Old December 10th, 2017, 13:12   #1
rpm-inc
TDI(s): 2000 beetle
Default Boost log graph
I don't have excel and wouldn't know how to use it if i did. Could somebody graph it for me and post it here? I can email the csv file. Thanks!
rpm-inc is offline   Reply With Quote
Old December 10th, 2017, 17:37   #2
rpm-inc
TDI(s): 2000 beetle
https://log.malonetuning.com/chart/3...wNAgAAAA%3D%3D
Getting the car 100% for a tune. And look what malone has! It will be getting a malone tune....
So how does this graph look? Seems lazy at first? Thought it should spike and then settle back down?
Or this one....(EDIT)
https://log.malonetuning.com/chart/3...Ojw4LClsKNAAAA
Old December 10th, 2017, 17:50   #3
rpm-inc
TDI(s): 2000 beetle
4th gear from 2100 to 3800
Old December 11th, 2017, 15:18   #4
rpm-inc
TDI(s): 2000 beetle
Any comments? Look fairly normal? :-)
Old December 11th, 2017, 18:36   #5
wonneber
The 2 boost graph's are very close together.
I'm not an expert but Mine vary from each other more.
I also may have a bit of sticking in the turbo.
Old December 11th, 2017, 20:58   #6
UhOh
UhOh's Avatar
Actual boost is dropping off when it shouldn't be. Not sure what that little spike drop is there, but that ain't right either. N75 looks "lazy" to me: don't ask me what that means (it just "looks" lazy- might be because boost doesn't look like it's real quick, hence the N75 doesn't have to react quickly?).
I believe that Malone's instructions say to run from 1,800 rpm to redline, in third gear; burying the pedal and keeping it that way.
Here's a graph from my son's car, stock tune but T4 nozzles (note how boost shoots up an is knocked back down and then holds very well to Requested):
https://log.malonetuning.com/chart/3...PDgsKWwo0AAAA=
Old December 12th, 2017, 08:18   #7
wonneber
Could this be a bad MAF sensor?
Would MAF logging with the boost & N75 help?
Maybe a look inside the EGR valve to see if it and the intake are clogged?
Old December 12th, 2017, 14:58   #8
rpm-inc
TDI(s): 2000 beetle
I can do another log. Previous owner said he cleaned the intake when he deleted the egr/asv. Should probably do a log with the n18 connected to the turbo actuator?
Old December 12th, 2017, 19:13   #9
wonneber
You could swap them around.
Include block 11 also with the log.
Old March 3rd, 2018, 13:28   #10
rpm-inc
TDI(s): 2000 beetle
Didn't do much about this until recently. Started overboosting and going into limp mode. Swapped the n75 for the n18, and stopped overboosting, but was very laggy. Installed a new Pierburg n75, and the lag is gone. Logged this today. Is the maf bad.
https://log.malonetuning.com/chart/2...7CtzkrGsOCAAAA
Old March 3rd, 2018, 13:41   #11
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
There's also this, if you want to do it on your pc-
Dropbox link - LogPlottingApplication.zip
Old March 7th, 2018, 01:31   #12
UhOh
UhOh's Avatar
What's the story on this car?
The requested Air numbers look problematic. And the N75 doesn't look like it's doing what it should: max change % is low.
Can you log per Malone's instructions? (they call for a 3rd gear pull from 1,500 rpm to red line)
Old March 7th, 2018, 08:17   #13
Owain@malonetuning
MAF looks fine, it correlates with the boost
https://log.malonetuning.com/chart/2...KHw60owpMrAQAA
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old March 8th, 2018, 16:09   #14
rpm-inc
TDI(s): 2000 beetle
The car is a 2000 beetle that I bought with a blown 01m. Put a 5 spd in it and timing belt. EGR was deleted by PO. i have put about 4k miles on it since then.
After posting, I did realize that the maf actual is probably following actual boost, not the other way around. At this point I am thinking something is sticky with the actuator or vanes, causing the boost to over and undershoot. I have not done any testing on this. Maybe this weekend. Car has about 140k miles on it.
Old March 8th, 2018, 16:47   #15
BobnOH
not-a-mechanic
They all look fine to me. If you're purchasing a tune from Malone, they should be able to give better analysis (ask). Getting everything squared away before a tune is just smart.
I remember visiting a local guru for service, he had just finished a chip session with Jeff from RC, he had no less than 4 TDIs in the yard awaiting further repair.
Overboost ? Log Graph Inside v4id VW MKIV-A4 TDIs (VE and PD) 6 March 29th, 2017 10:18
Boost log graph, sine waves! T-Roy VW MKIV-A4 TDIs (VE and PD) 8 June 15th, 2015 00:31
need advice: boost overcorrect / under shoot with log graph SFHGolfTDI TDI Power Enhancements 12 March 24th, 2015 10:29
Vag com boost log graph borachris TDI Power Enhancements 21 October 30th, 2009 15:17
How to graph MAF log in excel Monkey1 OBD Scanners 1 August 4th, 2007 04:52
Page generated in 0.15221 seconds with 10 queries
[Output: 123.09 Kb. compressed to 102.50 Kb. by saving 20.59 Kb. (16.73%)]
