Old September 22nd, 2017, 18:18   #31
Forte
I have the Stage 2 Malone on my 15 Golf... we got them at the same time lol I could've swore I felt the similar thing at the same RPM thru my DSG.. I do plan on getting the DSG tune eventually and rarely get on it even that low in RPM... I got it for better MPG but enjoy the power when I need it.
Forte is offline   Reply With Quote
Old September 23rd, 2017, 19:34   #32
Kevinski4
Kevinski4's Avatar
A DSG tune won't fix DMF shudder. A minor tweak to your ECU tune will.
I am a Malone Tuning dealer in Eastern WI, including Common Rails and DSG, Sprinter, and BMW! Visit our website: www.facebook.com/wisconsindiesel
Forget Clean Air, It's a Power and Money Grab
Kevinski4 is offline   Reply With Quote
Old September 25th, 2017, 10:58   #33
Forte
well it only happens once in a while IF I do WOT at low RPMs... should I have them retweak it Kevin or will it not damage anything since I don't get on it at low RPMs then?
Old September 25th, 2017, 17:44   #34
adjat84th
adjat84th's Avatar
If you drive around it there's no harm. As you can see from the dyno posted above, there is an abrupt spike in torque that unfortunately the DMF just can't handle in tuned form. Even the CR190 GTD in Europe is torque limited to 280lb-ft for this reason when that turbo is capable in tuned form to get close to 350lb-ft. I'll say again though, not trying to plug for their product, the Fluidampr made the shudder disappear in my car entirely. The only options are to have the tune tweaked under 2k rpm or install the Fluidampr which is just a fluid filled harmonic balancer that replaces the almost nonexistent OEM damper. If you ever plan on upgrading the turbo and clutch down the road, you'll want the Fluidampr in order to run a single mass flywheel. It is highly likely that VW intentionally used a cheap damper because they know the DMF will soak up the rest of the torsional vibrations on these cars!
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old February 7th, 2018, 05:37   #35
740GLE
Follow up to old thread, I received a modified stage 2 tune and DMF shudder has been 95% removed. I notice a small shudder if at almost WOT, where before it was 70% WOT.
As far as comparing Stg 2 to modified Stg 2, I couldn't tell the difference in pull or tip in off the line. I'm sure a dnyo would say otherwise but I'm very happy with the 2 months its been installed.
Also the price of a tune is worth it for tip in more than peak HP numbers, it just makes zipping form a red light and goosing the pedal in the 1400-2000 RPM range so much more enjoyable, I've never felt the need to wind it out above 3-4K.
Malone Tuning - Stage 0.5 Tune for 2015 Golf/Jetta/Passat WhatFloor VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 38 August 6th, 2017 15:01
2014 B7 Passat NMS stage 3 malone / DSG Tune kwajtimbo TDI Power Enhancements 0 August 12th, 2014 03:35
Malone stage 2 cr and dsg... TOPH R Ontario 3 May 29th, 2014 15:57
Malone Stage 2 W DSG chgofirefighter VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 14 December 5th, 2013 23:07
Malone Stage 1.5 and DSG tune... Paulinski VW MKV-A5 Golf/Jettas 12 September 13th, 2013 19:24
Page generated in 0.13889 seconds with 10 queries
[Output: 72.79 Kb. compressed to 64.78 Kb. by saving 8.01 Kb. (11.01%)]
