Old September 12th, 2017, 16:07   #1
Josh_WA
Josh_WA's Avatar
Default TDI 1Z to 93 Eurovan (budget build)
Poor man’s 93 Eurovan MV TDI conversion
Here we go again. I previously converted a 93 MV weekender for my use via this thread.
http://forums.tdiclub.com/showthread.php?t=443865/
My goal on that build was to spend about $2k for the conversion. I think I ended up spending about $2300. This time my goal was to again spend around $2k, but to also include the van.
Earlier this summer I can across a great deal on a rear wrecked B4 Passat that somehow couldn’t pass up. I pulled the car apart and saved up the conversion parts I need for another VW Eurovan (T4a) conversion. I’ve sold enough parts to net a free 1z engine and parts needed. The Passat had the timing belt changed about 10k miles prior to the rear ending, so I’m forgoing changing belts and rollers if they appear good. I’ll do some inspection on the rotating items as I clean up the engine. The turbo unfortunately needs to be replaced. The whole backside of the engine has a nice coating of oil. The nice thing about going with the 1z from a Passat, is that the gauge cluster is physically the same as the Eurovan cluster. Also, the wiring harness for the 1z is not integrated with the lighting harness of the car, so the wiring is a little cleaner to begin with. I have more parts to sell, but as of now I’m at +$150 with the wrecked Passat purchase.
Passat parts needed for the conversion:
Engine
Engine accessories, including turbo
Coolant hoses and reservoir
Engine wiring harness
Matched ECU
Gauge cluster
Fuel lines
Eurovan tdi #2 by x Holmes, on Flickr
Just recently a van came on the market that would be an ideal candidate for my budget build. There are usually plenty of inexpensive manual transmission GL models that come up, but I was waiting for a manual MV. This one was going for cheap because it’s only running on 4 out of 5 cylinders. $500 later, I’m sweating home on 4 cylinders, to avoid a tow. I’m again going with a stock manual transmission. This one being a CHP this time, but will changing out 5th gear for the .756 in the Passat transmission. Stock 5th is .8xx. With, the van, I’ll be pulling out what is saved from above, to be replaced. The van itself is in fair shape aside from the slider door that I will be replacing. The inside needs a trim piece and just a general cleaning, but is not too bad. I can get those pieces from a local guy. That brings my van price to about 650.
The 3rd part of this puzzle of course are the European parts to make this bolt right in. The 1z and AHU engines are of the same block build as the ABL na diesel that is available in Europe. Frans will be supplying these parts again. Costing about $600.
4cyl transmission carrier 02B409905K
lower timming belt cover 028109127H
Oil dip Stick/housing 028115629E, N90461401, 044115611F, N 028 224 01
Oil filler neck and cap 044115308A/070115319
Sump (oil pan) 044103601D
Transmission upper cover plate 044103647B
right-side engine mount 028199207E.
lift pump (fuel tank pump) 701919813B
So far I’m at $1150 in cost. Additional $s to be spent mostly on the turbo, clutch package, and exhaust welding.
Josh_WA is offline   Reply With Quote
Old September 12th, 2017, 16:15   #2
Josh_WA
Josh_WA's Avatar
Last time this took me a good 6 months to complete. Started with an easy task of drill and tapping the bolt holes for the European passenger side engine mount.
These 3
Drilled out with 5/16 bit
Bottom tapped with m10 x 1.5. The stock size running through the mount.
Old September 12th, 2017, 16:57   #3
Bobob729
TDI(s): Jetta
I always told my self if I ever get a van this will be what I do. Awesome to see others are doing this as well
Bobob729 is offline   Reply With Quote
Old September 12th, 2017, 21:09   #4
therabbittree
therabbittree's Avatar
TDI(s): B4 passat
Awesome! Looking for a clean 2000 so wiring and cluster matches my 1z. 96 passat.
'96 Passat TDI wagon, 1982 Jetta Coupe tdi swap project, 2000 Excursion 4x4, 12v cummins, G56, \x/ hillfolk
therabbittree is offline   Reply With Quote
Old September 13th, 2017, 05:34   #5
Josh_WA
Josh_WA's Avatar
You'll need a 93 cluster trim to fit the 96 Passat cluster to a 97-03 eurovan. Or use an mk4 tdi cluster.
Old September 13th, 2017, 06:40   #6
therabbittree
TDI(s): B4 passat
From what ive seen the 93-2000 eurovans have the b4 passat style cluster. The 2001-2003 eurovans have the different dash and have mk4 style clusters. Thats one of the benefits of Using the 2000 older eurovan vs a 2001-2003 . The 01-03 do have better brakes and suspension etc
Old September 14th, 2017, 06:45   #7
mogly
Cool project. Budget builds are always fun.
2000 was a transitional year for the T4. I've seen some with the early middle 2 person bench with the corduroy upholstery and others with '01-03 upholstery and separate buckets.
mogly is online now   Reply With Quote
Old September 24th, 2017, 22:12   #8
VW-TDI
VW-TDI's Avatar
There was a "split" 08/1999 - 09/1999, so if the van was manufactured in September 1999 or later - it has a new style cluster. If production date before 9/99 - then the van come with older style cluster.
And that means of course all 2000 Eurovans come with newer style cluster, even some 1999's with new style clusters/dash.
VW-TDI is offline   Reply With Quote
Old September 26th, 2017, 18:00   #9
mogly
Thanks for the clarification Slavic.
