I have new battery, checked grounds under battery box, alternator checks good, fuses inside and under hood check good.
We got an intermittent battery light on a recent trip so I scanned and the only thing that looked related was the P1503. A couple of weeks later the car wouldn't go into gear at a traffic light and the dash warning lights were lit up like a christmas tree. Scanned again to find 30+ errors. With all the error codes the car still starts fine, alternator charging 14.4. It goes into gear but I haven't driven since towing home.
The way my wife described the breakdown I thought bad mechatronic but it appears there's low voltage everywhere. I have a Bentlely for my other tdi's but not for this one. I suppose it's time to start tracing wires. Anybody seen this before?
Thanks, Mike
Date: 2017-12-03 15:01
VIN:
Car: Volkswagen Jetta
Year: 2006
Body type: Saloon
Mileage: 323290 KM
00 Steering Angle Sender
01 Engine
System description: R4 1,9L EDC G000DG
Software number: 03G906016AC
Software version: 7551
Hardware number: 0281012239
Serial number: VWZ7Z0F3432623
Coding: 0050078
Trouble codes:
P161A - Glow plug cylinder 1 Open circuit
static
P161B - Glow plug cylinder 2 Open circuit
static
P0401 - Exhaust Gas Recirc.Flow Insufficient Detected
Intermittent
P1503 - Load signal terminal DF of Generator Implausible signal
static
P2015 - Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance
Intermittent
P0102 - Mass or Volume Air Flow Circ. Low Input
static
02 Transmission
System description: GSG DSG 070
Software number: 02E300043
Software version: 1126
Hardware number: 02E927770AE
Hardware version: C30
Serial number: 00000601100069
Coding: 0000020
Trouble codes:
00446 - Function limitation due to insufficient voltage
Intermittent
P1850 - Databus drivetrain Missing Message from Engine CM
Intermittent
03 Brakes
System description: ESP FRONT MK60
Software number: 1K0907379AA
Software version: 0102
Hardware number: 1K0907379AA
Coding: 0021122
Trouble codes:
01314 - Engine control module (ECM) Please read DTC
Intermittent
00668 - Vehicle voltage terminal 30 Lower limit not reached
Intermittent
01314 - Engine control module (ECM) No signal/communication
Intermittent
04 Steering Angle Sender
08 Air Conditioning
System description: Climatic PQ35 090
Software number: 1K0820047EC
Software version: 0505
Trouble codes:
00532 - Supply voltage Lower limit not reached
Intermittent
09 Central Electrics
System description: Bordnetz-SG H37
Software number: 3C0937049D
Software version: 1002
Hardware number: 3C0937049D
Hardware version: 063
Serial number: 00000000279098
Long coding: 14018E234004150000140000001400000008730B5C
Subsystems:
System description: Wischer VW350 013
Software number: 1K1955119C
Software version: 0402
Coding: 0063445
Trouble codes:
00446 - Function limitation due to insufficient voltage Lower limit not reached
Intermittent
0F Radio Tuner Digital
System description: SDAR XM H03
Software number: 8E0035593E
Software version: 0080
Hardware number: 8E0035593E *
Serial number: AUZ4Z7F7044106
Trouble codes:
Intermittent
Intermittent
02635 - Tuner not enabled/activated
static
15 Airbag
System description: 39 AIRBAG VW8R 032
Software number: 1K0909605P
Software version: 7900
Hardware number: 1K0909605P
Hardware version: 003
Serial number: 0038FD04JDJ8
Coding: 0013113
Subsystems:
System description: BF-Gewichtsens. 006
Software number: 1K0959339E
Software version: 0005
Trouble codes:
Intermittent
16 Steering Column Electronics
System description: J0527 034
Software number: 1K0953549AH
Software version: 0070
Hardware number: 1K0953549AH
