Old December 21st, 2017, 13:20   #1
gmo
Default gt1756 hybrids .. rate or hate
after doing a good bit of digging on the board it seem for the most part folk pick 2052 over 1756.. ther 1756 is not very popular mod and ive seen it push close to 250bhp on some hard pushed units n sub zero temps on dyno, it seem a cheap and cheerful bolt on for a pd for us who cant just shell out for full gtb kits
what your bolt on choice for hybrid on pd an why. 2052/2056 or 1756 or other??
.. my car will be mainly driven hard on tsity b roads and mid term goal of 23o-240bhp and 380lb and as punchy as poss.
(2052 is never really used in uk tbh)
thanks for input
gmo is offline   Reply With Quote
Old December 21st, 2017, 21:59   #2
sam-
if you get some skill to adapt yourself the turbo, take a gtb2060vklr or gtd2060vzk, it can make boost pretty quickly and still good if you choose to go with nozzle upgrade for more power.
sam- is offline   Reply With Quote
Old December 21st, 2017, 23:44   #3
adamss24
Fuel Economy: 35-45mpg
The vklr are very problematic, they sufer with high egt and bolts holding chra come undone wrecking the compressor or turbine/vnt nozzle ring...
I would use a gtb2056v Or a 1756vk if you want quick boost! Hybrid based gt2052v. Will work but i would upgrade the turbine as well and it will still work worse than a used gtb turbo!
adamss24 is offline   Reply With Quote
Old December 22nd, 2017, 00:47   #4
gmo
next turbo is deffo a gtb2056vk with 9 or 11 blade billet wheel mate , you reckon a gt2052 would spool better make same boost 1756 and hold boost in more stable fashion.. no one seems to use them round here , everyone i know picks the 1756 over the 2052 or hybrid 2060 or x man 1856 hybrid.
Old December 22nd, 2017, 06:01   #5
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
I have run 1722 ,1756,2060 on the Beetle in the real world of roadracing .
We ran the 1722 at 27 lb of boost for a few years worked very good but ran out of steam a 4000 we did test the 2060 but I did not like how it pulled of the turn.
The 1756 work great on the track it pulled so hard of ever turn . It would walk BMW, Poesches too . It was in a ALH build.
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old December 22nd, 2017, 06:53   #6
gmo
Thumbs up
gt or newer gtbs mate .. i ran a va with aa blade at 33 peak and held 28. is was like **** oif **** but ran out of puff early
Old December 24th, 2017, 17:32   #7
[486]
TDI(s): 02 golf ALH
doing it again, I'd ditch the small frame turbos right off the bat and find something of proper size like a VGT s200, or a VGT holset off a cummins dodge
like injectors, just buy ones of proper size to start with
[486] is offline   Reply With Quote
Old December 25th, 2017, 01:38   #8
adamss24
A s200 is a bit overkill on a puny 1.9 tdi however a. Gtb2260vk is plenty big enough for it and with decent lag so wont spool at 4k rpms
Old December 25th, 2017, 04:49   #9
gmo
that what i was thinking mate . darkside had a holest hx on a 1.9 pd arl and really make any boost at alltill 3k some like 50lb and 40 bhp at 3k lol and peaked about 4. fine for 1/4 mile stuff but that about it. mind you when it got wound up the graph shot up lol they had few with john deere 300sx vnt what was more resonsive iirc lol
i drive on twisty north uk b roads so a punchy turbo is must have, 260 bhp and 400lb is goal but the more midrange the better, i dont want to have rev its cock off to get full boost... why can you have antilag on dervs lol
Old December 25th, 2017, 13:47   #10
adamss24
a friend of mine has a pd 1.9 tdi vw caddy with a darkside gtb2260vk kit on it, aftermarket forged rods, firad large nozzles (something really silly +180%) and it goes like clappers! It did cost an arm and leg but it really goes. I have not driven the van- just been in the passenger seat but it does shift nicely!
Old December 25th, 2017, 14:24   #11
Mongler98
I cant hate on any turbo, no matter the size. more vroom vroom woshhhh
Old December 25th, 2017, 23:27   #12
adamss24
I have fitted a gtb1756vk on a 2.0 tdi quattro audi a3 2007 model, it was going greață with a remap from Unicorn Racing, however it wasnt without issues,The manifold and turbo kit(a gtb2260vk in the beginning) where from Xman with one of his fancy billet compressor wheels however it was very slow to spool, badly adjusted leaking EMP and the customer sent it back. I then fitted a 1756vk core to it and it was a blast to drive- quick spooling and loads of torque from tick over. The customer drove it hard for a year or two till the car got written off due to a minor accident. The xman kit came with a log style manifold which needed extensive modification to fit: cut and shut and a new flange to fit the new style gtb1756vk exhaust flange. Personally I can live with a bit of lag and I will rather take a stock cast wheel over a shiny billet wheel of unknown origin !
Old December 26th, 2017, 03:24   #13
gmo
good man!! and boost is good boost im my book
Old December 26th, 2017, 03:36   #14
gmo
i lke billet just for fact i know its stronger than cast mate as long it from good metal and made in us or eu and great choice of styles .. the 11 blade made huge difference to spool on my vb
i had few issue with xman. vnt set mile out and
i didnt know you could fit a 1756 core ina 2260? can you elaborate please.
Old December 26th, 2017, 10:21   #15
adamss24
Its almost a direct fit however the core needs the compressor housing as well- on the gtb2260vk the chra is one piece steel but on the gtb 1756vk the chra is conventional(2 piece) and the back plate is held with screws just like on the gt series...
VNT 17/22 or GT1756?? for ALH. Diesel Mania_26 TDI Power Enhancements 44 December 14th, 2013 19:23
FS gt1756 410onefour Private TDI Items for Sale/Wanted 7 June 9th, 2013 19:44
Why is that people think that hybrids are alternative fuel? I hate hybrids!! BioNerd General VW Discussion 29 January 6th, 2012 18:43
Hybrids vs. Non-Hybrids: The Five Year Equation jbright General VW Discussion 0 February 23rd, 2011 08:33
AHF with GT1756 Jasengine TDI Power Enhancements 50 September 17th, 2009 12:13
Page generated in 0.15368 seconds with 10 queries
[Output: 129.14 Kb. compressed to 108.50 Kb. by saving 20.64 Kb. (15.99%)]
