Old December 6th, 2017, 00:27   #1
Boostedballs
Fuel Economy: 42-46mpg driving fast and hard
Question High speed left turn shudder and traction light
I think I might have a damaged speed sensor wire or wheel bearing somewhere. When I make a hard left turn at 70mph or so, the fuel seems to cut and the traction control light comes on, shudders for a second then goes away.
I havent had a chance to look at it yet and it doesnt happen but maybe once every day or two.
So how far would the reluctor on the hub have to move away from the sensor before it loses its signal?
Will the computer store a code that would point to one wheel?
Boostedballs is offline   Reply With Quote
Old December 6th, 2017, 04:48   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
If the ABS/ESP is working as designed, then no DTCs will be stored. The ABS just thinks there is a loss of signal on one of the wheels, and is responding appropriately.
Unfortunately, I assume for safety reasons, most of the ABS modules will not allow data viewing through the DLC over a certain speed, and that speed is typically very low (like 10 kph). So it isn't like you can just drive the car and watch the data with a laptop when it is happening, and see which of the four wheels drops out.
So, the only thing you CAN do is first do a good visual inspection with the wheels off the ground, and wiggle the wheels for any slop in any of the wheel bearings. Then, if you do not find anything obvious, take all the rotors off to access the wheel speed sensor tone rings. Chances are one of the rings is either cracked, full of debris, or in some cases the sensor itself has a broken tip.
You can also use a very high refresh rate scope to watch the signal generated from the sensors, but you may not be able to spin them fast enough to see anything.
oilhammer
www.cardocautomotive.com
Old December 6th, 2017, 08:20   #3
KLXD
He doesn't mention this happening during braking. Is wheel speed even monitored if brakes aren't applied?
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
Old December 6th, 2017, 08:52   #4
oilhammer
oilhammer's Avatar
You betcha! Monitored all the time. ESP works no matter the brakes' application or not.
oilhammer
Old December 6th, 2017, 09:33   #5
KLXD
I didn't know they had active braking in 03.
Learn something new every day. But that's why I'm here.
Old December 6th, 2017, 10:10   #6
oilhammer
oilhammer's Avatar
ESP was a rare option on late ALH cars, yes. It was still an option on BEW cars at least early on. Not sure when it became standard.
My otherwise stripper 2005 Beetle, with the base 2.0L gas engine, manual gearbox, no sunroof, steel wheels, no fog lamps, etc. had ESP. But it may have been standard by 2005 on that model.
oilhammer
Old December 6th, 2017, 17:25   #7
Boostedballs
I guess I’ll have to jack up the front end and have a good look around, then the rear if I find nothing in the front.
Old December 7th, 2017, 05:09   #8
oilhammer
oilhammer's Avatar
And just to clarify, a follow up to KLXD's question, your car does have ESP, correct? There is a button on the center stack?
oilhammer
Old December 7th, 2017, 06:10   #9
jokila
jokila's Avatar
Fuel Economy: 52/45/40
ESP is the only option I did not get on my 03 Jetta because of availability. I wished i had it as it probably would have helped me when I slipped off the road this past February. IIRC, it was only a $250 option.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old December 7th, 2017, 06:24   #10
oilhammer
oilhammer's Avatar
It does work pretty well. And it really doesn't add much more complexity to the car beyond the ABS, which was by then standard equipment. All gov't mandated now of course.
Normally I could do without that sort of nannyware, but I have to admit is DOES work, and there were a couple times in my Beetle that it intervened before I even realized there was a need for it to happen. Can't say for sure it would have prevented anything, but it certainly didn't hurt. I've never wrecked a car once, my wits (and my cars kept in good order) have served me well thus far.
The Sprinter's ESP is also tied into something called Crosswind Assist. And boy, that setup works awesome. I have had that come active on me a couple times already, and it is like the hand of God himself reached down and stuck the van to the pavement all of a sudden during a massive wind gust.
oilhammer
Old December 28th, 2017, 12:40   #11
Boostedballs
Not sure what you mean by “center stack.”
Anyway, I cleaned the iron filings off the front sensors and the issue is still there. I guess I’ll do the same for the rear sensors (assuming there are sensors back there)
Old December 28th, 2017, 13:00   #12
UhOh
UhOh's Avatar
"Center stack" would be the center console dash area (where your hazard switch and others are located).
Old December 29th, 2017, 07:16   #13
jokila
jokila's Avatar
On a Jetta the ESP switch is to the right of the left seat warmer switch. If you don't have it, it's a blank button. On the New Beetle it's located on a button to the left of the hazard lights switch.
Old January 3rd, 2018, 13:34   #14
Boostedballs
Ah, I do have an esp button. My phone usually covers it up.
I’ll take another high speed left turn with the system off to see how it responds.
Old January 16th, 2018, 17:25   #15
Boostedballs
Wow! I cleaned up the rear speed sensors, another easy job, and one of the sensors had some serious metal chips. I am astounded that the sensor worked in the first place. I have not driven the car yet to test it. I’ll try to test it tomorrow...
On-and off grinding on hard left and traction control light... richmondvatdi VW MKIV-A4 TDIs (VE and PD) 29 December 28th, 2015 20:58
Low Speed Lash, High Speed Shudder mike000 TDI Conversions 18 September 20th, 2013 08:49
Traction Control (ASR) Light with Shudder blued TDI 101 14 January 24th, 2011 12:56
Idle bobbing, high speed shudder? DorkusMalorcusTDI TDI 101 0 July 15th, 2009 13:22
High speed coasting shudder Dr. Dotgain VW MKIV-A4 TDIs (VE and PD) 13 April 4th, 2006 15:55
Page generated in 0.10256 seconds with 10 queries
[Output: 128.68 Kb. compressed to 107.23 Kb. by saving 21.46 Kb. (16.67%)]
