Old September 5th, 2017, 13:28   #16
740GLE
Yeah the wife has never used either manual mode or sport mode. I've also been guilty of just mashing the peddle a little more in D just wanting the pull at taller gear rather than dip over to S or down shifting. Something about winding the engine above 3K doesn't seem right to me even thou I know that's where the real power is.
I was expecting the shudder, now I'm weighing the options if its worth going with a DSG tune, a reduced stage 2 tune or leaving as is and just be aware of it.
Again, you can't beat the simplicity of flashing in the garage in 20 minutes, I was able to change the cat litter boxs and bring back the trash cans from the curb all while getting more power.
Old September 5th, 2017, 14:55   #17
raffshore
are you sure it's dsg shudder? It could be the dual mass having trouble with the torque at low rpm
raffshore is offline   Reply With Quote
Old September 6th, 2017, 06:20   #18
740GLE
I guess it's hard to tell the difference, from the butt dyno, is there a log I can take to tell the difference?
I thought it was the DSG and possible clutch slippage which reverberates in the DMF. If it is the DMF I'll probably be looking at a detune as changing the DMF isn't on the table for a daily driver.
Old September 6th, 2017, 19:35   #19
travis45
travis45's Avatar
My money is on DMF. Just drive around it and don't floor it at 1,000 RPM.
14 Sportwagen GTB2260vklr Turbo, Rawtek turbo back exhaust, Malone custom tune, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Neuspeed rse14 Wheels, Fluidamper Crank Pulley, KW V3 Coilovers, H&R 22mm rear sway bar, PolarFIS, Darkside intercooler and piping, Wavetrac LSD, Brembo 18z calipers w/drilled rotors. Soon to install Colt billet stage 3 cams w/upgraded springs, ARP Headstuds and IE connecting rods.
travis45 is online now   Reply With Quote
Old September 7th, 2017, 05:20   #20
740GLE
I'm thinking the RMPS were up a bit 1,8-2k and it wasn't floored, def didn't hit the kick down switch, just squeezing more umph out of her.
The wife has been driving this week and haven't noticed anything.
Old September 11th, 2017, 23:18   #21
roadlust
roadlust's Avatar
DMF shudder happens under 22-23k. Put in manual mode floor it above 23k and see if it happens.
2013 TDI Golf 2dr Tech Package MT6.(Sold back to VW)
roadlust is online now   Reply With Quote
Old September 12th, 2017, 05:24   #22
740GLE
I had some more seat time with the car, it seems to happen right between 1.7-1.8K, I was able to feel it when romping on it from a rolling stop, I think it was in 3rd but the RPMS were moving quickly up to 3k to shift.
The more pronounced feeling is in higher gears in 5th or 6th and pulling, it sits in that RPM band longer, I think enough for the ECU to pull fuel.
Looks like its happening under peak torque, which is what 2.2-2.3K, 1.8K is probably right where the tune has the torque deviating a ton from stock and the DSG can't keep up with stock programing.
The more and more I'm thinking about it, I may go for a stage 1.5 tune to see if we can still keep the low speed pick up and have 75% of the highway pull of the stage 2. If the stock shifting of the DSG was lethargic or bugging me I may look at a DSG tune, but the '15 stock DSG shifts pretty darn fast.
I did do a couple pulls shifting up to 3,500 when the wife wasn't in the car, thing is a "rocket" compared to stock.
Old September 13th, 2017, 05:57   #23
Kevinski4
Kevinski4's Avatar
Peak torque with your tune is right where you are feeling the DMF shuddering, ~1800rpm. It's the flywheel, not the transmission. Have you talked to your Malone dealer yet about trimming torque right in that area? You don't need to go to a 1.5 (one doesn't exist for your car anyway) and the slight drop in peak torque isn't enough to notice by the seat of your pants.
It's an easy and free fix. A few minutes at your Malone dealer and you'll be back on the road, DMF shudder free, with no perceivable loss of power.
I am a Malone Tuning dealer in Eastern WI, including Common Rails and DSG, Sprinter, and BMW! Visit our website: www.facebook.com/wisconsindiesel
Forget Clean Air, It's a Power and Money Grab
Kevinski4 is offline   Reply With Quote
Old September 13th, 2017, 06:27   #24
740GLE
Seeing I bought online with flashzilla, it's on the list of things to do, just need to send the email.
BTW on Malones site it appears peak torque its more of ~2.1-2.2K, but it does make sense.
Old September 13th, 2017, 07:51   #25
Kevinski4
Kevinski4's Avatar
Old September 13th, 2017, 08:20   #26
raffshore
I agree
Old September 13th, 2017, 13:09   #27
740GLE
Ahh I was looking at the pretty looking smoothed out graph.
Old September 14th, 2017, 18:27   #28
adjat84th
adjat84th's Avatar
A fluidampr made DMF shudder disappear in my '15 golf with stage 2 eco tune. It's not cheap, but it does work!
Currently running a SMF, so problem solved permanently
The lower timing belt cover will need some trimming/sanding, or the pulley will rub on it when installed.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old September 15th, 2017, 09:27   #29
740GLE
Where did you source the fluidampr from?
At this point a "de-tune" is going to be my easiest option.
As for SMF, I'm assuming you have 6MT, not DSG. I'd have to say the DMFs and their inherent shudders may be different due to different parts.
Old September 16th, 2017, 05:23   #30
adjat84th
adjat84th's Avatar
INA in the vendor section has a thread there. I believe I posted my review in there as well.
Yes, 6MT so likely different DMF but certainly same design. I believe German Diesel Motorwerks has done an SMF upgrade in a DSG. Not sure what the progress on that was though.
Sent from my Pixel using Tapatalk
Malone Tuning - Stage 0.5 Tune for 2015 Golf/Jetta/Passat WhatFloor VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 38 August 6th, 2017 15:01
2014 B7 Passat NMS stage 3 malone / DSG Tune kwajtimbo TDI Power Enhancements 0 August 12th, 2014 03:35
Malone stage 2 cr and dsg... TOPH R Ontario 3 May 29th, 2014 15:57
Malone Stage 2 W DSG chgofirefighter VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 14 December 5th, 2013 23:07
Malone Stage 1.5 and DSG tune... Paulinski VW MKV-A5 Golf/Jettas 12 September 13th, 2013 19:24
Page generated in 0.13676 seconds with 10 queries
[Output: 132.37 Kb. compressed to 110.80 Kb. by saving 21.57 Kb. (16.29%)]
