Old September 7th, 2017, 09:34   #31
740GLE
How much they charging for that?
Old September 7th, 2017, 10:02   #32
forrest resto`s
ditto
forrest resto`s is offline   Reply With Quote
Old September 7th, 2017, 17:41   #33
N2UADTDI
To replace the core costs $800.
N2UADTDI is offline   Reply With Quote
Old September 8th, 2017, 04:51   #34
740GLE
Sounds lot better than $1000s and heat in the upcoming winter should also be a bonus.
Old September 11th, 2017, 18:35   #35
N2UADTDI
Car is back from dealer. So far so good. No boiling coolant in the egr cooler and co CEL.
Here's some pics of the exhaust system after the fix.
Old September 12th, 2017, 05:08   #36
740GLE
nice and shiny, now lets hope you don't in a minor fender bender and the insurance company totals the ride, and you make it to 300K!
Old September 12th, 2017, 08:48   #37
jbright
Originally Posted by N2UADTDI View Post
Update: The dealer called today and diagnosed the heater core as being clogged. The car will be ready Friday.
The same thing just happened to me. I had the fix done last week, along with a 150K service and a CV boot replaced. Picked up the car on Friday. It drove great, with no noticeable differences. The next day the CEL was on. I took it in Monday and they called and told me the egr cooler was clogged and needed to be replaced. They didn't have the parts on hand. I am not happy. I've been a customer with this very big dealership since I bought the car new and they've always treated me well, even though they're expensive.
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed' 10/18.
47.8 mpg best tank, all interstate @ 70 mph ----- 162,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
Old September 12th, 2017, 09:45   #38
93celicaconv
Originally Posted by jbright View Post
The same thing just happened to me. I had the fix done last week, along with a 150K service and a CV boot replaced. Picked up the car on Friday. It drove great, with no noticeable differences. The next day the CEL was on. I took it in Monday and they called and told me the heater core was clogged and needed to be replaced. They didn't have the parts on hand. I am not happy. I've been a customer with this very big dealership since I bought the car new and they've always treated me well, even though they're expensive.
Did you know you had a clogged heater core? Did you have heating problems in past winters?
93celicaconv is offline   Reply With Quote
Old September 12th, 2017, 09:51   #39
forrest resto`s
you really should read his whole thread..he explains in detail...
Old September 12th, 2017, 15:23   #40
93celicaconv
I may have worded my question(s) improperly. What I was trying to ask (which is not in jbright's post) is:
  • Did you know you had a clogged heater core before you brought in your vehicle for the emissions fix?
  • Did you have heating problems in past winters?
I'm trying to understand if the owner knew there was a clogged heater core prior to bringing it to the dealer for the emissions fix.
If clogged heater cores, prior to the fix, did not trigger a CEL, but after the fix, they do, VW did say that the thresholds in the new ECU flash would be different, so it is possible the new flash threshold was lowered and the CEL was triggered after the fix was applied. I'm not sure if a clogged heater core is considered part of the emissions system to be under the emissions warranty extension anyway. I'm sure others in this forum are better versed in knowing this than I.
Old September 12th, 2017, 20:38   #41
jbright
I mistakenly wrote heater core when it's actually the egr cooler (I shouldn't write when tired). I just corrected my post above. My original post is on the last page here: 2.0 Gen 1 post fix impressions, issues, etc. ( 1 2 3)
Old September 13th, 2017, 05:02   #42
N2UADTDI
Yes, I knew there was a heater core problem prior to the fix. What I did not know was that the heater core and the egr cooler are in series. The coolant runs from the engine to the egr cooler and then to the heater core.
A restriction in the heater core was causing the egr cooler to overheat and boil the coolant.
What I am thinking is that the egr system has more exhaust gasses going thru it. Prior to the fix all was well. But the increased cooling load on the egr cooler after the fix caused the system to fail.
