New to me mk4 Jetta TDi
h4vok
Denver (ex MN)
2003 Jetta TDi 5sp 171k
H4vok's mk4 Jetta TDi
First post on the forum. I have learned a lot here already though.
2003 5sp manual 148k
I have only owned it for a few weeks, but this is what I have so far.
Mods/maintence added in this order:
-Malone Eco Tune with Dynamic EGR
-Diesel Toys oil pan skid plate
-turbo back straight pipe to MangnaFlow 35134 tip (mufflerectomy)
-JVC KD-X50BT deck
-5 brake light mod
-Spal 6.5in fan on the intercooler
-DLC520 nozzles from DBW
-G2 boost valve (dawes device)
-VDO boost gauge with steering column pod
-polk 651 speakers
-Shifter bushings with DieselGeek ones
-MPPS v16 cable (customized the malone eco tune in edc15 suite to around 110whp 170wtq @17psi)
-155k Timing belt service using Gates belt kit and conti serpentine belt kit. All new rollers/tensioners, water pump, alternator pulley, and
thermostat. (Done by GreenGeeker)
-New vacuum lines as well
-Ventectomy
-Thermo T delete using 842/3 filter and stainless 5/16 fitting
-Poly swaybar bushings + endlinks
-Control arm bushings TT rear, oem front
-Ball joints
-Full tie rods
-shorter antenna
-FrostHeater
-Front strut mounts and bearings
-CTS dogbone mount
Mods to come:
-springs/struts
-vr6 clutch
-vnt15/17 from DAP
Lessfilling_runsgreat
Walnut Creek, CA 94598
1998 Jetta - RIP (Rest In Pieces); 2003 Jetta TDI GLS
Nice car! I have a Galactic Blue 2003 that looks identical to yours except for the exhaust tip. I did a stage 2 chip (can't remember whose) and 520 injectors. A little smoke, but not rolling coal. 45+ mpg while averaging 75 to and from work. I also have a Bora Sport TDI cluster from UK I'm trying to adapt. Enjoy your ride!
