Old December 11th, 2017, 23:34   #16
shakescreek
X3 on the Hengst.
shakescreek is offline   Reply With Quote
Old December 17th, 2017, 08:10   #17
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
For oil, I use Mann in my VeeDubs, Always manage to get them on deal to, more available then Hengst. For my Jeep GC CRD, was NAPA gold, made in Poland. But Just got a Mahle for under $4, made in Austria. Fuel Filters I use Mahle for VWs, best price,also made in Austri, under $14 although I did get a Mann from IdParts $10 on clearance, had to order little gaskets separate at another time. Jeep I use Hengst. Get for $20, much cheaper than Mann and others. Air, I use Mann.
2003 Jetta GLS TDi TTbushings
2005 Passat GLS TDI Wagon Stone Henge Gray
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old December 18th, 2017, 06:15   #18
740GLE
Picked up 5 Mahle filters for the Alltrack made in Austria as well, it uses an O-Ring type seal around the center rod, where the factory filter which I'm guessing is mann, uses the filter media fused sealed end.
Either way in hind sight I could have picked up 6 pack of mann for the same price from Amazon I ordered 5 mahle filters from Autozone, but oh well.
Old December 19th, 2017, 08:10   #19
thundershorts
NAPA gold oil filter for b5 is made in Poland.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old December 19th, 2017, 19:45   #20
boertje
boertje's Avatar
X4, it’s Hengst for me as well on both ALH and BEW.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old December 19th, 2017, 20:25   #21
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
What defines "good" in an oil filter here?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old December 20th, 2017, 13:39   #22
hskrdu
Originally Posted by phaser View Post
I've been using Hengst for years.
I've been looking for that thread showing the number of pleats but haven't found, it yet.
This is one of the pleat comparison threads from years ago, but it's a Bosch vs Mahle comparison:
http://forums.tdiclub.com/showthread...95#post2529995
Now: 03 Golf GLS TDI 5SPD & (hers) 03 Jetta GLS TDI 5SPD
Then: 99 Jetta GLS TDI, 94 Golf GL, 85 Golf GL, 85 Golf, 79 Rabbit C, 68 Beetle, 65 Beetle
hskrdu is offline   Reply With Quote
Old December 20th, 2017, 14:11   #23
FWIW all of the brands mentioned above have facilities in China. And as far as we can tell Hengst doen't make many of their own products for Euro brands.
Mann just recently purchased Wix. I don't know if they repackage Mann filters for Euro applications: we plan to continue to purchase Mann for VWs, and will add Wix products for domestic diesels. They seem to have a good reputation in that market.
Purolator tends to identify spin-on filters that are "close enough" for the stated application. Given a choice I'd pick Mann over Purolator. Mann also owns Purolator.
Old December 20th, 2017, 14:30   #24
phaser
Fuel Economy: 50 MPG B-20
At least the 20 Hengst filters (E154H D4) I have on the shelf are each labeled "Made In Germany".
I don't know if they still are.
2004 Jetta BEW 5M - 490k - 50 mpg / Fuel B-20 / Fuel Filter - Cat IR-0750 /
Oil Filter - Hengst / Oil - Schaeffer Supreme 9000 5W-40 /
Bypass Filter EaBP100 /
Air Filter - EaA208
/ Transmission Oil - VW G50
phaser is offline   Reply With Quote
Old December 20th, 2017, 15:39   #25
Yes, but by whom? Re-boxing filters from other manufacturers is pretty common, and Hengst seems to do this more than other brands.
Old December 20th, 2017, 18:38   #26
BKmetz
Administrator, Member #10
BKmetz's Avatar
Just a FYI: Bosch does not make its oil filters. Bosch contracts the oil filters out to someone else. Bosch used to use Champion but AFAIK, Bosch now uses Purolator.
As an aside, Bosch does make its own fuel filters.
Brian, 2015 Passat SE TDI 6MT
Kathy, 2014 Passat SE 2.5
Chris, 2015 Passat SEL TDI
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old December 20th, 2017, 18:49   #27
phaser
From Hengst website:
"The particularly high vertical integration is what distinguishes Hengst from our competitors. From the preparation and refinement of the filter medium up to the plastic housing and the pressure cast component, everything is manufactured by Hengst."
https://www.hengst.com/en/filtration...tion-spectrum/
Air Filter - EaA208
Old December 23rd, 2017, 09:54   #28
diesel steve
TDI(s): 1996 b4v
Fuel Economy: 50 mpg city/highway
A lot of interesting comments about filters. No one mentioned the Hastings LF517 or Fleetguard LF3451 or Donaldson P557780. I use to use the Purolator filter but have read some things that it used to be a good filter but it is made different now and not recommended. I have read that there are only a few factories that make filters and brands like Amsoil,Royal Purple and Mobil 1 are made by other companies to their specs. 100% synthetic are supposed to be the best for extended oil change intervals but there are very few filters made for this application that are. I change my oil every 10,000 miles and use the Rotela 5w-40 synthetic. I have not heard about the Hengst or Mahle brands. A lot of comments about these two brands and many seem to recommend them. What about the brands I have mentioned?
diesel steve is offline   Reply With Quote
Old December 31st, 2017, 05:19   #29
AndyBees
AndyBees's Avatar
Considering that the original VW engines from the 25 hp to 36 to 40, etc., seemed to survive without an oil filter, I think about any brand is sufficient to handle the intended purpose. Keep the oil level at spec and change everything per spec and drive on! Surely at 370k miles, my ol' 2000 will make it to 500k.
Anyway, Mann is my choice when purchasing on-line. Locally, I buy Purolator filters.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old December 31st, 2017, 06:27   #30
James & Son
TDI(s): 2006 Jetta
Those with a PD engine can still get the originally supplied zig zag filter which is good for 2 oil changes or 30,000 kilometers. It is still available at the dealer and is sold for the v-6 passat. Part number 070 115 562 made in France.
Edit: My mistake, According to ID Parts (which only sell the Mann straight pleat): Oil filter for Volkswagen Jetta TDI on the A5 chassis as well as the MkVI Golf TDI. This oil filter will fit the 2005-2006 Jetta TDI with the BRM engine as well as the new 2009+ VW Clean Diesel TDI, 2.0L, engine codes CBEA and CJAA
James & Son is offline   Reply With Quote
Larger Oil Cooler and Remote Oil Dual Oil Filter with By-pass Filter G60ING VW MKIII-A3/B4 TDIs 24 December 5th, 2017 15:33
Air Filter Quality vs. DPF Lifespan TurboDieselPoint TDI (Diesel) Emissions 2 March 18th, 2014 15:57
Best quality oil filter D-Roc TDI 101 26 November 18th, 2007 19:09
filter quality? elnigel VW MKIV-A4 TDIs (VE and PD) 5 October 27th, 2002 09:47
Quality of Fuel & Oil Help Intake System Stay Cleaner Than Low-Quality Lubes Turbo Steve Fuels & Lubricants 18 January 10th, 2001 16:31
Page generated in 0.15598 seconds with 10 queries
[Output: 134.96 Kb. compressed to 113.48 Kb. by saving 21.48 Kb. (15.92%)]
