Old November 1st, 2017, 14:57   #1
KidFromAkron
TDI(s): 2010 jetta
Default New tune, new problems
I installed the Malone tuning stage 2 on my 2010 jetta cr tdi six days ago. The car has seen regular scheduled maintenance by the dealer that I bought it from and has only 78,000 miles. While driving in normal stop and go traffic my glow plug light came on and started flashing. Car drove fine for the three miles till home then the check engine light came on just before killing the motor. The motor shuddered to a stop a little rough as well. Restarted and both lights still on. No limp mode as of yet. I called a local euro car specialist and he's going to scan it tomorrow morning. Anyone else see this with their new malone tune? Btw I'm new here and new to the upgrade world (at least on my dIesel).
KidFromAkron is offline   Reply With Quote
Old November 1st, 2017, 18:56   #2
travis45
travis45's Avatar
I'm going to go out on a limb and say your tune had nothing to do with it and your hpfp just took a sh!t.
Open up your fuel filter and look for metal shavings in the bottom.
You need to scan with VCDS to see what codes come up.
14 Sportwagen GTB2260vklr Turbo, Rawtek turbo back exhaust, Malone custom tune, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Neuspeed rse14 Wheels, Fluidamper Crank Pulley, KW V3 Coilovers, H&R 22mm rear sway bar, PolarFIS, Darkside intercooler and piping, Wavetrac LSD, Brembo 18z calipers w/drilled rotors. Soon to install Colt billet stage 3 cams w/upgraded springs, ARP Headstuds and IE connecting rods.
travis45 is online now   Reply With Quote
Old November 1st, 2017, 18:58   #3
travis45
travis45's Avatar
If it is the hpfp the preferred fix is to upgrade to a CP3 pump.
Old November 1st, 2017, 20:10   #4
KidFromAkron
TDI(s): 2010 jetta
I thought that maybe the sensors had a tendency to take a dump from the changes. Just spitballing. Guess I'll find out tomorrow. Thanks for the reply.
Old November 1st, 2017, 20:13   #5
travis45
travis45's Avatar
Check fuel filter housing. Scan for codes.
Old November 4th, 2017, 09:19   #6
travis45
travis45's Avatar
Any luck? What did you find out?
Old November 6th, 2017, 11:58   #7
KidFromAkron
TDI(s): 2010 jetta
Scan showed intermittent TPS issue. By the time I took it to the shop the lights were out. they said bring it back if it starts again. There was no more rough stops when turning off the key but of course lights came back on and the rough stops are back. I'm assuming the problem is at the motor and not the throttle position sensor in the go pedal based on the rough stops. I'm almost due for my 80k mile service. I'll probably have it taken care of then. Any other suggestions?
Old November 29th, 2017, 09:51   #9
KidFromAkron
TDI(s): 2010 jetta
So after taking some time to decide how to best spend my money I finally broke down and took my car to a non-dealer vw specialist to get a definitive diagnosis. I was torn initially on whether to just spend the $200 and get a VAG-COM and then just do the work myself (if I can) or go to a specialist and have them use their diagnostics and willingly pay the mark up.
Basically for $55 the shop diagnosed what I suspected: I need to replace the EGR valve air regulator flap.
I plan on doing the work myself because in my research I've found that this fix seems well within my wheel house seeing as how I know lefty looses righty tightey. In researching the actual part I found dap.com to have the oem part for $360 and ECS tuning had it for $357 which was from continental. A few key strokes later I found the same serial number continental part on amazon for $253 with free shipping. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
With the money I save in part mark up and labor I plan on buying the ross tech VAG-COM to use later as I plan on getting at least another 200k miles out of my Jetta.
I'll post pics and updates of the work once the part comes in. Thanks again for following and helping with great input!
Old November 29th, 2017, 10:50   #10
Nevada_TDI
Glad to hear you found a resolution, and as most here will say, "...If you own a VW you also need to own VCDS..." Or have a good relationship with someone that lives or works nearby where you live.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old November 29th, 2017, 10:53   #11
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Methinks the problem is not with one of the two EGR systems.
oilhammer
www.cardocautomotive.com
Old December 1st, 2017, 17:29   #12
KidFromAkron
TDI(s): 2010 jetta
Any thoughts on what it is Oilhammer?
Old December 1st, 2017, 19:13   #13
scrambld
What does Oilhammer charge for internet diagnostics?
scrambld is offline   Reply With Quote
Old December 3rd, 2017, 19:59   #14
KidFromAkron
TDI(s): 2010 jetta
Guess he gave what I paid.
Old December 4th, 2017, 03:59   #15
oilhammer
oilhammer's Avatar
I would ask the tuner what mods were done to the EGR systems and see if they have any insight.
oilhammer
2013 golf apr stage 1 tune problems vedubbmk6 TDI Power Enhancements 31 September 22nd, 2014 09:37
17/22 tune Problems Flutter, bark on BEW STILL! hiepriest TDI Power Enhancements 53 August 28th, 2013 18:29
High altitude problems after injector upgrade / tune Flimzy TDI Power Enhancements 0 October 15th, 2012 12:51
TDI Stuttering Problems after tune up vwjettatdigirl VW MKIV-A4 TDIs (VE and PD) 4 August 16th, 2009 16:11
Page generated in 0.16297 seconds with 10 queries
[Output: 126.86 Kb. compressed to 105.34 Kb. by saving 21.52 Kb. (16.96%)]
