Old November 20th, 2017, 13:32   #16
Mythdoc
Mythdoc's Avatar
The only way this will be scientific is to pre fix test and then post fix same car on a dyno. Second best: someone who keeps hand calculated records, look up what they got under similar driving conditions for 5 tanks last winter vs 5 tanks now.
“Yeah, well, y’know, that’s just like, uh... your OPINION, man.” —The Dude
2015 Q5 TDI w/ Chipwerke tuner, 30K Miles
2011 Touareg TDI 74K Miles (sold back to VW, May, 2018)
2015 Golf TDI 22K Miles (son’s)
Mythdoc is offline   Reply With Quote
Old November 20th, 2017, 14:45   #17
nayr
nayr's Avatar
TDI(s): 2014 Audi Q7
When I went in to get emissions tested I choose a facility that offered dyno print out for a little extra money.. unfortunately their printer was broken and they wouldent sell it to me.
Ive got every fuel receipt since I owned it, for the last 10k miles.. but it would be nice to get graphs of the original tune, the fixed tune, then my fixed-fix stage 2 tune.. but thats not gonna be cheap to get :\
Might record some 0-60 runs in Drive and Sport just too compare what they did to the shift points.. I can do that for free.
2014 Audi Q7 Prestige, Air Suspension, 30in BFG All Terrains on 17in Wheels - #dieselgate upgrade
2013 Golf 6MT 5 Door, Tech Pkg, Malone Stg2, Westfallia Hitch, Frost Heater, Escort Passport, Tow Bags, Runflats - (RIP: March 2013 - April 2017)
1975 Westfallia 4MT - ALH Conversion in progress.
nayr is offline   Reply With Quote
Old November 29th, 2017, 18:06   #18
bloc
Got mine done a couple days ago. Same off the line, feels WAY flatter in midrange and higher RPM.
More "diesel clatter" in certain conditions.. definitely less downshifting/engine braking than before.
The battle between extended warranty and stage 1 or 2 malone is tipping toward malone...
2013 Touareg TDI
bloc is offline   Reply With Quote
Old November 30th, 2017, 03:57   #19
KDAWG97M3
TDI(s): Q7
I had mine done in early early nov......no issues so far, knock on wood....
KDAWG97M3 is offline   Reply With Quote
Old December 3rd, 2017, 09:32   #20
dyehead
My 2013 Q7 feels like a lesser car now for sure. You can’t feather the gas and have any effect, merging into traffic feels way more dangerous because the timing is way worse. I have to basically drive it in sport mode when merging or changing lanes or risk an accident. Feels like it will refuse to downshift unless you press down hard, and then when it does it drops you multiple gears.
dyehead is offline   Reply With Quote
Old December 4th, 2017, 17:02   #21
bloc
Yeah, i'm not happy with the big flat spot on the lesser half of throttle pedal travel.
Taking a right turn from one road onto another I dip into the throttle expecting it to go somewhere and it just sits there until I stomp on it.
I'm thinking the idea of a tune is gaining some traction in my head.
2013 Touareg TDI
Old December 4th, 2017, 18:29   #22
Twohorses
Default Reduced power, reduced MPG and terrible engine sound, no fun to drive anymore
Just got my 2014 Touareg TDi fixed at dealer. Driven 2 weeks now post modification. Contrary to VW claim, I can say with certainty that 1) the car lost a lot more than 1 MPG. I am seeing mpg value as low as 18.5 which never happened in my pre -mod 27,000 miles of driving under any condition. I was getting 31-32 on highways pre-mod. Will find out later how much MPG loss in highway condition. 2) there is significant loss of accelerations power. This was one of the character I like the most. 3) the engine sound noisier all the time with a completely different feel when driving. My conclusion, I am getting a much worse different car after VW modifying it. I believe VW deliberately understated the changes resulted from the emission modification.
I was not angry when VW was first caught cheating. I am much angrier now realizing that they decided to cheat their consumers out the second time and our government appears to be helping them rather than us.
Twohorses is offline   Reply With Quote
Old December 5th, 2017, 14:51   #23
bloc
Until you document miles driven against fuel you actually pump into the tank you can't claim a mileage hit post-fix. The car's calculation of mileage is notoriously inaccurate, and may be more-so with VW having been mandated to change operational parameters of the engine, but not being required to make the MFI accurate.
Also, mileage MAY increase as the vehicle learns and adjusts certain values.
I'm not saying people's mileage didn't drop.. I'm saying going by the MFI is not an accurate way to support that argument.
2013 Touareg TDI
Old December 6th, 2017, 10:33   #24
bird67
bird67's Avatar
Truly not trying to be antagonistic here. I get that calculating MPG by taking odometer reading and dividing by fuel burned is a more accurate determinant of MPG. I also get that comparing pre-"fix" calculations by hand with post-fix MFI readings tells little about relative MPG pre- vs. post-"fix." But what I don't get is why comparing pre-"fix" MFI readings with post-"fix" MFI readings isn't a valid indicator of whether the "fix" has adversely affected MPG.
So long as it's an apples-to-apples comparison, why isn't comparing pre- vs post-"fix" MFI readings a reliable way to see if your TDI is less fuel-efficient post-"fix"? For example - if I got 28 MPG on my MFI pre-"fix" and now get 24 MPG on my MFI post-"fix", why can't I draw the conclusion that the "fix" hurt fuel efficiency? My MFI MPG was consistent pre-"fix" at about 1 MPG over hand calculation, and since it was consistently the same 1 MPG off, time after time, I don't consider it "notoriously inaccurate."
