Tdijarhead
- Joined
- Nov 10, 2013
- Location
- Lawrenceville PA
- TDI
- 2003 TDI Jetta Daughters Car, 2001 TDI Beetle, Wife’s car, 2005 Golf TDI Mine, all 5 spds
Well it happened to me. Something got inside the timing belt cover and momentarily jammed the belt. I'm missing about 8" of teeth. I was so sure when it quit that it couldn't be the belt, yes I looked at as much of it as you can alongside the road with no tools and a dog collar in place. It seemed tight and the teeth I could see were fine.
I was on a hill so I even tried poping the clutch. A friend towed it home Thursday night and I let it set till yesterday. I pulled the timing cover and this is what I found. Debris field.
After I got the belt off you can see the damage.
I'm not sure what it was or how it got in but the damage is clear. I was about 65k miles on this belt, the water pump , roller and tensioner are all in good shape no failures there. I was planning on doing the belt in late September to mid October when I would hit the 80k mark.
So I've found an engine and I think I'm just going to swap engines. That way I'll have all kinds of extra parts , turbo, tandem pump, egr, etc,etc.
Anybody want to share from their past experience what the object might have been? I'm thinking small rock. I found nothing in the pile of debris, other than teeth.
About three weeks ago I adjusted my torsion a bit. That's the only time the cover has been off in over a year. Could something have fallen in then and stayed out of the belt path for three weeks?
