Old April 9th, 2017, 18:38   #1
nitec
TDI(s): 1.9TDi PD
Fuel Economy: What's fuel economy?
Default Eurotrash Motorsports: W8 4Motion to BHW swap
Folks,
this has been a long time coming...The W8 base belonged to a long time TDiclub member - Fitzski...I've been on his case to sell me his W8 4Mo 6spd wagon for at least 3 years before he finally crumbled under the pressure. It then took me 2+ years of sorting out other projects before I found a suitable donor...long story short we started this project today and I`m really excited about it
The plan is fairly straight forward - complete BHW swap out of a B5.5 using all stock setup swapped into the B5.5 Wagon using the OEM O1E manual transmission - that's it. I'll build this for my mom or to sell so no Holset madness on this project
I've noticed there really isn't a good W8->TDi thread so hopefully this will help document the process a little better...
on with the pictures:
Here's the W8
Here's the extremely clean donor (short of a leaking valve cover gasket)
intercooler bracket needs to be moved over
this is where we stopped today
only things left to do before we pull it all out tomorrow are disconnect the driveshafts and the transmission shifter
nitec is offline   Reply With Quote
Old April 10th, 2017, 18:19   #2
nitec
TDI(s): 1.9TDi PD
BHW's out...
it's a chain drive BSM - I think the consensus is the leave it alone?
I've got a few gaskets to replace and then it's ready to be dropped in...the W8 is coming out next...
realized pretty quickly that the BHW AC will not work in the W8 so I`ll have to figure out a way to mount the W8 AC compressor to the BHW - perhaps using the BPW bracket from the Audi will work?
Old April 10th, 2017, 18:26   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
For the chain drive - the consensus is to delete it using an ALH pump.
What are you using for a clutch?
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old April 10th, 2017, 18:29   #4
nitec
TDI(s): 1.9TDi PD
oh yeah? the BSM works fine for now - I`ll look up the procedure...it is just a matter of unbolting it and bolting up the ALH pump? there was some hole that needs to be plugged right?
clutch is likely going to be single mass Valeo kit...works great on my B7 so no reason not to use it...I was thinking of getting a dual mass but can't seem to find a reasonable kit for it...
Old April 10th, 2017, 19:25   #5
nitec
TDI(s): 1.9TDi PD
is the BHW sprocket unusable? I've got the whole BRM assembly but don't feel like pulling the sprocket if I don't have to
Old April 10th, 2017, 20:01   #6
dogdots
dogdots's Avatar
TDI(s): None
You have to
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old April 11th, 2017, 02:39   #7
Windex
Windex's Avatar
Sprocket is different. Original design is weak on the chain/sprocket/guide, as well as the hex shaft which drives the oil pump - both will trash your engine. Guide here:
http://pics.tdiclub.com/data/3419/BH...eplacement.pdf
that guide is for replacement with a ($$$) geared module, same procedure to install the delete kit shown here:
http://www.cascadegerman.com/product...ft-delete-kit/
Old April 11th, 2017, 11:47   #8
otty
otty's Avatar
Watching with interest! Still a few wiring issues with my swap but some may be different than yours given the AVF engine/ECU in mine.
Malone tuned stage 1 and loving it!
otty is offline   Reply With Quote
Old April 12th, 2017, 08:57   #9
nitec
TDI(s): 1.9TDi PD
hmmm...the engine is really clean so I was hesitant to get into big tear down exercises but I think this is worth doing...I've already got a few oil pumps kicking about so should be ok - will need a new sprocket though that's for sure...
My parts list is shaping up like this:
- front and rear crank seals
- oil pump sprocket
- BRM (or BEW or 1.8T oil pump)
- Valeo 228mm SMF clutch
- 1.8t pilot bearing
- valve cover and tandem pump gaskets
- oil filter housing gasket
that's about it...was thinking of taking the intake and turbo off to chance gaskets there too but again - everything looks new so I`ll leave it at that...
am I missing anything in the "while in there" category?
Old April 12th, 2017, 09:43   #10
nitec
TDI(s): 1.9TDi PD
otty - I'm curious...what did you do about your AC?
Old April 13th, 2017, 11:46   #11
otty
otty's Avatar
AC is not working currently. It is somehow not wired correctly and I haven't figured it out...
Old April 13th, 2017, 13:22   #12
Mikkijayne
Mikkijayne's Avatar
TDI(s): Audi S8
Fuel Economy: lol
Can't you just swap everything under the hood from the BHW in to the W8 body - pipework, condenser, drier & compressor? The point where the lines enter the cabin is standard so as long as you swap everything it should all be fine surely?
The AC controller in Audis can be coded to either mag-clutch or internal valve so I would assume the Passat one is exactly the same if thats the issue?
Pecuariam felis
Mikkijayne is offline   Reply With Quote
Old April 13th, 2017, 16:26   #13
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Single mass flywheel clutches are documented to destroy 01E synchros in short order. Good luck with the build. Do something mad with the leftover W8 engine. A straight exhaust alone brings out the single plane V8 Ferrari-like sound. Search YouTube to see/hear what I mean.
Old April 13th, 2017, 18:42   #14
nitec
TDI(s): 1.9TDi PD
yeah I read about the SMF 01E situation...not sure how I feel about it - my B7 uses the same style transmission and it runs like a charm with the 228mm SMF...I find it a little hard to believe the "strongest" Audi transmission that people use behind all of their high HP turbocharged motors with SMFs fails just because it's mounted to a diesel engine where an O1A apparently doesn't...I dunno - every other option costs twice as much so I'm pretty sure I'm going down that path anyways...I wonder how many O1Es/SMF sets have actually failed and how long each one took...
MJ - interesting...I wouldn't think you can do that with VCDS? I've got a few different brackets to try out over the next few days to see if I can get the W8 AC mounted to the BHW the same way I did it in the B7...there's no issue mounting it the same way that the BHW was mounted - the only problem is the clutch activation so if you think that can be adjusted then it may be pretty straight forward...
otty - do you have a pic of your AC setup? I suspect the previous owner kept the BHW setup, which doesn't work with the W8...perhaps MJ will help us with out with this
Old April 13th, 2017, 20:09   #15
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
One of these in your straight-piped W8 engine would be simple mental.
http://www.ebay.ca/itm/291973493410
2003 Passat W8/BHW 2.0Tdi Swap Machineman TDI Conversions 51 June 4th, 2017 14:58
Eurotrash Motorsports - Audi A4 OPRC / Targa TDi nitec TDI Conversions 195 October 15th, 2016 14:32
Eurotrash Motorsports TDi Dyno Day - May 7th, 2016 nitec Events, Gatherings, Clubs 8 April 12th, 2016 22:30
BHW swap into a W8 6MT wagon? PassatTDIesel TDI Conversions 13 March 1st, 2016 11:29
B5.5 W8 4Motion moosejaw Sightings 6 January 20th, 2016 07:52
Page generated in 0.15679 seconds with 10 queries
[Output: 132.36 Kb. compressed to 110.35 Kb. by saving 22.01 Kb. (16.63%)]
