Old September 5th, 2017, 07:11   #46
93celicaconv
Originally Posted by Galo View Post
Owain and I have exchanged a few emails over the last few days and....I am now very satisfied I made the decision to 'keep and fix', because the $5.1k will go a long ways towards:
- Owain's Stage 1.....that's all I need/want
- suspension refit, including some nice Konis, an improved rear sway bar, replacing all even slightly worn bushings, tie rod ends, etc
- timing belt change
- fixing my stupid, two year dead radio
- have some money left over for a good celebration
Bottom line: if you can't live with the reduced performance, u can fix that too for about 10% of what VW will be giving you -and have a helluva nice warranty to boot.
I am of the understanding that a fix warranty extension is voided if there is a ECU tune of any type done. I don't know if VW came out directly and stated that in print. Pretty sure that is the case. If one can switch between fix tune and aftermarket tune, if that isn't detectable by VW service, then I suppose it's possible. I'm not aware if Malone tunes can be switched back to factory post-fix tunes - if they can (and if so, how?), I would be interested in a post-fix tune, if a post-fix Malone tune isn't also a neutered tune and can't get back the normal performance these tunes used to do before the emissions fix.
93celicaconv is online now   Reply With Quote
Old September 5th, 2017, 07:20   #47
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Originally Posted by oilhammer View Post
You can also record some engine data, too, for before and after results. However it is important to remember that DPF regen cycles could skew the results if data is obtained in short concentrated events. Long(er) term data gathering is better.
I was/am planning on checking the effects of the fix over 1000 up to 5000 miles, before and after. The before numbers will be a little off due to summer and my wife not driving to school every day. That will also include our summer vacation of about 3000 miles with the bikes on the back.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old September 5th, 2017, 07:28   #48
I think most tuners would agree that if you tune the car you risk detection by VW and voiding the warranty. Even if you flash the ECU back to fixed stock prior to visiting the dealer, they can detect the number of times the ECU has been flashed and may use that as a reason to deny warranty coverage. However, I (and tuners I've talked to) think this is unlikely.
The warranty post-dieselgate applies to cars that are fixed. If you tune the car you should not be eligible for warranty repairs on the emissions system. If you re-flash to stock prior to a warranty visit you are deceiving VW. This may or may not bother some, but it is what it is.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old September 5th, 2017, 07:47   #49
forrest resto`s
Originally Posted by Kevinski4
"So first everyone is angry that VW "cheated", and now that VW fixed it, they are angry that they themselves can't cheat? Got it".
.....no not everybody was angry.I being one that was not angry at all.personally i did not give a hoot.( my opinion only: epa and carb. have gone way overboard on their powers/requirements) my only beef is that the fix..may defeat some of the reasons I bought the car..although me personally am still debating the fix..and also look forward cautiously to vw honoring the ext. warranty to the tee....time will tell!
forrest resto`s is offline   Reply With Quote
Old September 8th, 2017, 16:04   #50
Galo
And here's where my conscience will be fine: VW cheated all of us for a looooooong time, and payback (if needed) will be very sweet.
Galo is offline   Reply With Quote
Old September 8th, 2017, 16:43   #51
tadawson
I'll take a dime . . . If I have been damaged, I've yet to find out how or where . . .
tadawson is offline   Reply With Quote
Old September 14th, 2017, 18:04   #52
dubStrom
dubStrom's Avatar
EPA has a very important goal. I know NOx is not good for our new asthmatic cohort.
But don't forget, the emissions are based on parts per million. If you use LESS fuel, you emit less NOx per mile. And if your miles are on the road, you don't contribute to city NOx.
And personally, I want to use less fuel, so I generate less carbon dioxide. Deniers are dinosaurs.
And by the way...I will "cheat" and lie like I stole it. Use less, get farther. To me, it is NOT about the money.
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline   Reply With Quote
Old September 15th, 2017, 05:20   #53
740GLE
Regardless of fuel consumed, VW was way above grams of NOx/mile threashold set by epa/carb under certain circumstances. Only thing we can really argue is the threshold for a small commuter car vs 3/4 ton or heavy duty diesels is where the EPA went wrong.
