Old September 28th, 2017, 19:44   #1
travis45
travis45's Avatar
Default Limited Slip Differential in DSG
Looking everywhere for some information. Would like very much to install a limited slip differential in my 14' JSW With a DSG transmission.
A lot of information out there on install of a LSD in a manual transmission.
Would love to have a conversation with someone who has done this job. Or if anyone who can point me in the direction of more information. I've never opened up a DSG and want to be prepared before I do.
Respectfully,
Travis
14 Sportwagen TDI CR170 Frankenstien hybrid 2056 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD, GTB2260vklr, Colt billet cams w/upgraded springs, ARP Headstuds.
travis45 is offline   Reply With Quote
Old September 29th, 2017, 04:22   #2
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Wavetrack makes it for dq250 ..that would be my 1st choice.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old September 29th, 2017, 04:44   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The standard ASR/EDL with the ESP is not enough? I think that is why they generally do not bother much with locking or limited slip mechanical differentials in FWD cars. The traction control works pretty good.
Of course if you are wanting to road race or track day the car, that may be a different story. Then the mechanical type has an advantage. Because it needn't reduce any available power in order to work.
But for getting around in winter weather, all my dubs equipped with ASR/EDL do just fine. Excellent actually.
But with a lot of power mods, the LSD would certainly be welcome and may even make for the electronic nannyware to not intervene nearly as much.
oilhammer
www.cardocautomotive.com
Old September 29th, 2017, 04:54   #4
travis45
travis45's Avatar
I agree that the traction control works well. But after last Sunday at Road America, I realize how much potential isn't hooking up with the track. My guess is that seconds would be shaved off my times with th LSD.
Thanks Mac, yes Wavetrac is the one. But have you ever installed one?
Old September 29th, 2017, 05:26   #5
oilhammer
oilhammer's Avatar
You will likely find more information on LSD into DSG installs by widening your internet searches to not specifically limit TDIs. Because a quick google search just now revealed ALL KINDS of info, videos, pictures, part numbers, etc. for folks putting them in DSG equipped GTIs. Which should be mostly the same thing for your car.
oilhammer
Old September 29th, 2017, 06:21   #6
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
The performance pack Mk7 GTIs come standard with an electronically-controlled LSD. That would probably be a nightmare to source and install though.
Blue_Hen_TDI is offline   Reply With Quote
Old September 29th, 2017, 07:16   #7
Enabled
Electronically controlled LSD is just the brakes being applied to alternating sides to simulate LSD. Not a true LSD.
-2003 Jetta TDI GLS Manual (Mods: SBC II Daily, .681 5th, VNT17 & PP520, Self Tuned)
-BMW 328is Manual (heavily modded 220whp, track toy)
-BMW Z3 Roadster (Fun in the sun car)
-BMW Z3 M Coupe (1 of 36)
-BMW 328d wagon (Self tuned ~230hp)
Enabled is offline   Reply With Quote
Old September 29th, 2017, 07:25   #8
Blue_Hen_TDI
Incorrect. https://youtu.be/HQqh2Tv5Puc
Old September 29th, 2017, 07:37   #9
Enabled
Nice info.
That's how the 'lesser' electronically controlled LSDs used to work. Which wasn't all that great.
Now I wonder if all this electronic control over the LSD is worth the complication over a simple and very good torsen type LSD, or even the classic clutch pack style.
Old September 29th, 2017, 08:04   #10
Blue_Hen_TDI
Nice info.
Probably not quite as good, but a no-brainer option on the GTI, when performance pack also comes with larger Golf R brakes (and a minor tune +10 bump in hp), all for $1500.
Old September 29th, 2017, 11:02   #11
travis45
travis45's Avatar
Of course, how could I have not thought of such a simple solution. Thanks Oilhammer.
Let me add to the madness by asking if it is possible to put in a taller 6th gear? If a DSG is just an automatic manual, why not? Would be great to lower a few hundred RPM on the highway commutes.
If I have the case cracked, I'd want to do it all at once.
Old September 29th, 2017, 11:17   #12
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
I have done one on a DSG worked well .
For any real roadracing it is a must to have a LSD in a front wheel car.
Here is my car last year as the car rolls it will lift the inside wheel so you need all the tires touching driving you forward.
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old September 29th, 2017, 12:45   #13
adjat84th
adjat84th's Avatar
You could look into sourcing the 6th gear from the '15+ DSG TDI as they have a taller ratio than your '14.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
Old September 29th, 2017, 13:35   #14
travis45
travis45's Avatar
Bob,
Is there much difference to this job on a DSG compared to a manual?
Crack case, remove shift forks, remove gears, remove ring gear with differential, drill out rivets, install LSD to ring gear, reassemble?
What about new bearings and checking lash?
Respectfully
Travis
Old September 29th, 2017, 15:52   #15
CNGVW
I did the ring gear work I used a tranny shop to pull it apart I use a lot. He said it was a bear to assemble had to watch a few youtubes to get it right.
On start up made a lot of noise and then did the adaption and it was fine after that.
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
Limited Slip Differential Hondroid TDI 101 3 November 7th, 2010 05:29
09, Limited Slip Differential goldgary TDI 101 3 October 23rd, 2008 17:39
Limited Slip Differential TheMadcap TDI Power Enhancements 16 December 6th, 2002 13:19
Limited Slip Differential TDI 1 Upgrades (non TDI Engine related) 5 May 3rd, 2001 11:39
Limited Slip Differential TDI 1 VW MKIV-A4 TDIs (VE and PD) 3 April 28th, 2001 18:51
Page generated in 0.16133 seconds with 10 queries
[Output: 135.78 Kb. compressed to 113.49 Kb. by saving 22.29 Kb. (16.42%)]
