from other mods like head work.
Old December 23rd, 2017, 08:42   #6
gmo
it cost me about 2 grand (uk)to get a pd130 to 210bhp and 360lbs, that inc clutch .. after that your into gtb's bigger nozzles and head work.. after 260 ish the bang for buck isnt worth it imo
using old bit with new hybrid i hope to get 240bhp and 380lbs
gmo is offline   Reply With Quote
Old December 23rd, 2017, 09:14   #7
Mongler98
is that in pounds or USD? If it is, 2600 aint that bad. i have an easy 2K into my engine alone and its stock internals. but its an old AHU
Old December 23rd, 2017, 09:52   #8
gmo
pounds mate , gt1756 hybrid, decat. fmic mapping and clutch..
see if you can pick up set of second hand pd130 injectors and your laughing
Old December 23rd, 2017, 10:22   #9
Mongler98
Nice. Maybe some head work and a cam. If the injectors are out of this world, you could always go water meth injection for some extra power.
Old December 23rd, 2017, 11:02   #10
15TDIreg
On my old Jetta i paid to have it done and parts, labor and tune spent 2100 with a Malone tune. My current Touareg cost 1300 or so all in but i did the labor myself. My American diesel trucks cost about 2000 each to delete which includes Tuner and hard parts but labor is done by me. All well worth it in the end my friend from an efficiency, power and longevity stand point.
15TDIreg is offline   Reply With Quote
Old December 25th, 2017, 02:20   #11
gmo
very tempted with w/m i must say mate. ive read cams give little in way of gains and can cause valves to meet piston.. that cant be good lol
Old December 25th, 2017, 02:20   #12
gmo
Old December 25th, 2017, 05:36   #13
Interesting conversation, but most of it is irrelevant to the OP. I'm not aware of larger injectors for the EA288 engine. Regardless, there's plenty of fuel available through electronic adjustment. Turbo upgrades don't exist yet, at least not in this market, for the EA288. A turbo upgrade would be complex because of the EGR setup and the air-to water intercooler.
Because of this, most folks who want more power get at tune. Rocketchip wasn't mentioned here, but Jeff has a great tune for the EA288. Projected power is 180HP/300 torque. The big benefits in my opinion are much better accelerator response on tip-in, much more like a tuned rotary pump TDI. And the car pulls much better in 6th at lower highway speeds (60 and up). Fuel economy is largely unchanged, unless you use the power all the time.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old December 25th, 2017, 06:20   #14
gmo
would it not be possible to get the turbo reworked with a bigger billet compressor wheel?
Old December 27th, 2017, 09:35   #15
740GLE
No doubt, others have had some sucess with CR190 turbos, but the effort is much more than plug and play, and have heard of some issues with tuning not being able to play nicely.
Page generated in 0.17339 seconds with 10 queries
[Output: 119.76 Kb. compressed to 99.46 Kb. by saving 20.30 Kb. (16.95%)]
