Old December 20th, 2017, 09:33   #1
jctdi00
Default Trace on ecm from tune
I have a Malone stage 1.5 tune and the flashzilla. I was wondering if anyone knows if any trace is left on the ecm after you put the stock tune back on. California recently changed the software for the smog in hopes of catching if you have had your car tuned. I have an 01 Cummins that used to have a box tuner that plugged into my map and data link connector and despite not having issues at the last inspection, it just failed due to presence of tampering in the ecm. Should I be fine with the Jetta since it is a flash rather than a box tuner
03 Jetta TDI GLS Manual : dlc764, vnt17, mufflerectomy, glowshift boost and egt gauges
jctdi00 is offline   Reply With Quote
Old December 20th, 2017, 10:23   #2
Owain@malonetuning
The flash counter changes unless you decide to set it to zero. You'll be fine since this is a proper ECU flash.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is online now   Reply With Quote
Old December 20th, 2017, 11:17   #3
KERMA
KERMA's Avatar
FYI, there is no flash counter on a 2003
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old December 20th, 2017, 11:27   #4
Nevada_TDI
Charlie, If someone buys a tune from you and then buys their upgraded hardware from you too, do you charge them for ECU updates?
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old December 20th, 2017, 11:36   #5
KERMA
KERMA's Avatar
kind of off topic, but since you asked:
Always free tune upgrades to support parts sales. or even just because you want something else. Not really into upselling on added cost "features." If you want something, just ask. You may get some pushback if it's silly like "hardcut blah blah" but it will be an honest opinion because there's no incentive to upsell for being "custom".
But I kind of have a hard time subsidizing competitors with free labor.
Old December 20th, 2017, 12:23   #6
Owain@malonetuning
Whoops, I assumed PD since stage 1.5 (speaking of which, PP764 and vnt17 on stage 1.5? how's the bottom end response? feel free to send off a boost log). Yes you're fine either way, same applies for commonrails, revert back to stock if it's an issue, keep in mind you'll want to drive it to reset readiness monitors and can test those with vcds.
Old December 20th, 2017, 18:13   #7
jctdi00
The bottom end is pretty decent. I'm happy with it. It really takes off close to 3k rpm and up. I've had no issues with clutch slippage. A regear would help out some overall since I have the power on tap, but I got 47.5 mpg recently all freeway doing at least 80. I'd really like to do a .681 regear but its discontinued. A .7 is not much of a drop for me to convince myself to buy the gears and the taller gear might hurt me on the grade when I move. It would be cool to get the turbo to sing like the vnt15 without a muffler, but the vnt17 is quiet. I'm definitely happy overall with the car though
Old January 14th, 2018, 09:01   #8
TDIMK4GUY
Fuel Economy: avg 41.5mpg city 47/48 freeway
Sorry to piggy back on this post but it's the closest I've found to my situation. I'm currently getting my 02 tdi golf worked on in Portland and am getting a stage one Malone tune to go along with my vnt17 and 11mm pump. The shop also said a EGR delete is accomplished with the tune if I understood correctly. My car is currently registered in a no smog county in California but my concern is will I have problems passing smog with the stage one tune and the EGR delete if I ever changed the registration address and have to smog it in the future? Thanks and again sorry for hyjacking the thread.
TDIMK4GUY is offline   Reply With Quote
Old January 17th, 2018, 20:12   #9
dirtride
TDI(s): 2003 Golf
Fuel Economy: mid to upper 40's
You're best bet is to keep the vehicle regestered in the "no smog" county. If you change to a Modesto address, when they send you a renewal with emissions check required at the top, you will not pass with the EGR physically removed. Most techs will not notice an VNT-17 or 11mm pump.
Bottom line is you must pass ECM readiness and visual inspection.
Mark
03 GOLF ~ GLS ALH EGR (turned it into a mutt)
00 F-350 ~ 7.3 PSD 4WD ZF-6 XLT LBCC (modified, not a mutt)
dirtride is offline   Reply With Quote
Spare ECM with DPF delete tune? TDItundra TDI (Diesel) Emissions 1 April 8th, 2016 01:24
BHW ECM for 5 speed/ Malone tune NoelMcC Private TDI Items for Sale/Wanted 2 October 18th, 2015 15:03
ECU/ECM tune, injector/nozzle calibration opinions DieselDork TDI Power Enhancements 2 September 3rd, 2015 11:18
glowplug recall = messed up ECM tune? jgeppelt VW B5 Passat TDIs 6 February 14th, 2011 11:11
FS: ECM with RD 2/3 tune dslkevin Private TDI Items for Sale/Wanted 6 April 26th, 2010 09:30
Page generated in 0.10474 seconds with 10 queries
[Output: 94.28 Kb. compressed to 80.63 Kb. by saving 13.65 Kb. (14.48%)]
