Old September 29th, 2017, 22:19   #16
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Lots of guys on the mk6 gti forum put lsd into their dsg so you can find lots of info there. It shouldnt be too difficult to mount.
I would also put it in my ds500 but the price tag is too high for the moment at over 2000€
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old September 30th, 2017, 07:29   #17
travis45
travis45's Avatar
Bob, what do you mean by adaptation?
14 Sportwagen TDI CR170 Frankenstien hybrid 2056 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD.
travis45 is online now   Reply With Quote
Old October 1st, 2017, 09:49   #18
travis45
travis45's Avatar
Found a good thread here:
http://www.golfmkv.com/forums/showthread.php?t=188812
Old October 5th, 2017, 10:50   #19
740GLE
Originally Posted by travis45 View Post
Of course, how could I have not thought of such a simple solution. Thanks Oilhammer.
Let me add to the madness by asking if it is possible to put in a taller 6th gear? If a DSG is just an automatic manual, why not? Would be great to lower a few hundred RPM on the highway commutes.
If I have the case cracked, I'd want to do it all at once.
This is what I want for the Alltrack, no more of this 2300 RPMs at 65!
Old December 21st, 2017, 18:02   #20
travis45
travis45's Avatar
Ready to buy the LSD, but I need to know where I can find the parts list of bearings, shims, seals etc.
Can anyone point me in the right direction? I have a local installer willing to do the work, but I need all the parts and pieces.
Any help is appreciated.
Respectfully,
Travis
Old December 22nd, 2017, 11:11   #21
travis45
travis45's Avatar
Finally... ordered today..
Diff shim kit: http://autotech.com/vw-02e-dsg-diffe...5wk-188wk.html
Diff bearing kit: http://autotech.com/2wd-02e-dsg-diff...aring-kit.html
Wavetrac DSG 25T 2wd diff: http://autotech.com/wavetrac-differe...3-tt-2-0t.html
Old December 22nd, 2017, 12:10   #22
xjay1337
Originally Posted by oilhammer View Post
The standard ASR/EDL with the ESP is not enough? I think that is why they generally do not bother much with locking or limited slip mechanical differentials in FWD cars. The traction control works pretty good.
EDL can destroy brake pads. After all, it tries to combat wheel spin by using the brakes, right?
(FYI, it does simulate a diff really rather well, but at a cost in consumables, and effectively torque vectoring by braking is always slower than by using a diff
On my fronts calipers, I had 2mm left on my right hand side, but my left hand side was much healthier at 5-6mm.
When your pads cost $700 a pop , rather not waste them
I used my right foot more carefully for a while, and now have a Peloquin ATB in a rebuilt gearbox.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 340hp 625nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old December 22nd, 2017, 20:59   #23
travis45
travis45's Avatar
The next question is should I put a new DMF in, and is there a beefier one, say from a CR170, while I'm in there...
Also, if you were doing this, would you put in the upgrade clutch packs at the same time as well?
All opinions appreciated....
Travis
Old December 23rd, 2017, 01:42   #24
turbobrick240
turbobrick240's Avatar
I think Les at GDM(German diesel motorwerkes) may have a dmf upgrade for the dsg. Not sure how necessary/beneficial that or upgraded clutch packs would be though.
Old December 23rd, 2017, 05:56   #25
740GLE
Stock tuned DSGs have been holding up to +400HP on the R and about that on GTIs, while I know it saves you the labor to do everything at once, you maybe chasing the wrong problem.
Old December 23rd, 2017, 06:40   #26
travis45
travis45's Avatar
Thanks for the response guys. Going to slap the LSD in and roll with it...
Old December 23rd, 2017, 12:00   #27
turbobrick240
Stock tune, or stock hardware? It's really the torque figure that matters- which on 400 hp 2.0 TSI is probably around 400 lb-ft. But yeah, the stock dsg hardware should be fine.
Old December 29th, 2017, 21:15   #28
travis45
travis45's Avatar
Ordered an engine support bar to help with the DSG removal. Only $60!
http://www.amazon.com/dp/B01BRB0RL2/..._l6xrAbQQMHH7J
My local tuner recommended a cheap electric hoist instead of a jack to lower it.
Any advice appreciated to help with the removal.
Old January 2nd, 2018, 10:09   #29
740GLE
From what I've read a DSG tune is recommended to get everything out of the tune, but the DMF is good to go.
APR stage 2 "high torque" with TCU tune handles 400tq with 387 hp.
Old January 13th, 2018, 16:11   #30
3L3M3NT
3L3M3NT's Avatar
If you haven't got your transmission back together , here are a few options for you on upgraded clutch packs.
https://www.uspmotorsports.com/Dodson-Motorsport/
https://redlinespeedworx.com/dodson-...ade-audi-tt-s/
https://www.goapr.com/products/clutch_packs_dq250.html
https://www.sspperformance.com/vw-au...t-gearbox.html
http://www.unitedmotorsport.net/products/dq250-dsg/
Hope the links help.
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: https://chrome.google.com/webstore/d...giikdkpmcpkaon
Firefox Fix: https://addons.mozilla.org/en-US/fir...t-fix/?src=api
3L3M3NT is online now   Reply With Quote
Limited Slip Differential Hondroid TDI 101 3 November 7th, 2010 05:29
09, Limited Slip Differential goldgary TDI 101 3 October 23rd, 2008 17:39
Limited Slip Differential TheMadcap TDI Power Enhancements 16 December 6th, 2002 13:19
Limited Slip Differential TDI 1 Upgrades (non TDI Engine related) 5 May 3rd, 2001 11:39
Limited Slip Differential TDI 1 VW MKIV-A4 TDIs (VE and PD) 3 April 28th, 2001 18:51
Page generated in 0.17226 seconds with 10 queries
[Output: 132.40 Kb. compressed to 110.68 Kb. by saving 21.72 Kb. (16.40%)]
