Old December 15th, 2017, 22:16   #1
brewer13
TDI(s): '98 Beetle
Default '98 Bettle TDI oil recommendation
Just got this car and want to change the oil. What do most of you use for engine oil and what is the best oil filter. Thank you for any input....
brewer13 is offline   Reply With Quote
Old December 16th, 2017, 07:54   #2
scooperhsd
No Owner's manual ? No looking in the thousands of similar posts ?
Oils - anything that meets VW505.00 or later, or any diesel rated 5w40 synthetic, CF4 rating or later. You can buy oil at your VW dealer, European Car formula, Shell Rotella T6, Mobil Turbo Diesel Truck, etc.
Oil filter - Mann /Wix - again you can purchase at the VW dealer or online. Just look for ALH as the motor type. There are a number of online venders that can supply the whole package (oil + filter).
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old December 19th, 2017, 22:00   #3
BorisBug99
TDI(s): 99 beetle
What he said.
1999 Beetle 35,000 original mile barn find.
BorisBug99 is offline   Reply With Quote
Old January 2nd, 2018, 12:38   #4
otm646
Fuel Economy: 54/48.5/43
Either Mobil 1 Turbo Diesel Truck (often called TDT on the forum) or Rotella T6 (They unfortunately just changed the formulation) 5w40 but they're still great oils and available everywhere.
76 300d 475k
97 750IL V12 working SLS 187k!
98 Jetta AHU 330k! PD150 intake 2.5 SS straight pipe- Sold to Papa Validius
05 WRX 5 speed wagon 220k + flow mods ~270 HP
81 Lancia Beta Zagato
otm646 is offline   Reply With Quote
Old January 2nd, 2018, 12:45   #5
belome
Fuel Economy: 47'ish
Since you are new... are you aware the of Timing Belt change intervals? Those are heartbeat of the TDI and when they fail it is big money to fix.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old January 10th, 2018, 11:47   #6
toastyjosh
I have been using t6 for a good while, right now I am using Mobile 1 tdt cause I got a good deal.
here is a good vid
https://www.bing.com/videos/search?q...9B5A&FORM=VIRE
toastyjosh is offline   Reply With Quote
Old January 17th, 2018, 01:11   #7
garreth5
TDI(s): jetta
Anoter option is the Castrol Syntec 5w40.
garreth5 is offline   Reply With Quote
Old January 19th, 2018, 16:47   #8
Rob Mayercik
Or the Mobil Delvac 1 5w40
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
Old January 21st, 2018, 02:15   #9
h4vok
h4vok's Avatar
Fuel Economy: 35 to 50
Another +1 for shell diesel T6 I use the 5w40 and 0w40 versions of it in my 03. The TDT is good too and both should be available locally. If you want to go euro oil online pentosin hp2 5w40 I have heard is good and has both the 505 vw ratings if your into that.
DLC520, Mufflerectomy, tuned, more linked below
My car thread
h4vok is offline   Reply With Quote
Old January 21st, 2018, 07:19   #10
whitedog
What did they do to the T6? If you are referring to the change from CJ to CK, that is a periodic reformulation to keep the oil operating for new engine technology.
Old January 21st, 2018, 08:01   #11
jettawreck
jettawreck's Avatar
Sticky from the forum header:
http://forums.tdiclub.com/showthread.php?t=158788
2004 Cadillac SLS (wife's)
Old January 21st, 2018, 20:38   #12
tjpeterson96
tjpeterson96's Avatar
TDI(s): 04 bew jetta
I've seen Blackstone test from unused samples of the CJ and new CK flavors on BITOG and and the CK no Moly in it at all
tjpeterson96 is offline   Reply With Quote
Old January 22nd, 2018, 07:23   #13
whitedog
So I wonder if other oils are doing away with moly in their oils as well. I also wonder why they are going away from it. I also wonder if I should have leftover pizza for breakfast or save it for lunch.
Old January 30th, 2018, 04:56   #14
Powder Hound
Powder Hound's Avatar
Yes, they are. Because the molybdenum is there as molybdenum compounded with sulfur. It is a great antiwear compound because it breaks down and releases the plating molybdenum via pressure and does not need a lot of heat like the zinc compounds do. The reason they're getting rid of it is because when it breaks down, it releases the sulfur, which poisons exhaust catalysts.
And finally, breakfast, definitely. If you wait for lunch you run the risk of someone else grabbing and eating it, and/or if you wait, you have to heat it up first.
Cheers,
PH
Old February 4th, 2018, 20:01   #15
reince
TDI(s): 2006 Beetle
Use Mobil 1 Turbo diesel truck, tried and tested here.
reince is offline   Reply With Quote
98 bettle tdi - discontinued l/r door latch assemblies GotEuroCorrado TDI 101 9 February 11th, 2017 08:55
wtb 98-2000 TDI bettle 5speed gsman TDI Cars for Sale/Wanted 1 September 10th, 2014 15:58
98 bettle window clips? 02 jetta TDI 101 1 January 3rd, 2010 09:09
98 Bettle TDI $4500 greasewagen TDI Cars for Sale/Wanted 1 December 5th, 2008 10:22
98 bettle tdi slow starting NSTDI New Beetle TDI Picture Gallery 16 November 13th, 2006 07:53
Page generated in 0.14457 seconds with 10 queries
[Output: 125.17 Kb. compressed to 104.16 Kb. by saving 21.01 Kb. (16.78%)]
