Old December 9th, 2017, 14:24   #1
Nero Morg
Default ALH upgrade options
Hey all, looking to get some upgrades in on my rig, it's a '01 ALH w/manual conversion. I currently have a brand new DMF LUK, 11mm pump, and I think it has the 672 injectors in it since it was originally an auto. Freshly cleaned (taken apart) turbo and adjusted to spec.
I'm not looking for anything crazy, but definitely looking to get some more oomph. Open to ideas of new injectors and maybe a tune. Plus, how to even do a tune this is all fairly new to me. I've already done the usual preventative maintenance like filters, timing belt, even a new MAF/clean intake manifold. Let me know if there's any other details you need too!
Nero Morg is offline   Reply With Quote
Old December 9th, 2017, 18:52   #2
Mongler98
nozzles
water/meth
Tune : call or contact Malone
PD150 intake
EGR delete
Auber gauges
i say water meth or just water to keep your EGT's down so you can crank had some .764 or 520 nozzles with a pop test stage 2 from kerma, Hammer mod your IP to 1.6-2.4.
Bump up the PSI to about 18-19 and get a 3 bar MAP
Have Malone or Kerma Write you a Tune
This is easy power and will be very reliable. You are probably going to need a stage 2 SBClutch Eunduro
Old December 11th, 2017, 07:15   #3
nikolay_ss
TDI(s): 1.9TDI ALH
Bosio 1019 DLC is your best option for optimal mpg and good performance, without needing any other hardware upgrades. Also you really need a tune after install them.
nikolay_ss is offline   Reply With Quote
Old December 11th, 2017, 09:13   #4
Mongler98
with my gt2052 and my .764 on an IQ of 1.4 im still getting 55+ reliable MPG. You want to tune, dont worry about MPG, you WILL get them. the only way to get more MPG is to get more power with out being ridiculous with fuel injection.
Old December 11th, 2017, 09:34   #5
Yourbuddysatin
I agree with nikolay. You already have a 11mm pump so 1019 DLC would be perfect. I donít see why to have the IQ so low though. To get better mileage would be around 5.0-5.5 from me experience. You only lose torque buy raising the IQ from my understanding. I have a 10mm pump and .764 to compensate. My IQ is set around 2.5 and get around 45-48mpg.
Yourbuddysatin is online now   Reply With Quote
Old December 11th, 2017, 11:03   #6
Mongler98
same here, but im at 1.4 iq and get about 53 on average but not the way i drive it lol
Old December 13th, 2017, 15:03   #7
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
1019's and an 11mm is WAY too much fuel for a VNT15, 10mm no problem.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old December 13th, 2017, 19:15   #8
nikolay_ss
TDI(s): 1.9TDI ALH
That's why it needs tune. It's good combo, because of better atomization. Also it would take off stress of fuel pump and timing belt, because it will works at lower voltage. Bosio dlc1019 are good enough to deliver power without excessive smokes.
Old December 14th, 2017, 20:42   #9
turbovan+tdi
turbovan+tdi's Avatar
Exhaust, injectors, tune, that's it for a nice bump in power. Do that and drive it, if you want more, a turbo upgrade is next. KISS is the word here.
Old December 15th, 2017, 13:33   #10
Owain@malonetuning
Hey aren't you in BC? that second S was dropped to avoid hurting anyone's feelings.
Agreed on the setup, PP520 will flow plenty for a stock turbo, then an 11mm with a VNT17 will cover that. Past that things get expensive. With the DMF, I personally wouldn't add nozzles just for the sake of reliability.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is online now   Reply With Quote
Old December 15th, 2017, 19:02   #11
john.jackson9213
TDI(s): 1996 B4V
A tune first, then bigger nozzles,. After that, a turbo upgrade. Right now your turbo limits the power. Budget about$300 for the tune, $3-400 for bigger nozzles. Above that, your clutch will be the weak link
Been there - done that. Had to dial back power because of a clutch. See my signature.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old December 15th, 2017, 19:10   #12
Mongler98
I always thought that the tune was after you did fuel and turbo because your tune needs to reflect what you have, not what your going to do, right?
Old December 16th, 2017, 10:04   #13
nikolay_ss
TDI(s): 1.9TDI ALH
That's right, Mongler. Tune depends on your hardware.
Old December 16th, 2017, 10:52   #14
Yourbuddysatin
I would only assume Nero morg has lost interest. Posted the thread and now....disappeared!!! We have all put options out but no reply from the OP.........
Old December 16th, 2017, 13:07   #15
Mongler98
20% of most thread here are communication with OP's. 80% is the rest of us talking about, learning, comparing, and arguing! I would say that 99% of the posters who ask, "How do i more power" are not the ones who are active on this site enough to hear back from them. Most of them are "How do i roll coal" and other 16yo vdubber wannabee hipsters!
ALH Jetta intercooler upgrade options?? Speardog TDI Power Enhancements 18 January 13th, 2018 17:56
ALH Block upgrade options ??? JetPo TDI Power Enhancements 10 May 3rd, 2016 15:32
Upgrade options Joshthemedic TDI Power Enhancements 4 September 3rd, 2015 22:25
Upgrade options? evileltdude TDI 101 7 March 14th, 2012 20:17
02' NB ALH upgrade advice/options? The Shootist TDI Power Enhancements 1 September 23rd, 2008 22:39
Page generated in 0.16838 seconds with 10 queries
[Output: 124.67 Kb. compressed to 104.27 Kb. by saving 20.40 Kb. (16.36%)]
