Old December 20th, 2017, 15:35   #1
corsabala
Default PIPERCAM 272 camshaft upgrade
Hi everyone,
I have a 1.9 TDI VE AGR 90hp with a GT2260VK MFS, 11mm pump head and 0.360mm nozzles. So I'm thinking about buying a 272 Pipercam for my engine.
My question is: The valves don't hit the pistons with this camshaft? Anyone are using that can help me?
A friend had this camshaft in a 1.9 TDI AHU some weeks ago and the engine was doing a noise "knock knock". When he installed the OEM camshaft the noise disappeared.
Thank you
corsabala is offline   Reply With Quote
Old December 20th, 2017, 16:25   #2
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
I havent tried that one...but that does happen with many high lift cams. You will need to deepen the valve reliefs on the pistons an appropriate amount if you wish to use a cam such as this.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old December 20th, 2017, 22:52   #3
Jukums
Is this camshaft from gasoline engine ?
Jukums is offline   Reply With Quote
Old December 21st, 2017, 03:16   #4
Johnny10bx
TDI(s): 1.9 M-TDI
Dbilas cam 272 and 260 the same problem.
Johnny10bx is offline   Reply With Quote
Old December 21st, 2017, 13:39   #5
Mikkijayne
Mikkijayne's Avatar
TDI(s): Audi S8
Fuel Economy: lol
The Newman regrind cam has 9.9mm of lift and fits fine with stock valves. I've done a few of them now
http://www.newman-cams.com/camshafts/
They don't list the regrind on their site, but its about half the price of a new blank. Best to email them for details. Turn-round time is usually a couple of weeks so best if you can send them a spare if you need to keep the car running.
Pecuariam felis
Mikkijayne is offline   Reply With Quote
Old December 22nd, 2017, 06:56   #6
leon10tagg
leon10tagg's Avatar
Yes the Newmans regrind is a great option and not expensive. I've fitted a couple of them to VE motors with consistent results.
Currently they do not have an option for a new blank grind.
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, Newman cam, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
05 & 04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
leon10tagg is offline   Reply With Quote
Old December 26th, 2017, 09:22   #7
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
I don't know about that particular camshaft, but I can say that with 11mm of valve lift and 270 duration not only will they hit the pistons, it'll make the springs bind up as well lol
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old December 26th, 2017, 18:28   #8
corsabala
Thank you all for the answers.
I will send an email to Newman for more information.
@Mikkijayne, if the Newman cam have 9.9mm of lift, what's the lift the 272 and 260 cam dbilas and pipercam? Anyone know?
@Jukums, it's a diesel engine cam.
@leon10tagg What are the biggest performance differences with Newman cam you noticed?
dbilas 272 cam 1.9vp Johnny10bx TDI Power Enhancements 1 February 24th, 2017 12:15
1.9TDI PD 8V camshaft upgrade for 250bhp ? X-Man TDI Power Enhancements 15 March 21st, 2014 00:46
timing dbilas 272 pd cuprapower TDI Power Enhancements 4 December 22nd, 2013 17:49
1.6 IDI camshaft as an upgrade? 2footbraker TDI Power Enhancements 5 November 23rd, 2009 01:31
what to do next? 1996 passat with 272,000 mcquinn VW MKIII-A3/B4 TDIs 6 November 24th, 2004 19:28
Page generated in 0.15763 seconds with 10 queries
[Output: 84.42 Kb. compressed to 72.62 Kb. by saving 11.81 Kb. (13.99%)]
