Old November 8th, 2017, 06:19   #16
a57oval
Zornigvw,
You mentioned that this seems to be a common issue: Do you know of other people that have had this issue?
Does your Valeo vibrate just on speed 4? Do you have an OEM resistor or an aftermarket one? Did you purchase your Valeo from IDParts?
If you bought it from IDParts my hope is they just received a bad batch of heater blower motors and this is a limited issue.
Corey from IDParts is supposed to check into the issue and report back. I will update this thread when I hear from him.
Peter
a57oval is offline   Reply With Quote
Old March 7th, 2018, 13:49   #17
jbleu101
Fuel Economy: 43 Avg for mixed driving
Default Blower motor r&r thread
I'm glad to read this thread that it is an easy replacement. I'm going to look for an R&R thread as I have an parts car I can pull from. Hopeful the old resistor pack will work from it. My motor started to make weird noises, would quit after a minutes, I could turn it off and turn it on again to get a few more minutes of running, then it finally gave up the ghost. I'm hopeful I can solve my own problem. The only other thing of note is the AC compressor wire was apparently broken and I have to fix that as well, so it is getting no power. I don't normally run the AC in the ON position when running the heater in the winter time, so I'm hoping these items are exclusive to each other.
Thoughts. Sorry to highjack
2002 Reflex Silver Jetta
SoyLect B20 + 80% BP Supreme
Amsoil HDD 3000 5w-30 Annually = 20K
Rocketchip Stage II
Garrett VNT-17
Bosch T4 Transporter Injectors
VR 6 Clutch 18# flywheel
5 Speed, Cold Weather Package, TDI Heater
OEM Steel Skidplate, Audi TT front anti-sway bar
ON CCV, ON SS Filler Cap (MIA)
Vented, Coolant Migration Mod
50% Front, 38% Rear tint (OH Legal)
Euro Switch, Rear Fogs
GTI 25th AE headlights w/leveling
157,000 Miles 7/04/2010
bleu TDI
jbleu101 is offline   Reply With Quote
Where to get new heater blower motor, and... GrampaPete VW B5 Passat TDIs 0 October 15th, 2015 21:40
How to remove heater blower motor? Jamos VW MKV-A5 Golf/Jettas 17 May 18th, 2015 13:13
Heater Blower Motor supton VW MKIV-A4 TDIs (VE and PD) 15 November 26th, 2009 12:55
which blower (heater fan) motor do I need? timmyd VW MKIV-A4 TDIs (VE and PD) 0 February 2nd, 2007 14:30
Heater Blower motor problem Mike Piles VW MKIV-A4 TDIs (VE and PD) 2 January 27th, 2005 13:32
Page generated in 0.13884 seconds with 10 queries
[Output: 54.52 Kb. compressed to 50.50 Kb. by saving 4.02 Kb. (7.38%)]
