Old October 9th, 2017, 12:26   #1
bugija
Default Big problem with 7 or 6 bar sensor calibrate :(
Hi
I have big problem. I can pay for it, who can calibrate my map sensor. I have 2 map sensor:
Bosch 0 281 002 420 - 6 bar - it doesnt work lower than 0.5 bar and vnt doesnt work
Second map sensor its 7 bar custome and it have:
Voltage range: 0,5 - 4,5v
Pressure range: 0 - 7bar
I try calibrate but vnt doesnt work
bugija is offline   Reply With Quote
Old October 10th, 2017, 12:45   #2
choramix
Fuel Economy: 6 l
i think i can do it send files
none
choramix is offline   Reply With Quote
Old January 1st, 2018, 03:38   #3
jabcok20
TDI(s): golf mk1
I have the same problem. Have you find solution?
I dont check yet is it problem with osensor or linearization. But propably sensor don't see pressure under 0.5 bar. I take atmosferic as start voltage and it should work right.
AFN gtb3576klnrv 12mm
Stock AFN block , CR 17:1 , de143 , pump mod , porthead, GGU gearbox , strenghtened clutch.
jabcok20 is offline   Reply With Quote
Old January 1st, 2018, 15:29   #4
Libang
Libang's Avatar
TDI(s): TDI power :)
if you look at datasheet , this sensor is 6Bar
Pressure : 0,05 - 6bar
Voltage : 0,3 - 4,8V
post here you map linearization map
Fabia RS ASZ
Transporter T4 AHU
Golf 2 AGU
Libang is offline   Reply With Quote
Old January 1st, 2018, 19:39   #5
Mongler98
>87 to 100 psi
>VTN turbo
>WHAT???
just curious what this is for and why a VTN is part of it
Old January 2nd, 2018, 00:52   #6
jabcok20
TDI(s): golf mk1
I made ot myself . Work ok.
3 bar, 2.5 bar map sensor, thermo switch blitzed Private TDI Items for Sale/Wanted 6 March 29th, 2014 14:09
Sway bar hole too big...ideas? Caddy 16v General Automotive 8 October 13th, 2012 18:55
Electronic Immobilizer Big Big Problem coleslawter TDI 101 32 January 6th, 2011 13:26
sway bar advice.. big front vs rear Aquaticmind Upgrades (non TDI Engine related) 16 August 24th, 2010 23:37
Running 4 bar map sensor, BUT, BIG but... devonutopia TDI Power Enhancements 35 July 27th, 2009 12:19
Page generated in 0.11305 seconds with 10 queries
[Output: 71.49 Kb. compressed to 62.33 Kb. by saving 9.17 Kb. (12.82%)]