Old October 6th, 2017, 14:37   #10
Josh_WA
Josh_WA's Avatar
Received some parts from Dutchautoparts.
on Flickr
installed the ABL lower timing cover and test fitted the passenger side engine support with the new 10mm tapped holes. Bolts on great.
on Flickr
Drilled a pilot hole for the dipstick as well. There's a flat at the back of the engine block intended for the rear dipstick on a forward tilted engine. Just drill perpendicular to the flat.
on Flickr
And hopefully you hit the flat on the underside.
on Flickr
Old October 24th, 2017, 09:28   #11
Josh_WA
Josh_WA's Avatar
Finished up that rear dip stick. 13/32 drilled all the way through. Step drill it down about 3/8 with a 9/16 bit.
Here's the dipstick now installed. Bolts to the coolant heater plug flange, but under the round engine harness plug bracket. Like my first van, had to extend the bottom bracket hole of the dipstick housing to reach the stock bot position. Its in there good and tight.
Old October 24th, 2017, 11:07   #12
Josh_WA
Josh_WA's Avatar
The van has assumed the position. This is all the room you need in a minimalist work area situation.
Once into position, time to pull the front end apart. No pressure in the AC lines, so those came right off. Drain the coolant and power steering fluid. Disconnect the lines and pull the hing pins from the radiator assembly and remove it. i opted to pull the lights although they could be left in place. have to remove at least the drivers side cover under the light to disconnect the radiator fan resistors.
4 bolts up top and 6 around the bumper and it can be removed. Make sure to unclip all the wiring and hoses from the backside of the bumper.
To get the engine out. Pull the wiring back towards the battery side. Engine doesn't come out without the transmission. Disconnect: power steering lines, power steering brackets, power steering pressures sensor, inner axle bolts, AC lines, ground wires, coolant hoses to the body, intake hose, fuel lines, shift linkage, speedo cable, and slave cylinder(the part i forgot). Inch it out. The engine tends to bind up on the axles. You could complete remove the axles if you want, but I like to fight them.
I've separated the transmission from the engine now and waiting for my new clutch to arrive. Also have gotten the ABL oil pickup and pan on the engine and accessories remounted. Haven't modified the AC compressor yet. I'm working towards firing up the engine first.
Old October 24th, 2017, 11:29   #13
Josh_WA
Josh_WA's Avatar
While I've been waiting on the clutch, went to modifying the fuel tank. I went with the ABL diesel fuel sender. I drop the tank to modify the fuel nozzle opening to 1" as well. First up is to disconnect the gas pump power and sender signal. That wire won't stretch to the floor if you just drop the tank.
Had a full tank of gas, so I put 12v to the pump to get the rest out.
Pull out the ring and take out the rubber surround.
One bolt that can keep you from dropping the tank.
Pry the 3 tabs to separate the metal cap and funnel from the tank neck.
Using a very small screwdriver you can pry out the tab holding this splash plate in.
No picture of the end product, but carefully used a 1" bit in a drill press to open up the funnel hole. Reassemble.
I dropped the tank by removing the rear 3 bolts from the straps holding it up. In hind sight probably jacking up a board or two underneath may help getting it down. But Gravity. Pull out the gas pump and sender by unscrewing the retaining ring. I needed to reuse the ring and rubber washer. There is a ring at the base of the tank that the gas sender attaches to. This ring will be in the way of the diesel sender. It's only necessary to remove half the ring. It's a plastic covered copper ring that was a bit of an effort to remove on both tanks i've modified. It's the passenger side of the ring that needs to come out. There will be a nub of plastic remaining, but the diesel sender will go right over top of it.
I pulled the original fuel lines and filter out. I ran a section of the donor vehicle fuel lines to the diesel filter in the stock location ahead of the battery. Normally there is a plate riveted on there that the coil sits atop of.
I attached the fuel lines to the tank before hiking it back up with the help of a jack this time. Fuel support is now complete.
Old October 24th, 2017, 11:48   #14
Josh_WA
Josh_WA's Avatar
Using the Passat wiring harness seems so much easier than the Jetta harness on my first van. Nothing to pull apart. Pushed the inside connectors through the firewall and plugged the hole with the donor plug. All the inside plugs reach everything they need to go to. Again using these T4forum wire references, and additionally Andrews wiring information.
http://www.vwt4forum.co.uk/showthread.php?t=61313
http://www.vwt4forum.co.uk/showthread.php?t=63539
http://andrewclink.com/projects/thebus/wiring
This time I modified the passat potentiometer bracket for the throttle. Again using most of the bottom of the original gas pedal and the top of the passat pedal for adjustment. I think I've got it where I want. Just need to weld the pedal pieces together.
Old October 25th, 2017, 19:54   #15
archemitis
archemitis's Avatar
What are you doing to the fuel sender?
I just got mine running and just bypassed the gas pump by letting two hoses dangle down to the bottom of the tank, still using the gas level sending unit. What did the ABL have?
Ya got me nervous, I really dont wanna drop that big ole plastic tank again.
archemitis is offline   Reply With Quote
TDI AHU to 93 Eurovan Josh_WA TDI Conversions 87 July 8th, 2019 09:50
TDI into a '93 Eurovan twentyeight TDI Conversions 10 January 15th, 2016 21:09
1.9 TDI in a '93 Eurovan? vwlotus TDI Conversions 1 March 15th, 2008 17:06
TDI in a 93 Eurovan? AlanH TDI Conversions 4 October 8th, 2006 15:01
93 Eurovan TDI Conversion? Shaun512 TDI 101 3 May 20th, 2005 12:32
Page generated in 0.20554 seconds with 10 queries
[Output: 142.47 Kb. compressed to 119.79 Kb. by saving 22.68 Kb. (15.92%)]