Again, not trolling for a fight. I just don't understand why comparing apples-to-apples is invalid.
Avatar: Touareg TDI during its emissions testing "perp walk" of shame.
bird67 is offline   Reply With Quote
Old December 6th, 2017, 12:57   #25
Mythdoc
Mythdoc's Avatar
First, because of small sample size. How many tanks did it take to arrive at an MFI pre fix? How many tanks post fix?
With the small sample, you have all sorts of variables: diesel blend and quality, route, traffic, headwind, who knows? My Touareg showed up to a 15% variation in MPG from one tank to another on I-75 trips back in the day. One time I had a 31.5 mpg tank but typically it was 26-28. I would stop at the same pumps but in different season and in different weather. The 31.5 tank was when there was a stiff south westerly wind literally blowing me all the way from Virginia to New Hampshire. I hand calculated everything and was totally perfectionist about filling the tank exactly the same amount every time, zeroing out and record keeping. If hand calculating showed this much spread, the MFI will show even a bit more.
Old December 6th, 2017, 21:09   #26
nayr
nayr's Avatar
Because its well known that getting an aftermarket tune borks the MFI and it needs re-calibrated afterwords.. When my 2.0L got tuned the MFI went from being pretty accurate compared to hand calculations to far off from hand calculations..
If MFI thinks that injectors firing so many times == so much fuel, and then they tweak how long injectors are open or the pressure of the fuel then suddenly the MFI's calculations are nonsense until manually adjusted to compensate.. it could think its using more fuel than it actually is pretty easily with the fix in place..
also calculating it by the tank averages it out better, the long average on MFI isint that far out.. for example, if you just had a regen its usually not that accurate either.
Old December 7th, 2017, 11:16   #27
bloc
Others brought up good points but I had one big point to add.
We don't know exactly how fuel economy is calculated, and whether anything about those calculations changed with the fix.
Yes, I get that you can calculate fuel use over distance, but there is no direct measurement of injected fuel volume. There are calculations based on measured fuel pressure, injector open duration, and an offset entered into the ECU to tell it exactly how much each injector flows (the fact that this changes over time isn't relevant to this conversation, but is to overall reported MFI on a high-mileage vehicle).
Even then, does it compare calculated fuel use per hour, then adjust that by MPH to get MPG? Does it calculate fuel usage over a 100yd distance? 1/4mile?
Ultimately there is a lot we don't know about the inner workings of the ECU, as well as what exactly the fix did. We don't know whether some element of the fix could have impacted the way the ECU does FE calculations for the MFI.
Basically, there are too many unknown variables. Until you compare actual fuel pumped vs actual odometer change it isn't a valid comparison. Even the difference in how one fuel pump shuts off vs another or the tendency of the fuel to foam or not can impact this measurement, but as long as the fuel pumps are calibrated this will average out pretty quickly over a few tanks.
That said, I'm on my first tank post-fix and with 1/4 left it sure seems like I'll get significantly less miles out of it. But, I'll calculate MPG for this tank and a couple more (to allow for adaptation within the ECU to the way I drive) before drawing a conclusion.
My gut is telling me that I lost significant FE. I'll wait to complain about it until I have hard numbers.
2013 Touareg TDI
Old December 7th, 2017, 12:58   #28
bodhisattvah
bodhisattvah's Avatar
Fuel Economy: 50mpg cty/55mpg hwy/67mpg personal best
Nobody's pulling raw data from Torque?
bodhisattvah is offline   Reply With Quote
Old December 7th, 2017, 14:34   #29
bhuizer
Does anyone else notice their engine warms up much faster than before? I don't have a complaint about this, but I do worry about how they are doing it. One can only assume that they are doing significantly more EGR than before to get everything up to temp. Not a big deal, but too much EGR is hard on an engine and is also bad for engine oil quality. If I plan to keep this Touareg a while, I'm wondering if this is going to be detrimental to the longevity of the engine. Granted it's all under warranty now, but not in a few years when I'm over 120k and VW is no longer taking care of the bill.
bhuizer is offline   Reply With Quote
Old December 7th, 2017, 14:55   #30
nayr
nayr's Avatar
the cold start idle is higher and it shifts later when cold, in my Golf I got an aftermarket tune that provided the dynamic idle and it reduced warm up time significantly.
they coulda mucked with the EGR too, but its not ALL to blame on the EGR.
2014 Q7 TDI - #dieselgate upgrade nayr Audi SUVs (Q7 & Q5) and other V6 TDIs 15 August 11th, 2018 15:25
2.0 Gen 1 Modification Completed-Results Keith63 Dieselgate - VW Group Emission Scandal 55 October 29th, 2017 07:47
Bad time to buy 2014+ Q7 TDI? Smashed Ixnay Audi SUVs (Q7 & Q5) and other V6 TDIs 34 February 16th, 2017 06:40
Q7 Tdi performance upgrade suggestions? Rx Burner TDI Power Enhancements 15 April 5th, 2015 17:45
Golf TDI 2014 7th Gen BryanK Ontario 7 September 21st, 2013 18:59
Page generated in 0.16237 seconds with 10 queries
[Output: 136.15 Kb. compressed to 114.31 Kb. by saving 21.85 Kb. (16.05%)]
