Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old May 27th, 2017, 02:41   #16
y2kbird
Fuel Economy: 45-50mpg
Found a new 2015 Jetta SEL 6M Wed, and picked it up yesterday with <50 miles on it. Topped it off to clear fuel in the fill neck right before departing, and after I got home.
Result: 52.27mpg: 559.3 miles, 10.7 gallons used. average speed of 65mph, limited AC. MFD indicated 59mpg average
gauge:
7/8 at 199 miles driven
6/8 at 275 miles driven
5/8 at 373 miles driven
4/8 at 463 miles driven thru refuel point of 559.3 miles
assuming a 15.5 gallon tank, the remaining 4.8gallons would have yielded me only 250 miles at the same mpg, despite the gauge still being on half. So much for a linear fuel gauge.
If VW has it set to indicate Empty with 2gallons left, using 2.8 more gallons / 146 miles would have cleared the second half of the gauge.
y2kbird is offline   Reply With Quote
Old May 27th, 2017, 09:25   #17
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
...snip...
Thanks for your info
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old May 27th, 2017, 09:49   #18
ezshift5
Fuel Economy: Please note Fuelly...........
[QUOTE=y2kbird;5284269]Found a new 2015 Jetta SEL 6M Wed, and picked it up yesterday with <50 miles on it. Topped it off to clear fuel in the fill neck right before departing, and after I got home.
[/QUOTE.
You are off to an impressive start 'bird...............
..............I say this knowing you've got a 'green' (as in not fully broken-in TDI!!
Can't beat the TDI/6M drive train for fuel numbers......(and it will just get better).
all the best hombre
ez
ezshift5 is offline   Reply With Quote
Old May 27th, 2017, 10:58   #19
2015vwgolfdiesel
y2kbird
35 years ago I stopped topping off my 1978 Chevy 3/4 ton van. Not sure, but think it had about a 28(?) gallon tank, and only got 12-ish MPG.
I hyper filled it one time, and had approx 3+ more gallons in after the first automatic pump cut off.
...then it dumped a load of gasoline on cement, 3 foot wide, 8-9 long.
...sure it was more than 1 gallon.
... loss of $$$$s was a concern--- real fear of fire was the quintessential issue; especially if you fill then go straight to your home garage. We had a gas water heater with pilot light in garage area
... thoughts anyone?
Old May 27th, 2017, 14:02   #20
ezshift5
Thoughts? Here's one.........
....hopefully your gas water heater garage installation reflected - even in earlier times - the 18" above grade code requirement..................
ez
Old May 27th, 2017, 15:32   #21
2015vwgolfdiesel
ez
We are up to code, I'm sure as we have replaced the water tank twice, in the last 43 years, living here, by licensed contractors.
By my own volition, I might cram fill my TDi when going on a trip. Trying to judge the amount to over fill it. But filling to go straight to the garage, I will go to the first pump automatic cut off point, then one more single squirt.
Close enough for government work
Old May 27th, 2017, 21:41   #22
y2kbird
Does anyone have a guess of what my mileage would have been in a DSG? Reason I ask is I am looking at a 2nd 2015 for my wife. DSG is more prevalent plus she hasn't mastered driving a manual yet. As far as my taking a risk by filling to the brim--old habit from the Tdiclub monthly mileage spreadsheets. Diesel does not have the flash point as unleaded vapors. A big spill in the garage would be a nuisance more than a fire hazard. I have tested these clear fuel in filler neck fills a block from home and parked it. never had any leak or spray out when I unscrew the cap the next morning. Since the tank is plastic, I suppose if there was a huge rise in outside air temperature between filling it up and storing the car there would be some expansion or higher pressure. If VW can only allow for a 95% fill though, maybe they account for it somehow other than the tiny amount the fuel filler neck holds.
Old May 28th, 2017, 05:47   #23
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
My DSG is doing slightly better than your 6M, but that is likely due to different driving style. I typically drive 60-65 mph (5-10 over posted limit).
2015 GSW TDI S DSG - FrostHeater
2011 BMW 335d - JR 2.8 tuned
Blue_Hen_TDI is offline   Reply With Quote
Old May 28th, 2017, 09:04   #24
2015vwgolfdiesel
Does anyone have a guess of what my mileage would have been in a DSG? Reason I ask is I am looking at a 2nd 2015 for my wife. DSG is more prevalent plus she hasn't mastered driving a manual yet. ..... snip......
IMO...
Driving habits will be the factor.
My city-town is satisfying at mid 40s -- and a lot of it is very short hops -- with multi red lights and stop signs
Old May 28th, 2017, 18:02   #25
RichF
2 fill ups first 37.4 MPG Computer said 43.5
second 44.1 MPG Computer said 46.9
Its obvious the MFI us useless
mixed long island driving
RichF is offline   Reply With Quote
Old May 29th, 2017, 05:34   #26
Airbus320
Airbus320's Avatar
Fuel Economy: 6.0 L/100
(DSG) I haven't fill the tank yet so take this for what it is, but I am 920kms (570mi) into it and so far my avg. Hwy is 4.6 L/100 (51mpg) with 300kms (185mi) to go. When I do city I get anywhere from 4.8-8.0L/100 (49mpg-29mpg) as it varies from low to high traffic. This is still the same rank that my dealer filled for me so it has a huge amount of idle time as they installed phase 1, when I drove home it had 90 km on the tank and 15hr of run time so I think my next tank will be much better.
As long as the numbers from the computer are legit I am really happy, even if they are of 5mpg I still think it's awesome.
Sent from my iPad using Tapatalk
Airbus320 is offline   Reply With Quote
Old May 30th, 2017, 10:03   #27
jjblbi
Fuel Economy: 41ish mpg post fix
Not trying to highjack the thread and just reminding everyone the MFI mileage can be recalibrated via VCDS. I am consistently within .1-.2 mpg calculator versus display at every fill-up. '14 Passat DSG and "unfixed", ~120k miles 44.xx mpg avg.
jjblbi is offline   Reply With Quote
Old May 30th, 2017, 11:51   #28
Airbus320
Airbus320's Avatar
Good to know thanks. I did not need this on the Jetta as it was within .05 of a L but I could need it for the Passat.
Old May 30th, 2017, 12:01   #29
2015vwgolfdiesel
Cost? Other info to help this really uninformed guy. Would be nice to have it "spot" on.
Thx
Old May 30th, 2017, 12:42   #30
Blue_Hen_TDI
Thx
Probably not worth buying (it's $200) if all you want to do are a few tweaks. Just find a local with a VCDS cable and beg and borrow.
http://www.ross-tech.com
The "I've got the lower mileage" thread... pierreracine VW MKVI-A6 Jetta Sedan (~ 2011+) 8 June 23rd, 2011 11:31
"Recherché" Decembre/December 2007 "Want to buy" Thread Skippy Quebec 41 February 25th, 2008 18:06
"A Vendre" Octobre/October 2007 "For Sale Thread" Goldfox Quebec 9 November 20th, 2007 11:40
"Recherché" Avril/April 2007 "Want to buy" Thread Skippy Quebec 29 June 27th, 2007 19:22
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 07:06
Page generated in 0.17142 seconds with 10 queries
[Output: 138.10 Kb. compressed to 116.32 Kb. by saving 21.78 Kb. (15.77%)]
