Old March 8th, 2018, 17:44   #16
rpm-inc
TDI(s): 2000 beetle
OK, thanks. I don't think the boost should be fluctuating as much as it is?????
rpm-inc is offline   Reply With Quote
Old March 11th, 2018, 13:31   #17
rpm-inc
TDI(s): 2000 beetle
https://log.malonetuning.com/chart/2...nCu0wNAgAAAA==
Boost is supposed to change slightly as it cycles on and off?
Crawled under the car and the circlip is missing. Ran the same test while under the car, and the lever doesnt go to the stop. I can pull it to the stop about another 3/8" or so.
I drained the intercooler about 4k ago when I did the timing belt. Drained it again and got about 2 table spoons. Also, oil is seeping from the boost hose connection above the timing belt cover. Thinking I should just get a new turbo?
Old March 18th, 2018, 13:15   #18
rpm-inc
TDI(s): 2000 beetle
Got the actuator off and it is a mess. Rust hole and rattling around inside. Vane lever moves freely. Put a new garrett actuator on and it hits the stop at 19 in. Doing the basic settings test, it cycles all the way now. So now n75, vacuum lines, and actuator are all new. New log today.
https://log.malonetuning.com/chart/2...wrtMDQIAAAA%3D
Disregard the on off log. Is this considered normal now? Seems like the dip after the overshoot is a bit much?
Overboost ? Log Graph Inside v4id VW MKIV-A4 TDIs (VE and PD) 6 March 29th, 2017 10:18
Boost log graph, sine waves! T-Roy VW MKIV-A4 TDIs (VE and PD) 8 June 15th, 2015 00:31
need advice: boost overcorrect / under shoot with log graph SFHGolfTDI TDI Power Enhancements 12 March 24th, 2015 10:29
Vag com boost log graph borachris TDI Power Enhancements 21 October 30th, 2009 15:17
How to graph MAF log in excel Monkey1 OBD Scanners 1 August 4th, 2007 04:52
Page generated in 0.12968 seconds with 10 queries
[Output: 58.03 Kb. compressed to 52.86 Kb. by saving 5.17 Kb. (8.90%)]
