Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old December 11th, 2017, 05:28   #16
Intech
Fuel Economy: 03' Jetta 67.1 best 51 avg. 99.5 Golf 46 Avg.
Originally Posted by jerrymander View Post
With my stick, I get about 40 mpg with my idiot computer saying 46. I also have a one inch lift and 235 width tires. Rolling resistance and aerodynamic drag are killer.
I have to agree with you on rolling resistance. When I first went to Nokian WRG3s, I was told that they were the same as the G2s. No way!!. With the G3s, which were heavily advertised as a very low roiling resistance, my MPGs jumped about 5 mpg. At first I found that hard to believe, but it was a fact. I went from mid to upper 50s to low to mid 60s. When I went back to the Bridgestones, it went back down about 5 mpgs. I gave the Nokians with more than half tread on them to a friend of mine, and his mpgs jumped about the same as mine did, and the only factor was rolling resistance
A gun is like a parachute, if you need one and don't have one, you'll probably never need one again
Intech is offline   Reply With Quote
Old December 11th, 2017, 05:39   #17
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Better MPG is always a good thing.
Question please. Noise, stopping distance, and & a comfortable ride is my personal preferences.
Did those tires sacrifice some (or a lot) in those area?
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old December 11th, 2017, 06:52   #18
Intech
Those tires were the most comfortable tires that I ever had, also no noise at all. Very soft sidewalls. Stopping distance was horrible, especially in the rain, one of the main reasons I got rid of them. Also, handling was squirrely, with the soft sidewalls, the car leaned, but the tires stuck. I also had to run almost 38 psi, to get some decent performance out of them
Old December 11th, 2017, 09:03   #19
2015vwgolfdiesel
..... much thanks
Old January 15th, 2018, 23:07   #20
[486]
TDI(s): 02 golf ALH
remote start is generally bad with any diesel
Dunno if they've solved the wet stacking issue with the later emissions package.
I'd imagine they very well could if they put their minds to it, being able to make nice toasty 1200 degree EGTs at idle.
[486] is offline   Reply With Quote
Old January 29th, 2018, 09:50   #21
1.9TDI60MPG
TDI(s): 2006 1.9 TDI
Fuel Economy: 39 MPG Hard Ripping
Default 35 MPG Ripping Hard
I get around 35 MPG if I drive her like I stole it all the time. Car does get around 5 hours of idle time on a tank so that makes it worse too....Standard 5 speed(2006 PD engine)
1.9TDI60MPG is offline   Reply With Quote
Old February 7th, 2018, 03:58   #22
2015vwgolfdiesel
Originally Posted by 740GLE View Post
6MT will always win over the DSG, there is parasitic loss of the DSG, clutch pressure is hudralic, there's circulating pumps for fluid and cooling. Also up until 2015, the gearing of the DSG was much shorter than the 6MT, think 200 extra RPMs at 65 vs the 6MT.
The '15's DSG are stupid tall though, 2000 RPMS at 75mph tall, not sure how that stacks up against the '15 6MT.
M6 at 75 MPH compared to DSG at 65 MPH is a joke
See my signature. With the FIX money and all dealership and VW discounts, my bases in a new 2015 DSG TDi Golf is a tiny $12,495
MSRP = $24,895
My car is original, and will have a 162,000 mile 11 year transferable warranty.
After one pays hundreds (or thousands) of dollars for MODs, then looks at the much better FE results .... well you see the point.
For the record, I spend (approx) 39 cents per day on diesel. Save all fuel tickets
Her (2015 2015 Toyota RAV4 LIMITED) is (approx) $1.13 daily, (no ethanol) gas.
Old February 10th, 2018, 17:21   #23
tjpeterson96
tjpeterson96's Avatar
TDI(s): 04 bew jetta
i always get between 500-600 on a vented tank with my tuned 04 auto BEW. 50/50 highway and city. and i like to floor it alot i always keep the tires at 40 psi and i always get better MPG in the winter due to not using the A/C. I guess we don't get winter blend fuels here in central Fl
2004 Jetta BEW: pd150 TIP, pd150 Intake manifold w/ 57mm EGR delete, DSG R32 airbox, MAF, and snorkel, Darkside pd130 FMIC, Buzzken 3in DP with custom side exit, stock turbo... for now
tjpeterson96 is offline   Reply With Quote
Old February 20th, 2018, 06:52   #24
One of my co-workers worked at a VW dealer for the past few years and says remote start is a bad idea on any current TDI. It's complex, expensive, and prone to issues. As posted above, these cars warm up (or cool off) pretty quickly anyway.
Regarding manual versus automatic, there is a long running debate here on whether or not there's really a penalty for DSG versus manual. What I've gleaned from many posts is that if you drive a lot of highway miles the difference is negligible. If you're driving in the city or traffic, there can be a significant FE penalty for the DSG.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old February 20th, 2018, 08:11   #25
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
I learned to drive on a 3 on the tree shifter. I've had nothing but manuals for some time until my first auto.
As far as I'm concerned not having to be constantly clutching and rowing the gears makes an auto my choice!
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Cruze Diesel is rated at 52 mpg highway in stick version, 37 mpg combined JM Popaleetus Non VW Group Diesels 249 March 10th, 2017 13:16
TDI Stick to Auto MPG estimates...need advice.. shooter66 TDI Fuel Economy 16 July 20th, 2008 09:59
auto or stick??? Jack_Berry General VW Discussion 4 November 2nd, 2006 00:25
MPG auto/stick "newbie asks" BMWRich58 TDI 101 17 August 20th, 2004 17:11
Auto to stick will360655 VW MKIV-A4 TDIs (VE and PD) 6 November 6th, 2002 09:30
Page generated in 0.15845 seconds with 10 queries
[Output: 107.38 Kb. compressed to 91.98 Kb. by saving 15.39 Kb. (14.34%)]
