Old September 2nd, 2017, 09:38   #46
TDI-T
TDI(s): 97 AHU
Well, I'm finally about to tear into this. The engine is on a stand and ready to be disassembled. One sort of major question:
I can lock my injection pump and cam, but what is the best way to ensure my crankshaft goes in at exactly the right location for the new sprocket I purchased? Just make sure the flat spot of the crank is in the same location? That seems less than precise, but maybe that is the only way?
TDI-T is offline   Reply With Quote
Old September 2nd, 2017, 09:50   #47
flee
Fuel Economy: 40-ish
A simple way would be to fab a pointer for the flywheel mark before disassembly.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old September 2nd, 2017, 10:05   #48
TDI-T
TDI(s): 97 AHU
Any ideas if I don't have a flex plate or flywheel? I've got my harmonic balancer marked with the plastic front cover, but on this conversion you remove the VW flywheel - hence why I marked the balancer.
Seems that balancer is pretty picky about the way it goes on. If I bolt up the new sprocket and use the balancer mark I made will that still be correct?
Trying to double check things before I pull it apart and get lost.
Old September 2nd, 2017, 11:54   #49
jmodge
I believe if you find TDC of #1 piston that is where you want your crank timed. Dial indicator if the head is off, or a stop located in the injector bore or threaded in to the glow plug hole. You could then rotate the engine forward, mark the pully at contact, then backward, mark the pulley at contact, and TDC would be between the 2 points.
Is that help you? Wait awhile, If I am off base or there is a better way, someone will chime in, but I seem to remember someone on the blog mentioning this as working for them.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old September 2nd, 2017, 15:18   #50
TDI-T
TDI(s): 97 AHU
Well, I've currently got it at TDC. I'm wondering how easily I can just drop in the crank, connect the rods and still be close? Once I get the sprocket back on and the harmonic balancer I wonder if that will help me fine tune it?
Can I just move the adjuster pulley to remove the timing belt and then do the reverse to put it back on? I will mark the direction of the belt.
Old September 6th, 2017, 15:57   #51
turbovan+tdi
turbovan+tdi's Avatar
You can use the gp or injector hole and use a dial indicator to find the TDC.
Old September 7th, 2017, 14:37   #52
TDI-T
TDI(s): 97 AHU
Cool. Good to know if I need to. Mains and rods are in, just need to torque down now. Just double checking things first as my bolts are new and I don't want to re-torque them.
Old September 7th, 2017, 15:56   #53
TDI-T
TDI(s): 97 AHU
Is there an order as to which main bearing cap to torque first, second and so on? I don't see one in my FSM? Lots of oil on my new bolts. I hope that is okay? I'm seeing lots of different info during searches regarding oiling the main bolts on an AHU.
Old September 8th, 2017, 13:00   #54
smelly621
I could have sworn my manual had an order specified, but in absence of one you could probably use the same rationale as the cam cap tightening order.
I would be wary of significant amounts of oil on the main bolts - don't want to have so much that you end up compressing it at the bottom of the bolt hole and cracking the block.
I don't think I oiled my main bolts on the ALH. Specified torque + the final 90 degrees seemed quite snug to me.
smelly621 is offline   Reply With Quote
Old September 8th, 2017, 13:58   #55
TDI-T
TDI(s): 97 AHU
Originally Posted by smelly621 View Post
I could have sworn my manual had an order specified, but in absence of one you could probably use the same rationale as the cam cap tightening order..
Thanks for the response! I'm thinking of going 3,2,4,1,5. I wonder if the ALH has an order?
I put a small amount of oil on the threads, but pretty light overall I think.
Old September 16th, 2017, 18:56   #56
turbovan+tdi
Doesn't matter, the crank is loose, it isn't being flattened down by numerous bolts. Start in the middle, end etc.
Old February 8th, 2018, 14:27   #57
andy2
andy2's Avatar
Originally Posted by andy2 View Post
I have used some arp bolts (#524-2801) from a ford 4.6/5.4L flywheel application on my other TDI that used a flywheel from spec clutch.They were a perfect replacement for the stock length vw bolts.I also doweled the crank to flywheel in that case as the flywheel had friction welded itself to the crankshaft when the bolts came loose.
From what I remember the acme flywheel bolts in my case were longer than the factory vw ones so the ford ARP ones I mentioned might not be long enough depending on the flywheel/flexplate being used.
Just an update about the ARP bolts that I mentioned.I ordered the wrong ones and wanted to correct the information that I gave.
Part # 524-2801 (flywheel bolt) is longer than the factory vw flywheel bolt.
http://arp-bolts.com/kits/ARPkit-det...?RecordID=1688
Part # 524-2901 (flexplate bolt) is the same length as the factory vw flywheel bolt.
http://arp-bolts.com/kits/ARPkit-det...?RecordID=1689
andy2 is offline   Reply With Quote
Old February 8th, 2018, 14:50   #58
All Stock
TDI(s): AHU
Out of curiosity how long is that wrong bolt?
I have to use longer than stock for my adapter.
Jeep Wrangler TDI Hybrid...
All Stock is offline   Reply With Quote
Old February 8th, 2018, 21:59   #59
[486]
TDI(s): 02 golf ALH
UHL in the link is "under head length"
ford pinto motor bolts are what I used on my 6spd twin disc ceramic clutch flywheel, 1.15" UHL, longest 10x1.0 I could easily find
Lots of motors used m10x1.0
If the OP hasn't taken his motor apart yet, I'd suggest drilling and tapping the ruined holes out to a larger size. Was thinking of going m12x1.0 (honda) or m11x1.0 (ford zetec) on mine.
[486] is offline   Reply With Quote
Old February 9th, 2018, 14:48   #60
mk3pd
Or even better,use this shim http://rosten-performance.com/produc...ywheel-shim-2/
www.rosten-performance.com
mk3pd is offline   Reply With Quote
Free crank pulley holder tool for torquing crank bolt Shawn MacAnanny VW MKIII-A3/B4 TDIs 2 June 15th, 2017 20:09
timing belt install problem crank moving Victorjay VW MKIV-A4 TDIs (VE and PD) 9 February 16th, 2015 12:34
Want to RENT crank lock and crank seal install tools sangretdi Private TDI Items for Sale/Wanted 3 October 10th, 2013 12:17
bent lower crank pulley? crank snout problems?? 1997 ahu samuraitd TDI 101 13 March 31st, 2013 18:30
Crank Seal Removal/Install Tools BEW ninedee_golf_tdi VW MKIV-A4 TDIs (VE and PD) 12 April 23rd, 2011 16:26
Page generated in 0.16089 seconds with 10 queries
[Output: 131.95 Kb. compressed to 110.51 Kb. by saving 21.43 Kb. (16.24%)]
