Old December 20th, 2017, 18:47   #1
gmo
Default can fitting a shim to solve smf issues on 02m box?
any one got in exp with this . did fitting a shim make the smf a a bit more user freindly
thanks
gmo is offline   Reply With Quote
Old December 20th, 2017, 20:29   #2
Mongler98
make the SMF a bit more user friendly?
like what? give it more personality? JK
Old December 21st, 2017, 02:13   #3
gmo
lol,, less sticking in gears at low revs and dull the noise a bit mate
Old December 21st, 2017, 07:58   #4
Mongler98
When was the last time you changed the trans oil with the Proper stuff?
Old December 21st, 2017, 13:25   #5
gmo
same time as change of clutch mate . tried 2 boxes and both same
engine and trans oil get done 2x per year
Old December 21st, 2017, 15:46   #6
Mongler98
How many miles are you putting on the car you have to change the trans fluid 2 times a year? thats WAY to much, its not going to hurt it but thats just $$$ down the drain. Trans fluid is usually 75-150K depending on the car. MAKE SURE that you are using the correct line of fluid. there are like 10 different types of trans fluid all in the same weight range. you need to know that some trans have brass syncros and some have Kevlar clutches, it all depends on what you have. What code is your O2M? I think that this is probably your issue. O2M's and just about all transmissions that are in healthy shape dont have your issue. #1 cause for trans failure is burnt out fluid or too much moisture in the fluid. Not sure if thats your problem as you changes it 10x more frequently than normal. How many miles is on the trans?
Old December 21st, 2017, 16:57   #7
adjat84th
adjat84th's Avatar
Try adjusting the cables?
The SMF is just going to make noise, period. Even with a "silent" clutch and Fluidampr mine still makes noise.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old December 21st, 2017, 18:31   #8
Kevinski4
Kevinski4's Avatar
I think he is talking about adding a shim to the throwout bearing/slave cylinder because his clutch may not be fully disengaging.
I am a Malone Tuning dealer in Eastern WI, including Common Rails and DSG, Sprinter, and BMW! Visit our website: www.facebook.com/wisconsindiesel
Forget Clean Air, It's a Power and Money Grab
Kevinski4 is offline   Reply With Quote
Old December 21st, 2017, 21:53   #9
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Like this?
http://nothingleavesstock.com/online...oduct=13912883
I put one in my Jetta (02M), Have the same transmission and clutch in my TT without the shim - I can't tell any difference between the two.
Comes with rave reviews for whatever that's worth.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old December 22nd, 2017, 03:15   #10
gmo
this trans has about 120k on i get mates rates at garage (MY BRO OWNS IT) and one of my best mate it tech for vw pullmans and get full service every 6 months as i drive my cars hard , all fluids filters bushes ect..
check link mate , i think sussed it !
http://forums.vwvortex.com/showthrea...aft-axial-play
doing some research lead me to this seems well explained in link,
"problem solved with a shim and bearing cover costing 14 quid in total and half an hour of time. Basically a gearbox specialist told me the main shaft bearing spring clip eats into the Bell housing causing play. I had almost an 16th of an inch eaten away. Put the shim on and its like new. No drag, no difficulty from reverse to 1st or crunchy changes from 1st to 2nd. Saved 700 quid to get it refurbed. Just follow the link below and use the part numbers for shaft play and jobs a gooden" .. source .. briskoda.
Old December 23rd, 2017, 21:28   #11
[486]
TDI(s): 02 golf ALH
Originally Posted by Fix_Until_Broke View Post
Like this?
that makes no sense
Hydraulic TO bearing is self adjusting. Run it out of travel and it blows out.
I guess I should get in the business of making shims to go atop the clutch pedal pad.
[486] is offline   Reply With Quote
Old December 23rd, 2017, 21:38   #12
Mongler98
looks like snake oil to me
Old December 24th, 2017, 00:01   #13
Yourbuddysatin
W T F mate??
Yourbuddysatin is offline   Reply With Quote
Old December 24th, 2017, 03:31   #14
gmo
Thumbs up
this^ it sometimes sticks in 1st 2nd and rev
Old December 24th, 2017, 03:33   #15
gmo
Originally Posted by [486] View Post
that makes no sense
so why are many reporting it solves the issues then mate unless it only works on car in the uk.. i dont know ,
SMF vs DMF, 02M gearbox. Cookiez TDI Power Enhancements 0 March 29th, 2016 09:39
SMF 02M clutch Sc0 TDI Power Enhancements 4 February 19th, 2015 23:36
FS: 02M Diff shim set smopoim86 Private TDI Items for Sale/Wanted 0 April 27th, 2014 14:38
02m Casting replacement & Shim question Burl4561 Upgrades (non TDI Engine related) 0 April 19th, 2014 20:19
02m smf clutch flywheel? v-dub-u TDI 101 3 July 30th, 2012 17:37
Page generated in 0.17889 seconds with 10 queries
[Output: 129.27 Kb. compressed to 108.55 Kb. by saving 20.72 Kb. (16.03%)]
