Old September 15th, 2017, 10:09   #46
jbright
Originally Posted by 740GLE View Post
Mind what you are reporting, EGR flow vs EGR inefficient cooling performance, these are two completely different issues on these cars.
EGR flow (P401) is due to a cracked PDF, a heater core replacement ain't gonna do squat on this.
EGR coolant performance (P2457) is due to the fix flowing more coolant and upping the EGR duty cycle. As is reported in this thread a replaced heater core will correct this issue.
Not to be nit-picky but keeping these small details separate will help someone else down the line.
Thanks. That's why included "more knowledgeable than I am" in my post. This will help me when I talk to them this afternoon.
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed' 10/18.
47.8 mpg best tank, all interstate @ 70 mph ----- 162,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
Old September 15th, 2017, 19:29   #47
add1son
Add another to the P2457 post-fix club. Also threw code P00D5.
Dealer said heat core replacement will fix the issue, like 740GLE indicates.
add1son is offline   Reply With Quote
Old September 19th, 2017, 14:03   #48
XjGhost
TDI(s): Jetta
Add another to the P2457 post fix club. Dropped it off this afternoon to see what they say. I just had the fix done on my 2014 Jetta too.
XjGhost is offline   Reply With Quote
Old September 19th, 2017, 14:08   #49
forrest resto`s
o/k people..please let us know how many miles on the car...and what year?.. were you having problems with heater before?...any codes before?? Please supply more info because this seems to be a consistent problem that should be monitored.. Thanx!
forrest resto`s is offline   Reply With Quote
Old September 19th, 2017, 14:43   #50
craigldavis
TDI(s): 2009 JSW M/T
Maybe add what type of coolant you are using.
I’ve always used only VW original coolant with distilled (or RO water) and never mixed types or brands.
Never had any heater problems and did not get the P2457 code after my fix.
2009 Jetta with 280,000 miles.
'09 Jetta SportWagen TDI MT6
320,000 miles
Last edited by craigldavis; September 19th, 2017 at 22:05. Reason: Clarified coolant mix with distilled water and not mixed any other brand coolant.
craigldavis is offline   Reply With Quote
Old September 19th, 2017, 21:13   #51
jbright
The dealership that did the fix has performed every service on my car since it was new, 152,000 miles ago, including a service at the same time as the fix. I had no sign of a problem with the heater core. The day after the fix I got the check engine light. $1100 of the money I received was spent to pay for a new heater core. . . . . .the car is driving great. I can't really tell any difference in performance and fuel economy. I'm about to fill up the tank so I can start to get an idea if there's any drop in miles per gallon (computer shows little or none).
Old September 20th, 2017, 06:36   #52
740GLE
I'd fight VW to be reimbursed for the $1100.
Old September 20th, 2017, 07:14   #53
meerschm
meerschm's Avatar
agree.
this was not any problem before the fix was applied.
start with the dealer,
call VW customer care and ask to elevate asap.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old September 20th, 2017, 07:38   #54
add1son
My 09 Jetta has about 97K. New timing belt a year ago around 82k, so new coolant with that. No issues with heater / heater core problems prior to the Error code. I should note I also threw code P00D5.
I have contacted customer care and they should be getting in touch with the dealer who performed the fix today, will update.
Old September 20th, 2017, 10:16   #55
740GLE
The fluid change out during a TB job, while helps prevent blockage in a heater core, won't fix any blockage issue if it's already started.
Sounds like people haven't been noticing any issues with their heater cores before the fix. This which makes sense, EGR duty cycle is prob reduced when cheating for better MPGs, so the cooling system may not need to operate as its peak efficiency. You'd still get some cabin heat but it may be only be say 70% of max temp.
But after the fix due to the EGR duty cycle being increased, unless coolant flow is near 100% thru the heater core you may boil coolant in the EGR cooler as its in series, and can't flow enough to cool it down, then up pops the code.
Old September 20th, 2017, 15:23   #56
joshhol
So if the cooling system needs to be at peak efficiency for the fix to work, as soon as the heater core gets some blockage it's going to throw the code again and that will be another $1100 heater core replacement. Is the assumed coolant change interval just to coincide with the TB replacement since it isn't explicitly mentioned in the maintenance booklet?
Is a 60 - 80K coolant change interval too long, allowing for sediment to build up?
Wondering what other longer term effects will the fix have on car systems.
joshhol is offline   Reply With Quote
Old September 20th, 2017, 16:01   #57
93celicaconv
Originally Posted by joshhol View Post
Is the assumed coolant change interval just to coincide with the TB replacement since it isn't explicitly mentioned in the maintenance booklet? Is a 60 - 80K coolant change interval too long, allowing for sediment to build up?
This is a great question. Checking coolant condition (pH, for example) or having a routine flush & refill period doesn't exist in the maintenance booklets (except for checking level and frost protection). Any coolant breaks down over time, and as the pH changes, that starts internal corrosion processes that causes the sediments that causes the plugging (most of the cases). Old DexCool, if the level got low and if air got into the internal cooling chambers, caused excessive coolant breakdown, at least years ago. So I understand the level part. But one has to check pH also, even if the level and frost protection properties are good.
93celicaconv is offline   Reply With Quote
Old September 20th, 2017, 16:15   #58
meerschm
meerschm's Avatar
there have been reports of gunked up coolant in the 2009 cars. (with clogged heater cores)
there is no interval specified by VW. Not even specified as part of the timing belt service.
but if you have one of these early cars, it would seem a good idea to flush the system out when you get the chance, fix or not. not just a drain and fill, but disconnect hoses and flush with fresh water, with special attention to the two coolant loops with smaller diameter hoses.
plenty of folks have had no issues with this, and will say it is not required.
Your mileage may vary.
Mike
Old September 20th, 2017, 19:50   #59
N2UADTDI
I asked the dealer to put the old heater core in the trunk when they replaced it. Was hoping the heater core had plastic tanks that could be taken off. But the whole thing is aluminum. Can't be taken apart easily.
Looking into the in/out ports of the core shows lots of rust. Clogged tubes.
This car has had rust in the cooling system from day 1. I changed the coolant every year using the coolant from the dealer. Mixed 50/50 with distilled water.
Had the dealer do a flush once. I've taken the expansion tank off several times to clean out the rust chunks.
Only once did I ever see this much corrosion in a cooling system. And that car sat for decades with plain water in it.
This was a new car in 2009(late 2008). How did such rust occur? Was there a problem with the block or was the coolant they used contaminated with rust?
N2UADTDI is offline   Reply With Quote
Old September 20th, 2017, 23:09   #60
meerschm
meerschm's Avatar
Good question.
Mike
TSB for clogged heater core / code P2457 inthewoods VW Passat Family (NMS and B7) TDIs (2012+) 71 January 21st, 2018 15:22
2014-2015 TDI fix, see any turbo/gear lag since fix? Reflex TDI 101 0 August 30th, 2017 12:50
P2457 - EGR cooling performance fdhunter VW MKV-A5 Golf/Jettas 8 May 17th, 2017 12:17
Question - Opt for fix, what if no fix, how to get "fix money"? Scott02 Dieselgate - VW Group Emission Scandal 41 September 12th, 2016 20:36
P2457 Code - 2014 Passat TDI TDINJ VW Passat Family (NMS and B7) TDIs (2012+) 2 June 25th, 2015 06:10
Page generated in 0.19124 seconds with 10 queries
[Output: 129.09 Kb. compressed to 108.07 Kb. by saving 21.02 Kb. (16.28%)]