Using exhaust gasses in the combustion process reduces NOx formation. And NOx was the issue with the scandal. So it would be reasonable to think that increased egr was one of the primary ways that VW reduced NOx to comply with the emission agreement with the gov't.
The problem I was having with the dealer was that I explained this to the service personnel as soon as I saw a problem after the fix was done. So instead of replacing the heater core they decided the car needed a new cooling system (that did not include the heater core) at a cost of thousands of dollars.
There are 2 egr systems on the VW common rail engine. Low and high pressure. This system that uses the egr cooler is the low pressure system. One side effect of the egr cooler is that hot exhaust gasses warm the coolant in the egr cooler and help the enigne to come up to operating temperature faster.
VWCC said they would not pay for any part of the cooling system. Even in this situation where the fix caused the CEL to come on. From my point of view the 4 year warranty on the fix should have covered this. Look at prior posts. The wording in the warranty is short, clear and concise.
I think it's worded that way so that the car owner is protected from the very thing that happened here. The dealer misdiagnosed the problem. If I did not catch this it would have been very costly and NOT fixed the problem.
VWCC said that they would not pay for any part of the cooling system, even if it causes the CEL to go away. Once again the wording of the warranty is very clear to me. But VW thinks otherwise. The VWCC people I spoke to did not seem to understand any technical aspects of the car.
I can only imagine the group of people sitting at a conference table and coming up with the warranty wording. It is there to protect the car owner. VW will do anything it can to push these costs onto the owner. One case at a time. One dollar at a time. Anything to avoid paying.
And now I see that the DSG transmissions in 2009 cars are not working after the fix. With all the cars they bought back you would have thought they had plenty of opportunity to test out the fix on a variety of cars. High mileage, low mileage, from various parts of the country. To make sure they know all the potential issues that could arise. But that would have cost money.
VW knows exactly what parts go into each car. What software works with what hardware.
This is what happens when the bottom line profit is what their sole goal is. Short term thinking for short term profit.
Old September 15th, 2017, 08:12   #43
jbright
Reporting back. The code after the emissions was fix was, indeed, for egr flow. However, the service rep this morning tells me they replaced the heater core, which was clogged, and that's what resulted in the egr code. 1100 dollars. Hmmm. Anyone more knowledgeable than I am have any thoughts? I'm picking the car up this afternoon and will ask more questions.
Old September 15th, 2017, 08:29   #44
craigldavis
TDI(s): 2009 JSW M/T
I stand by post #2 in this thread.
http://forums.tdiclub.com/showpost.p...24&postcount=2
'09 Jetta SportWagen TDI MT6
280,000 miles
craigldavis is offline   Reply With Quote
Old September 15th, 2017, 08:36   #45
740GLE
Mind what you are reporting, EGR flow vs EGR inefficient cooling performance, these are two completely different issues on these cars.
EGR flow (P401) is due to a cracked PDF, a heater core replacement ain't gonna do squat on this.
EGR coolant performance (P2457) is due to the fix flowing more coolant and upping the EGR duty cycle. As is reported in this thread a replaced heater core will correct this issue.
Not to be nit-picky but keeping these small details separate will help someone else down the line.
TSB for clogged heater core / code P2457 inthewoods VW Passat Family (NMS and B7) TDIs (2012+) 71 January 21st, 2018 14:22
2014-2015 TDI fix, see any turbo/gear lag since fix? Reflex TDI 101 0 August 30th, 2017 11:50
P2457 - EGR cooling performance fdhunter VW MKV-A5 Golf/Jettas 8 May 17th, 2017 11:17
Question - Opt for fix, what if no fix, how to get "fix money"? Scott02 Dieselgate - VW Group Emission Scandal 41 September 12th, 2016 19:36
P2457 Code - 2014 Passat TDI TDINJ VW Passat Family (NMS and B7) TDIs (2012+) 2 June 25th, 2015 05:10
Page generated in 0.15174 seconds with 10 queries
[Output: 134.29 Kb. compressed to 113.17 Kb. by saving 21.12 Kb. (15.73%)]
