Old October 6th, 2017, 02:39   #1
Devilsfuel
Default GTB2260VKLR Hybrid
Hi Guys,
Does anyone have any experience of hybridizing the GTB2260VKLR. This would be for a C350 CDI.
I have spoken to a few turbo specialists in the UK such as Turbo Dynamics, Xman and AET and they advise that the most they could do with this is a bigger compressor wheel.
Is there any scope to add a bigger turbine as well?
Devilsfuel is offline   Reply With Quote
Old October 6th, 2017, 08:00   #2
FraggyTDI
TDI(s): 04 Jetta
Why do you need it bigger? It's already plenty for a 1.9 or 2.0 unless you're going with a compound setup.
FraggyTDI is offline   Reply With Quote
Old October 6th, 2017, 08:18   #3
diffas
diffas's Avatar
Because why not? Its normal that basic chip is not enough after some time and you wanna make more power. Some basic 300hp is really not that much such a heavy cars. Not sure if there is bigger wheels available for vklr.
diffas is offline   Reply With Quote
Old October 6th, 2017, 08:59   #4
Devilsfuel
The car in question is running a 3.0L V6 (OM642) currently 310bhp with just software. I have a friend with an E90 BMW 335D stage 2 that i would like to keep up with to answer your question
Im really just looking for experiences anyone has on upgrading the GTB2260VKLR and how they found it and any expectations on what power increase a bigger comp wheel would give over the standard unit.
Old October 6th, 2017, 10:03   #5
devonutopia
devonutopia's Avatar
I'm already considering going from 2566vk to GTD2872vkr On a 4 pot. The quest for stupid power never ends.
Jason - Skoda Fabia TDI project
http://www.youtube.com/watch?v=TOE4nbT5NGY 315bhp dyno run video of my car.
http://www.youtube.com/watch?v=8R5c496IG1Q Skoda Fabia GTB2260vk in-car acceleration video!
http://www.devoncardetailing.gb.net/
devonutopia is offline   Reply With Quote
Old October 6th, 2017, 10:30   #6
sam-
My brother has a Cls 350 cdi and when i was looking for upgrade this was the only people i could find for those engine : http://kcperformance.eu/en/tuningsta...enz-om642-2010
sam- is offline   Reply With Quote
Old October 6th, 2017, 15:37   #7
martin33100
TDI(s): VW T5 2.5
Originally Posted by Devilsfuel View Post
Hi Guys,
It may be worth you taking to Craig at TDI Turbo's in the UK, he is ex Turbo Dynamics.
I had a VW T5 2.5 GT2056V machined to take a Mercedes GTB2060 turbine and comp wheel.
https://m.facebook.com/TDi-Turbos-634884833251922/
martin33100 is offline   Reply With Quote
Old October 6th, 2017, 23:22   #8
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Talk to Majesty here, i think he has a solution for the VKLR , should be enough for 380-400hp
Under 3000rpm will be dead of course, not much fun for a street car.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old October 7th, 2017, 01:19   #9
altz1
TDI(s): Allroad, A8
Change only the comp.wheel and you can push it to 350hp max also. Larger turbine would be ideal ofcourse. There is option to go gtb2056 as base from v6 320cdi and use amg turbine and some larger compressor. This would give you potential for 400hp. It would be pnp but slower to spool as its not bb turbo.
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Allroad C6 under construction, 420hp goal.
BVN 4.2TDI project twin gtd2060vzk, 650hp goal.
altz1 is offline   Reply With Quote
Old October 7th, 2017, 02:53   #10
Devilsfuel
Thanks all
From reading up it would seem to keep the drive ability and to keep the potential for lag down then an upgrade to the comp wheel to something reasonable would be enough for what im looking for (along with supporting mods)
Its interesting to see the page from KC performance, looks like they have fitted a 70mm comp wheel to create to the GTB2270VKLR, i wonder how the lag would be with that size of wheel....i was only thinking of going GTB2265VKLR
Old October 8th, 2017, 02:47   #11
fergyp
From what I read you want to keep the compressor inducer the same size as the exducer turbine roughly, what goes in must come out, I don't no if the amg gt23 turbine fits the vklr as it's ball bearing but its 48.6mm exducer so a compressor wheel around 48mm inducer would be a nice match
fergyp is offline   Reply With Quote
Old October 8th, 2017, 22:48   #12
Macradiators.com
There are lighter options for AMG TW that go with BB.
70mm cw on stock vklr turbo makes no sense.
CP3 Upgrade
Old March 2nd, 2018, 08:35   #13
Devilsfuel
Hi Guys,
Resurecting this thread just for a bit of information. I have managed to find a supplier who has bigger turbine wheels for the VKLR. Specs would be below for the turbo build.
GTB2567VKLR
Compressor - 49.5/65/67mm
Turbine - 49.1mm / 51.4mm (Supposed to also be lighter than standard wheel)
My car (C350 CDI 3.0L) drives well just now with minimal lag on the standard GTB2260VKLR, just wondering how much more lag the larger turbo is going to introduce?
thanks
Old March 2nd, 2018, 13:48   #14
Macradiators.com
If the tune is well done you wont feel much lag on a 3.0 engine with that turbine.
I went for the same setup for my 3.0 but different CW 50.2/65 7+7
CP3 Upgrade
Old March 3rd, 2018, 00:36   #15
adamss24
Fuel Economy: 35-45mpg
Hi Guys,
GTB2567VKLR
thanks
Do you have a price and contact details ? I have found a supplier in Romania of similar turbine wheel but they just want to install it themselves ! Installation is not a problem, their price is ! I also have a gtb2056vk which is waiting for AMG turbine wheel and 65/69 6+6 blade billet compressor ! Lag is not an issue in my case but I also donít have a 3.0 tdi engine to play with ! Thanks in advance !
adamss24 is online now   Reply With Quote
FS GTB2260VKLR Turbo bobby95 Private TDI Items for Sale/Wanted 9 July 3rd, 2016 12:14
GTB2260VKLR - Where To Get One? GoremanX VW B5 Passat TDIs 4 March 19th, 2015 19:51
GTB2060VKLR and GTB2260VKLR Diagi Private TDI Items for Sale/Wanted 2 August 5th, 2014 12:32
[fs] gtb2260vklr (a6420909580) micasb Private TDI Items for Sale/Wanted 11 October 29th, 2012 15:47
Wanted - GTB2260vklr JTT Private TDI Items for Sale/Wanted 2 August 5th, 2012 16:01
Page generated in 0.11423 seconds with 10 queries
[Output: 125.99 Kb. compressed to 105.03 Kb. by saving 20.96 Kb. (16.63%)]
