Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old May 30th, 2017, 15:48   #31
adjat84th
adjat84th's Avatar
Originally Posted by 2015vwgolfdiesel View Post
Cost? Other info to help this really uninformed guy. Would be nice to have it "spot" on.
Thx
I ran my first ten tanks and compared the actual vs MFD to come up with ~8% difference. The value you adjust in VCDS changes from 100% to 108% (or whatever your calculated difference is). Mine is now consistently within +/- 1mpg every time.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
Old May 30th, 2017, 15:54   #32
Airbus320
Airbus320's Avatar
Fuel Economy: 6.0 L/100
Can you do this with your speedometer as well?
Airbus320 is offline   Reply With Quote
Old May 31st, 2017, 05:39   #33
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Originally Posted by Blue_Hen_TDI View Post
Probably not worth buying (it's $200) if all you want to do are a few tweaks. Just find a local with a VCDS cable and beg and borrow.
http://www.ross-tech.com
Ya
I'm to cheap to pay $200.
But in my dreams
Thanks, again
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old May 31st, 2017, 05:46   #34
tomo366
TDI Lifer
tomo366's Avatar
Actually VCDS is nearer to $300 now....
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old May 31st, 2017, 06:07   #35
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
And VIN-limited too, which really blows. Glad I still have my unlimited cable.
Blue_Hen_TDI is offline   Reply With Quote
Old May 31st, 2017, 20:57   #36
lithgow
So, is it fair to say upper 30's mpg for largely city driving.....and possibly way over 50 if mostly highway? I'm ready to purchase a 2015 Passat and wanted to just confirm....
2010 Jetta TDI with DSG. 1993 Dodge W250 Cummins 12 valve
lithgow is offline   Reply With Quote
Old May 31st, 2017, 22:20   #37
2010golf
Everybody's driving is different. Expect a tad better than the 2010 in your sig. My "fixed" 2015 does 10% better than my stock 2010 both are 6m. A 2015 DSG may be a little more than 10 percent better than 2010 DSG on the highway because of the taller final gear in the 2015.
2010golf is offline   Reply With Quote
Old June 3rd, 2017, 19:06   #38
moorsb
TDI(s): 2015 Passat
Default Idle RPM
I have a DSG auto transmission. I have noticed it idles at 1000 rpm. If i let my foot off the brake at a stop, the car will move forward. Is this normal? I am thinking I will burn out the clutch like this.
moorsb is offline   Reply With Quote
Old June 3rd, 2017, 19:09   #39
moorsb
TDI(s): 2015 Passat
How do you switch between MFD 1 and 2?
Old June 3rd, 2017, 19:14   #40
Blue_Hen_TDI
Yes, that's normal. You're still in drive. You can put it in neutral if you want. Avoiding inching up while stopped is a good practice.
I saw a YouTube video where they monitored clutch pressures in the DSG with the VCDS program at a stop. The car still held a small amount of clutch pressure when stopped in Drive. When shifted to Neutral, the pressure is released to zero. I'm almost certain that the minimal pressure on the clutch(es) while stopped is not going to cause any significant long-term premature wear. I'm assuming the German engineers have worked out a margin of safety.
Old June 3rd, 2017, 19:18   #41
2015vwgolfdiesel
Mine idles at 800 RPM
But when it DOES hit 1,000 MINE is in a re-gen
Hope this helps
Old June 3rd, 2017, 19:33   #42
Blue_Hen_TDI
While we're on regens, I monitor mine with Scangauge II. So far, it's looking like they are occurring about every 250 miles in mostly highway driving and last about 10 minutes. EGR and DPF temps peg at 1200F during that time.
Old June 5th, 2017, 19:15   #43
PD Rig
Default DEF consumption
I have read some speculation that the "fix" to the ea288 will increase def consumption. Just curious as I have just put a deposit down on a leftover myself. It will be my first experience with def. can anyone speak to the change in consumption rate of the def?
PD Rig is offline   Reply With Quote
Old June 5th, 2017, 19:24   #44
tomo366
TDI Lifer
tomo366's Avatar
I am approaching 40K miles service I do not have a Ad blue warning yet! Before this I always get a warning before the service....so mine is actually better!
Old June 5th, 2017, 19:24   #45
Blue_Hen_TDI
Just filled my third tank this evening. 55.2 mpg.
The "I've got the lower mileage" thread... pierreracine VW MKVI-A6 Jetta Sedan (~ 2011+) 8 June 23rd, 2011 10:31
"Recherché" Decembre/December 2007 "Want to buy" Thread Skippy Quebec 41 February 25th, 2008 17:06
"A Vendre" Octobre/October 2007 "For Sale Thread" Goldfox Quebec 9 November 20th, 2007 10:40
"Recherché" Avril/April 2007 "Want to buy" Thread Skippy Quebec 29 June 27th, 2007 18:22
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 06:06
Page generated in 0.14955 seconds with 10 queries
[Output: 132.16 Kb. compressed to 110.47 Kb. by saving 21.69 Kb. (16.41%)]
