need4speed
- Joined
- May 4, 2004
I had given my 2003 Jetta to my son, and he had been taking care of it. I'm trying to reconstruct the events as he's described them, as he has returned the car, with a problem he can't fix.
At 210,000 miles, he had the timing belt done by a local shop: not a TDI-specialist shop (we don't have one here), but AAA-approved. I had used them in the past for work on other cars and generally trusted them.
Car now has 220,000 miles.
At some point after the timing belt job, the lower radiator hose developed a leak. He dealt with lowering coolant levels for a couple of weeks (topping off with either coolant or distilled water) - before he located the problem and replaced the hose.
When he replaced the lower hose, he accidentally broke the plastic fitting on the upper hose, so he had to replace that too. I think it was around this time he noticed "soot in the coolant reservoir". He took the car back to the same shop - and their diagnosis was "soot in the coolant reservoir". No other findings or other action taken.
He brought it back to me, and we flushed the coolant, and replaced it with fresh G12. This was when he started having occasional overheat problems on the highway. We couldn't tell where it was leaking from, but in hindsight, we now know it was leaking from the expansion tank's overflow.
When he could no longer commute to work (10 miles) without an overheat, he left the car with me.
Through each overheat event, he assures me; it never reached the top of the temperature gauge, and it never shut down due to high temperature. I don't think he ever found the expansion tank totally empty either, but I do think the car was probably run with too-diluted coolant for a while.
Here is what I've done:
1. Replaced thermostat (195 F).
2. Flushed and replaced coolant. (G40, which is G12 compatible).
3. Checked water pump: Impeller is fixed on shaft.
4. Checked exhaust gasses in coolant with block tester kit: negative.
5. No coolant in oil.
6. No oil in coolant.
7. Good flow through radiator.
8. Good flow through block.
9. Good flow through egr cooler and heater core.
10. No sign of coolant in exhaust.
11. Engine runs smooth and even, as always.
12. Expansion tank return line shows good flow, no bubbles.
Car warms up at idle to 195 F, thermostat opens. Operating temp stabilizes at 195-196. I can drive around the neighborhood, and temp remains at 192-196. (Temps monitored through ODBC port with an ELM 137 and smartphone with ODBCFusion app).
If I get frisky with it, it goes up to 202-204, and can come back down to 196. When I parked, it went up to 214, and I got out, and checked the expansion tank, again the level was near the top, (instead of halfway between min and max where I had just filled it), and it was visibly bubbling.
I'm kind of at a loss. I don't have a way to do a compression test because my tester does not have an adapter that fits these glow plug holes, and it only goes up to about 300 PSI. Same with the one I could rent at the local auto parts store. I'm not convinced that the head gasket is blown or head is cracked, but I believe I've eliminated all other possibilities.
