Old November 1st, 2017, 03:52   #1
Edd209
TDI(s): Mk3 Golf TDI
Default How to make an AHF go faster!
Hi all.
I'm new to the forum, so go easy haha.
I've just started reconditioning an AHF engine and would like to know what to put on the shopping list to get 200bhp out of it.
Edd209 is offline   Reply With Quote
Old November 2nd, 2017, 12:30   #2
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
GTD1752VRK turbo, .280 nozzles, 3 bar MAP sensor, re-map, (optional) cam.
Old November 2nd, 2017, 13:50   #3
Edd209
Thanks for the reply!
GTD1752VRK looks lush but it's abit out of my price range. I was thinking along the lines of hybridising a pd130 turbo, would that be any good?
As for the cam, can recommend one?
Old November 3rd, 2017, 10:40   #4
mk1-83
Fuel Economy: 1:15
Go for the gt1749vb from 150 pd turbo .280 nozzles im selling new ones
And dont forget a upgrade sachs clutch to hold the nm.
And a good fmic. 3 bar map and good tune
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old November 3rd, 2017, 11:20   #5
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I would always choose a newer generation turbo where possible. GTD > GTC > GTB > GTA > GT. For excellent spool, GTC1549VZ (very cheap in the UK); else GTB1752V (found in the 174 HP R5 TDI.
IMO going to a GTx20V frame size sacrifices more low-rev response than I'd personally like but will become necessary past say 230 HP.
For the cam, I'm biased toward NPS's, else Dbilas 240/250, keep it mild if you're not doing any head porting. Can't speak for Newman and Piper but some like them and they are both in the UK. If you have more fabrication/customisation skills than money, you could adapt a petrol 2.0 Mk3 ABA (048 109 101D) or 050 109 101 A cam.
http://forums.tdiclub.com/showthread.php?t=210553
Edit: @mk1-83: If you're selling more than your private holdings, you need to register as a vendor.
Old November 3rd, 2017, 11:56   #6
cruiserboy
I had an AFN engine VP110 with GTB1752VL from Renault Master 2.5 dCi with 0.280 DSSr nozzles and 11mm pump and it was already a really interesting little beast on the road
cruiserboy is offline   Reply With Quote
Old November 14th, 2017, 14:23   #7
Edd209
Hi guys, thanks for the info!
So - I picked up a GTB1752V for a good price and was thinking it'll need a custom manifold, is that right?
Also went for Darkside Developments cams and lifters, and have a set of .280 nozzles on order.
A couple more questions, if I may..
a) I'm going to keep the mk4 golf gearbox that came with the engine, any recommendations for an uprated clutch?
b) Do waste gates and/or dump valves work on TDIs?
Thanks for all your input, really appreciate it.
Old November 14th, 2017, 15:33   #8
Edd209
Also - which models have 11mm fuel pumps and are they plug and play? Or do I need to change other bits to get one in and working?
Old November 15th, 2017, 15:36   #9
QuickTD
Anybody that says big turbos are bad hasn't tried one.
QuickTD is offline   Reply With Quote
Old December 27th, 2017, 11:00   #10
gmo
you wanting to keep dmf or go smf mate and no dump valves are best left on petrols darkside sell all you need if on budget when you get mapped dont have it to aggressive and keep torque to 3oolbs max you should be ok on stock clutch .. it is the 6 speed box with 240mm clutch right?
gmo is offline   Reply With Quote
Old December 27th, 2017, 12:44   #11
Edd209
Hey GMO, cheers for your reply.
Plan is to keep the mk4 gearbox and put it in with a Vr clutch.
What do mean by dmf or smf?
Planning to get a custom rolling road map so I can get a good balance between power and economy.
Know any about headbolts? I've read that they need uprating if the power goes past 150hp?
Old January 3rd, 2018, 01:39   #12
DkZ
Fuel Economy: 7.5 / 6 / 4.5
For your knowledge:
DMF: dual mass flywheel
SMF: single mass flywheel
DkZ is offline   Reply With Quote
Old January 3rd, 2018, 08:36   #13
Edd209
Haha, cheers man. I do know that really, just being dim 😂
Make me faster vets soldieroverseas TDI Power Enhancements 8 June 3rd, 2013 18:09
How do you make a TDI rev faster? Mikkijayne TDI Power Enhancements 21 January 20th, 2008 15:45
I want to make my TDi faster brianteel VW MKIV-A4 TDIs (VE and PD) 4 April 22nd, 2005 18:17
how do i make my car faster without spending $ OneLostprophet TDI 101 50 September 9th, 2004 06:50
Make my TDI faster! SanjMan TDI Power Enhancements 16 October 16th, 2001 04:22
Page generated in 0.17269 seconds with 10 queries
[Output: 111.87 Kb. compressed to 93.90 Kb. by saving 17.97 Kb. (16.06%)]
