Old May 10th, 2017, 08:18   #46
eddie_1
eddie_1's Avatar
Cool. Any chance to show a log of MAF?
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old May 10th, 2017, 09:43   #47
Rub87
1400 kg/h from 3750rpm approx til redline
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old May 10th, 2017, 10:08   #48
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
Originally Posted by diffas View Post
Soo what we see here is a video that is fastened up and sound is still the same speed and therefore all is out of sync. Even an blind man can see that. :P
First of all .
That sound is distorsion caused by whatsapp !!video was sended with the app ,then uploaded!
Second ,video was made on straight road !
Now..I don't care of neither of you ,from my part I wish you all success in building fast diesels with power to move the planet !!
All I want is to keep me out of yours accusations and discussions.
Lucian189 is offline   Reply With Quote
Old May 10th, 2017, 11:55   #49
diffas
diffas's Avatar
To be honest I don't care if you have faster than speed of sound car or not. Conclusion is made by given "evidence".
diffas is online now   Reply With Quote
Old May 10th, 2017, 23:19   #50
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Its obvious that this video on youtube is not valid.
Don't feed the troll....
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old May 11th, 2017, 04:02   #51
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
I've heard yesterday of a reasonable bigger number, but gonna keep quiet till i see the drag racing results this weekend, see how it goes.
5xxhp A6 should do a nice 11.x seconds. Car is 1800+ kg, driver 85kg minimum
Get your popcorn!
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old May 11th, 2017, 04:35   #52
Rub87
Stock rs6 does 11.7 or thereabouts iirc.
Old May 11th, 2017, 08:31   #53
xjay1337
Get your popcorn!
1/4 Mile speed or VCDS log is a more accurate performance indicator than a speedo recording, I'm sure you can agree.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old May 11th, 2017, 08:34   #54
Rub87
https://youtu.be/bA6KM2DQYYw
Here is video from emp. 2.5-2.6 bar at 4k. This was still when it had stock inj, 370hp at that time, no more fuel avail.
Old May 11th, 2017, 11:48   #55
Macradiators.com
100-200 with racelogic 10Hz is pretty accurate also
or 402m drag
this car below has done a huge leap in hp they say, results in 2-3 days
387hp measured on a more than accurate dyno, 430 on tuner's dyno
https://www.youtube.com/watch?v=m6hC6EThLnA
CP3 Upgrade
Old May 11th, 2017, 12:45   #56
raffshore
or 402m drag
these youtube videos mean nothing to me. When mine had still the speed limiter it would go 264 on the speedo and 249 in vcsd. Meaning that you actually have no clue what speed you really have when you see 100 on the speedo.
Even a 400M drag... what does it mean? Driver response time is a factor, has nothing to do with the car.
Like boby says, log with time stamp
Anyway on the same dyno a standard bi turbo makes 411hp and then everything is maxed out (and sky-high egt's)
If somebody wants to put my car on another dyno, no problem for me.
raffshore is offline   Reply With Quote
Old May 11th, 2017, 12:54   #57
raffshore
Originally Posted by Lucian189 View Post
First of all .
I understand what you say, but it all started when somebody wrote here that 11.x seconds for a 100 to 200 is a very very long time. I am sorry but 7,5 seconds seems almost impossible
Old May 11th, 2017, 13:51   #58
diffas
diffas's Avatar
It's not that hard to get accurate results from the video (unless its a potato) once you know your gear+diff ratios and tyre perimeter.
Old May 11th, 2017, 21:40   #59
raffshore
worth looking :
http://gonzzz6.wixsite.com/performan...200-km-h-times
Old May 12th, 2017, 02:38   #60
xjay1337
I'm not sure about european drag strips but in the UK reaction time does not impact the ET time.
The 1/4 mile terminal speed is a good indicator of performance.
World Record MPG TDI For Sale Beeah TDI Cars for Sale/Wanted 0 April 14th, 2010 00:13
New Guinness mileage Record TDI/Goodyear fgbrault VW MKV-A5 Golf/Jettas 9 August 21st, 2009 19:59
TDI speed record Jester General VW Discussion 2 April 28th, 2009 13:15
TDI Reliability Reputation/Record Rickdude TDI 101 30 September 11th, 2005 19:14
TDI Land Speed Record suffeks VW MKIV-A4 TDIs (VE and PD) 35 January 20th, 2004 13:21
Page generated in 0.18863 seconds with 10 queries
[Output: 133.90 Kb. compressed to 112.02 Kb. by saving 21.88 Kb. (16.34%)]
