Old April 25th, 2017, 23:13   #1
raffshore
Default 3.0 TDI CLAA 461HP/885nm new record?
thanks to Rub87 !!!
I wasn't expecting this !!!
raffshore is offline   Reply With Quote
Old April 26th, 2017, 00:47   #2
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Very nice result Raf
You have the graph?
Im not aware of any 3.0 TDI VAG more powerful tbh.
Ruben done a great job.
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Old April 26th, 2017, 00:53   #3
raffshore
You have the graph?
Don't you see the graph?
https://lh3.googleusercontent.com/wZ...=w1222-h916-no
Old April 26th, 2017, 02:11   #4
DkZ
Fuel Economy: 7.5 / 6 / 4.5
I cannot see the graph
DkZ is offline   Reply With Quote
Old April 26th, 2017, 02:30   #5
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Nor can I.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old April 26th, 2017, 02:58   #6
Rub87
here it is. to be honest I was a bit plesantly surprised as well. overlay is another 3.0 tdi (258 hp base engine) with same inj, pump, railpressure, boostpressure, intercooler, exh backpressure. the only difference being the compressorwheel in the .. both turbo are ball bearing with special breed 49mm turbine wheel.
engine maxes 1400kgh maf sesnor out starting from 3700 rpm.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old April 26th, 2017, 03:17   #7
DkZ
Awesome curves ! that power is linear from the start to the end, should be amazing to ride that baby, congrats !
Old April 26th, 2017, 04:02   #8
bhodgkiss
Is this an auto?
What mods? Just turbo(s)?
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old April 26th, 2017, 04:06   #9
Rub87
inj, hp pump, intercooler, downpipe, turbo, ..
its a dsg dl501 with SSP clutches
Old April 26th, 2017, 05:21   #10
raffshore
To Humble you forget your programming...
Old April 26th, 2017, 05:26   #11
Rub87
thats just the sauce on the fries
Old April 26th, 2017, 09:38   #12
raffshore
don't forget the special RS6 air filter, which is good for 30HP
Old April 26th, 2017, 10:25   #13
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Very nice! So you're gonna make us guess at the hardware details??
Old April 26th, 2017, 10:36   #14
raffshore
Only the turbo is hybrid, wagner intercooler, dpf delete pipe, All the rest is standard VAG stuff, All PNP
and SSP clutches off course
Old April 26th, 2017, 11:34   #15
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
49mm turbine wheel is quite tiny...
World Record MPG TDI For Sale Beeah TDI Cars for Sale/Wanted 0 April 14th, 2010 01:13
New Guinness mileage Record TDI/Goodyear fgbrault VW MKV-A5 Golf/Jettas 9 August 21st, 2009 20:59
TDI speed record Jester General VW Discussion 2 April 28th, 2009 14:15
TDI Reliability Reputation/Record Rickdude TDI 101 30 September 11th, 2005 20:14
TDI Land Speed Record suffeks VW MKIV-A4 TDIs (VE and PD) 35 January 20th, 2004 14:21
Page generated in 0.19971 seconds with 10 queries
[Output: 128.59 Kb. compressed to 107.50 Kb. by saving 21.09 Kb. (16.40%)]