Coding: 0010021
Trouble codes:
Intermittent
17 Dash Board
System description: KOMBIINSTRUMENT 3HL
Software number: 1K0920953D
Software version: 4312
Coding: 0023206
Trouble codes:
Intermittent
19 Gateway
System description: Gateway H10
Software number: 1K0907530F
Software version: 0120
Hardware number: 1K0907951
Serial number: 28001061080726
Long coding: 3F3F0B60071002
Trouble codes:
Intermittent
25 Immobilizer
System description: IMMO 3HL
Trouble codes:
No trouble codes found
42 Door Electronics Driver Side
System description: Tuer-SG 024
Software number: 1K0959701K
Software version: 2377
Coding: 0001269
Trouble codes:
01811 - Supply voltage for door control module, driver side Lower limit not reached
Intermittent
01552 - Driver door central locking LOCK motor Electrical malfunction in circuit
static
00928 - Lock unit for central locking Driver side Implausible signal
static
44 Steering Assistance
System description: EPS_ZFLS Kl.5 D04
Software number: 1K1909144J
Software version: 1606
Trouble codes:
Intermittent
Intermittent
00778 - Steering angle sensor
static
46 Central Module Comfort System
System description: KSG
Software number: 1K0959433AF
Software version: 0401
Long coding: 137803281B09058F880F048051A0
Subsystems:
System description: Sounder n.mounted
System description: NGS n.mounted
System description: IRUE n.mounted
Trouble codes:
Intermittent
52 Door Electronics Passenger Side
Software number: 1K0959702K
Coding: 0001269
Trouble codes:
01812 - Supply voltage for door control module, frt. pass. side Lower limit not reached
Intermittent
56 Radio
System description: Radio DE2 011
Software number: 1K0035180C
Software version: 0015
Hardware number: 1K0035180C
Hardware version: 000
Serial number: VWZ4Z7F2110489
Coding: 0010400
Trouble codes:
00003 - Control module Faulty
static
62 Door Electronics Rear Left
System description: Tuer-SG 021
Software number: 1K0959703D
Software version: 2434
Coding: 0000144
Trouble codes:
01813 - Supply voltage for door control module, left rear Lower limit not reached
Intermittent
72 Door Electronics Rear Right
Software number: 1K0959704D
Coding: 0000144
Trouble codes:
01814 - Supply voltage for door control module, right rear Lower limit not reached
Intermittent
00935 - Right rear window lift motor no or incorrect basic setting/adaptation
Intermittent
7D Auxiliary Heater
System description: PTC-Element
Software number: 1K0963235E
Software version: 0404
Hardware number: 1K0963235E
Trouble codes:
00361 - Heater element for aux. heater Faulty
static
Thanks, Mike
VIN:
Year: 2006
Body type: Saloon
Mileage: 323290 KM
01 Engine
Coding: 0050078
Trouble codes:
static
static
Intermittent
static
Intermittent
static
02 Transmission
Coding: 0000020
Trouble codes:
Intermittent
Intermittent
03 Brakes
Coding: 0021122
Trouble codes:
Intermittent
Intermittent
Intermittent
08 Air Conditioning
Trouble codes:
Intermittent
Subsystems:
Coding: 0063445
Trouble codes:
Intermittent
Trouble codes:
Intermittent
Intermittent
static
15 Airbag
Coding: 0013113
Subsystems:
Trouble codes:
Intermittent
Coding: 0010021
Trouble codes:
Intermittent
17 Dash Board
Coding: 0023206
Trouble codes:
Intermittent
19 Gateway
Trouble codes:
Intermittent
25 Immobilizer
Trouble codes:
Coding: 0001269
Trouble codes:
Intermittent
static
static
Trouble codes:
Intermittent
Intermittent
static
Subsystems:
Trouble codes:
Intermittent
Coding: 0001269
Trouble codes:
Intermittent
56 Radio
Coding: 0010400
Trouble codes:
static
Coding: 0000144
Trouble codes:
Intermittent
Coding: 0000144
Trouble codes:
Intermittent
Intermittent
7D Auxiliary Heater
Trouble codes:
static