Or we can complain about the EPA/CARB turning a blind eye to fine particulate matter form the millions of DI gas engines in real wold driving. With 7K miles on the CARB complaint Alltrack, the tail pipes are quite black.
740GLE is online now   Reply With Quote
Old September 23rd, 2017, 17:43   #54
dubStrom
dubStrom's Avatar
Or we can complain about the EPA/CARB turning a blind eye to fine particulate matter form the millions of DI gas engines in real world driving. With 7K miles on the CARB complaint Alltrack, the tail pipes are quite black.
Oh, yes. CAFE standards are unpopular, but more pertinent to really reducing overall emissions than the NOx standard for passenger cars. And yes, compliant V8s and V6s are a big part of the fleet on US roads. I would include SUVs in that category.
Old January 24th, 2018, 22:36   #55
Miss_Athanatos
Miss_Athanatos's Avatar
what to do after neutered..been reading that some cars are really ruined after mod.. what are our options to fix this?.. according to the description from VW this should not be this bad...loss of power and really dropped mpg's...I have an appointment for my 2011 6mt next week and am seriously concerned that my car will be ruined.....where do we draw the line where the fix does more negative results than VW says it will do..e.g. 4-6 loss of mpg...10-25% loss of power? what will be enough loss that it is unacceptable?? Where/when will we say, or draw a line and say "this is not what is supposed to happen//you have ruined my car..this IS unacceptable"
The option that I am taking at this point is to leave my TDI stock. I don't get the impetus to take the "fix" after practically no development and testing period on the TDIs concerned. A lot of people apparently have a real need for the money offered...I value the car more than the hassle pay for the "fix".
Hope my posts make you smile.
2015 VW Golf SportWagen TDI S, 6-speed manual
2016 3500 Ram Tradesman 6.7L Cummins, 6-speed manual
Miss_Athanatos is offline   Reply With Quote
Old January 25th, 2018, 02:32   #56
Lightflyer1
Lightflyer1's Avatar
Some want the fix for the extra warranty that comes with it. The cash doesn't hurt either. Some will take the cash and just tune it as well.
2015 Beetle TDI.
Old January 25th, 2018, 05:07   #57
This. A tune improves on the original 2015 setup. Once you've driven one of these engines with a good tune it's hard to go back.
Old January 25th, 2018, 06:45   #58
93celicaconv
Just remember, the tune will void your extended warranty you had coming out of the fix. That also has to be a consideration in your cost of the tune.
Old January 25th, 2018, 07:07   #59
Perhaps. But I don't feel this is a big a deal as others do. If I want to take it to the dealer I can have it re-flashed to stock before taking it in. But without the fix, most think component life will be longer than with the fix. So, not much of a gamble.
Old January 25th, 2018, 07:44   #60
93celicaconv
As I understand it, the coding version changes (or rather indexes) with each flash. So if your car left with an emissions flash and came back with the same emissions flash it had when the emissions fix was done, but the coding version was different, VW would reject your warranty (unless VW reflashed and documented the change). You can check with Ross-Tech if you like.
First impressions after fix-NEUTERED! beetlemania Dieselgate - VW Group Emission Scandal 52 August 24th, 2017 13:45
Brandon ruined my... MerelyKarma Ontario 10 July 8th, 2011 11:49
New injectors...Ruined? Sykotyk TDI Power Enhancements 5 October 10th, 2007 15:25
Passat Ruined PlaneCrazy VW B5 Passat TDIs 54 September 15th, 2006 11:47
Does a ruined oil pan mean a ruined pump? cocteau104 VW MKIV-A4 TDIs (VE and PD) 14 January 7th, 2006 14:17
Page generated in 0.18544 seconds with 10 queries
[Output: 139.99 Kb. compressed to 118.38 Kb. by saving 21.60 Kb. (15.43%)]
