Non start
hypno
NM
2004 Beetle 1.9 TDI, 2003 Beetle 1.9 TDI
2003 1.9 tdi fuel shutoff valve short to ground, accelerator relay intermittent are the codes found vehicle will not start any suggestions
AndyBees
Southeast Kentucky
I'd start by checking the 109 Relay. ......... to do so, see if you have 12+ volts at Fuses 32, 34 & 43. If no current on these, the relay is bad.
hypno
NM
Here is latest scan with VGA/vas
Address 01: Engine
3 faults found
18009-relay for supply voltage terminal 30 (j317) p1601 -35-00 - implausible signal
17946- Fuel shutoff solenoid (N109) p1538 - 35-10 open or short to ground - intermittent
16612 - throttle pedal position sensor (G79) p0228 - 35-10 - signal too high - intermittent
Readiness 11011
AndyBees
Southeast Kentucky
Address 01: Engine
3 faults found
Readiness 11011
J317 is the 109 Relay. The 109 Relay is actually "activated" by the ECU (computer). The ECU has power on it even if the Ignition is OFF. It also receives power via Fuse 29 when the Ignition is turned ON.
So, you should check for 12+ volts on Fuses, 32, 34 & 43 as I suggested. If they do not have 12+ volts then the 109 Relay (J317) is not working. If it is not working, either the ECU is not "activating" it or it is bad. Or, Fuse 29 is not providing power to the ECU when you turn ON the ignition.
The other codes may go away (can be cleared) when the first problem is solved!
................................... EDIT.........
17946/P1538 - Fuel Shutoff Solenoid (N109)
17946/P1538 - Fuel Shutoff Solenoid (N109): Open or Short to Ground
Possible Causes
  • Fuel Shutoff Solenoid (N109) Faulty
  • Wiring to / from Fuel Shutoff Solenoid (N109) Faulty
  • Engine Control Module Faulty <<<<<<<<<<<<<<<<< My guess is that the ECU may not be getting power as I suggested above!
Possible Solutions
  • Check Fuel Shutoff Solenoid (N109) using Output Tests <<<<< Test for volts at the Shut-off! Voltage will drop considerably after the Ignition is turned ON, which is normal. Thus, you should have someone turn the Ignition ON while you have the multi-meter there checking for voltage. (Again, voltage will drop off which is normal.)
  • Check wiring to/from Fuel Shutoff Solenoid (N109)
Reading up on P0228 does not indicate a "no-start" situation, only limp mode! Again, fix the issue with the 109 Relay or power to the ECU and this code may be able to be cleared!~
https://www.yourmechanic.com/articl...or-switch-c-circuit-high-input-by-jay-safford
hypno
NM
109
Replaced 109 with new relay, have replaced fuel shutoff valve with new one, vehicle turns over the glo plug signal comes on and vehicle tries to start but does not. Incidentally the fuel shutoff valve is also designated as 109.
AndyBees
Southeast Kentucky
Yeah, but it has a prefix before the 109 (an N).
So, do you have volts at those Fuses?
I've been driving VW diesels over 32 years rolling up near 2 million miles and I have never experienced a bad Shut-off valve or locally know of one going bad. I knew that was a witch hunt. And, likely, the 109 Relay is not the issue either.
hypno
NM
I will check voltage on dues tomorrow, had to stand on my head to change the 109 will be back tomorrow with you then
sisyphus
Appleton, Maine
99.5, '01 A4 Jetta sedans, 5 sp box, Hamman mod, Joey mod, Bilsteins, 2.00" lift
You may want to remove the 109 socket and check that the connectors are firmly seated there. I had one that would randomly not start, showed all symptoms of a failed relay but it was the female connector in the socket. It had been pushed in and was giving intermittent contact on one of the male tabs on the relay switch. Good luck. FWIW, it was a blue wire that wasn't making contact.
mniceracer
mankato minnesota
99.5 jetta 2001 jetta 82 pickup mtdi 92 toyota alh work-in -progress
18009
I`m getting the same fault code(18009)and after researching a lot I found this can be related to many things from air in the system to low alt voltage.
This is in a Toyota pickup Malone did the tuning and all the deletes and I did my own standalone harness but I didn`t use the vw relay I used the Toyota ignition relay to power everything.
The truck starts fine and idles but smokes(blue)and has no power and boost kicks out at 7 pounds.
I had issues with getting this thing primed and running I put an electric pump near the tank and clear line on the return and I`m fairly certain all the air is out.
It`s probably something simple maybe something I did wrong with the harness just wondering if anyone else has had similar issues.
AndyBees
Southeast Kentucky
Mniceracer ... which TDI engine do you have (AHU, ALH, BEW, etc.)?
mniceracer
mankato minnesota
It`s an 02 alh.
Initially I was having problems with #4 now that one is fine and it`s moved to #2.I`ve switched injectors and lines and nothing changes.
I checked compression and #2 is slightly lower(maybe 20 pounds)so how finicky are these engines about compression?
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Well I'm confused. OP was a relay, fuel shut-off, TPS, sounds like you're referring to injectors? I'd take a wild ass guess the OP was a bad 109 or just some wire damage.
mniceracer
mankato minnesota
#2 misfire
ok so here`s an update on diagnostics.
checked compression #1 480 #2 460-70 #3 480 #4 480
I did a leak down and it`s losing some past the rings but barely noticeable on the gauge.
I`ve changed injectors,lines and no change changed the pump and no change.I even bent a spare line to make sure the injectors are atomizing and they are.This engine ran fine on the floor before I put it in and now it doesn`t.
I`ve searched high and low trying find anything like this and nothing.
I don`t know what else to do I desperately need someone to explain to me how I can have comp.and fuel and this cylinder won`t fire.
I`m pretty much to the point that I`m ready to put a different engine in because I really want drive this thing but then I`ll never know what`s wrong.
Matthew0123
Mississippi
04 BEW. 00 alh
#2 misfire
Well did you ever figure out what was wrong with it? I'm having the same issues
BobnOH
not-a-mechanic
central Ohio
5 year old thread. mini has no activity since our forum software update (or longer).
Wire harness r+r common solution for the PD
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,gluten for punishment got another tdi 2001NB,another yellow tdi NB
Bob this is not a pd engine….. it’s about an 03..ALH.
But still a 5 year old thread😉
