Old February 18th, 2018, 19:07   #91
Teamzarz
TDI(s): 2009 JSW
I'm not sure if it is or not. It may be that certain monitors in the ECU have changed and previous to the fix the ECU wasn't seeing an almost clogged heater core as clogged enough to warrant a CEL.
It could also be that since the heater core is next in line after the EGR cooler and the car is doing more regen cycles to heat up the cat and clear the DPF the EGR is seeing much more heat than normal. This hotter than normal coolant now reacts more aggressively with the solder flux in the core causing the coolant to go more acidic which reacts with the aluminum components making a scaly sludgy mess that builds up in the heater core and can't escape effectively plugging the core.
The above should be taken with a grain of salt although a similar core in the passat had this issue for which they issued a TSB and covered a load of replacements under an extended heater core warranty.
Teamzarz is offline   Reply With Quote
Old February 18th, 2018, 22:17   #92
spayne
Hey Teamzarz, call vwoa again and raise hell. The rationale that my service guys said to me was "the core was not clogged before the fix and now it is so we are going to fix it". But that wasn't their feelings before I called vwoa and raised hell.
Then soon after the heater core fix, the egr cooler clogged too and they took care of it also.
spayne is offline   Reply With Quote
Old February 19th, 2018, 07:07   #93
Teamzarz
TDI(s): 2009 JSW
Car at 125k in late 2014 the seat warmer passenger side tried to burn off my wife's butt and filled the car with burning foam fumes while our 5 month old son was in the car. Called VW and raised hell. They covered the seat replacement and gave me a loaner Tiguan for 51 days while they fixed it. total cost $5300. I paid nothing. This was pre-scandal.
Took it in for the fix had that manifold issue. Raised hell with VW. They covered it so I could get my fix done. $950, I paid nothing.
Now this stupid thing with the heater core, was prepared to just do it myself. Was going to let VW slide on this one. Till the dealer tried to gouge me for the diagnostic fee after I told them what I thought it was anyway. Then told me somehow that a 70 dollar heater core plus 1.5 hours labor would be 600 dollars to fix. Labor rates at Florida VW dealerships must be on par with Bentley or something.... Called VW on Saturday and raised hell yet again. I'll keep you posted.
Old February 19th, 2018, 09:14   #94
Teamzarz
TDI(s): 2009 JSW
Just got the call from Fields. VW is covering the heater core!
Please people if you get the fix and you throw this code call VWoA customer care and ask for it to be covered.
Old March 1st, 2018, 05:01   #95
Nurse Diesel
Okay, guys, I'm still sitting on the fence about getting my car fixed or just leaving it the way it is and hoping for the best down the road. The chatter seems to have died down from most of you--still happy with your "fixed" cars? Would you do it again?
Nurse Diesel is offline   Reply With Quote
Old March 3rd, 2018, 08:10   #96
forrest resto`s
Talking
Hey Kathy..from what I read most of the feedback has been positive..with me being one of them...like most have said here..getting the 'EXTENDED WARRANTY AND QUITE A CASH BONUS" HAS LEFT ALOT OF PEOPLE HERE VERY HAPPY.. KEEP IN MIND..if something goes wrong with your car (that would be under the extended warranty) you will have to pay out of your pocket without it.. and there are quite a few things that may go bad eventually.. e.g. fuel pump..egr filter..dpf.. heater core..the lists goes on...and it's VERY expensive to have any of these repaired by a dealer!.It's very comforting for me as others having this warranty! also if you want to you can take some of the cash and get a "tune on your car" (likely invalidating warranty though) and really get the power back and then some and also get better mpg's before you got the fix!..and still have a bunch of money left over to fill your closet with new shoes and clothes!
forrest resto`s is offline   Reply With Quote
Old Yesterday, 13:50   #97
jbright
I got a check engine light driving home from work last night. I dropped it off at the dealership today and just got a call. It's the heater core. Again. Right after I had the fix done in September the heater core had to be replaced, on my dime. This time it's covered under the extended warranty. I reminded the service rep this was likely caused by the fix itself and he said that was a good possibility.
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed' 10/18.
47.8 mpg best tank, all interstate @ 70 mph ----- 162,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
TSB for clogged heater core / code P2457 inthewoods VW Passat Family (NMS and B7) TDIs (2012+) 71 January 21st, 2018 14:22
2014-2015 TDI fix, see any turbo/gear lag since fix? Reflex TDI 101 0 August 30th, 2017 11:50
P2457 - EGR cooling performance fdhunter VW MKV-A5 Golf/Jettas 8 May 17th, 2017 11:17
Question - Opt for fix, what if no fix, how to get "fix money"? Scott02 Dieselgate - VW Group Emission Scandal 41 September 12th, 2016 19:36
P2457 Code - 2014 Passat TDI TDINJ VW Passat Family (NMS and B7) TDIs (2012+) 2 June 25th, 2015 05:10
Page generated in 0.17588 seconds with 10 queries
[Output: 82.03 Kb. compressed to 71.87 Kb. by saving 10.16 Kb. (12.38%)]
