Old August 22nd, 2017, 18:25   #31
Strider17
TDI(s): MK4 and MK5
Figured out the fuel pump codes too
I plugged in my vcds, went to the central electrical module, went to Long coding and there is an option that was checked off something to do with a fuel pump (gasoline only). I unchecked that and the code went away.
I am still going over all the wiring to see if everything is wired up correctly before I wrap it all up
But looks like I am finally done.
Strider17 is offline   Reply With Quote
Old August 22nd, 2017, 18:27   #32
Strider17
TDI(s): MK4 and MK5
With regards to the fuel pump relays for the TDI (double 449):
TDI pins 3 & 32 (2.5l pins 1 & 6) go to fusebox C fuse 27 (15A)
TDI pins 1 & 12 (2.5l pins 3 & 8) go to fusebox B fuse 15 (5A). Fuse 15 also feeds the glow plug control module pin 6 (as you noted)
NOTE: on the 2.5l, pin 3 was/is connected to fusebox C fuse 2 (5A) via a black/violet wire.
TDI pin 5 (2.5l pin 2) goes to the transfer pump in the tank
TDI pin 52 (2.5l pin 7) goes to the auxiliary fuel pump pin 2 on the engine
NOTE THAT PINS 2 & 7 ON THE 2.5l ARE CONNECTED TOGETHER IN THE WIRING HARNESS AND YOU WILL NEED TO SEPARATE THEM OR RUN A SEPARATE WIRE TO THE AUXILLIARY FUEL PUMP IF USING THE 2.5l HARNESS
TDI pin 2 (2.5l pin 5) goes to pin 46 on the 94 pin ECU connector
TDI pin 22 (2.5l pin 10) goes to pin 15 on the 60 pin ECU connector
The actual wire colours don't matter, just make sure they're connected as I have listed according to the wiring diagrams.
Basically the TDI uses the two 449 relays independently to run the tank and auxilliary fuel pumps via ECU control (ECU pins 46 & 15).
Whereas the 2.5l uses them in parallel to run the tank fuel pump and the high side of the injectors via the ECU & Vehicle Electrical System Control Module.
Old February 26th, 2018, 16:04   #33
dieselherb1
I talked with you last about your swap. I'm doing a CR into a 06 MK5 tdi. Have everything wired( I think) have it running but in limp mode. Any thoughts?
dieselherb1 is offline   Reply With Quote
ALH in a 2.5L MK5 Jetta turbocharged798 TDI Conversions 2 August 9th, 2016 07:27
MK5 TDI Gurus? jeff_vapelane Ontario 9 February 6th, 2015 14:13
Stock dpf 2.0cr from a MK5 jetta zxcv1000 Private TDI Items for Sale/Wanted 2 May 2nd, 2014 15:27
DIY: MK5 steering wheel on MK4 witchcraftz TDI 101 1 November 7th, 2013 08:12
:: ECS Tuning :: Schwaben Mk5 2.5L / TDI Brake Rotors - Blowout Pricing !!! ECS Tuning Vendor & GroupBuy items for sale 4 January 13th, 2011 01:02
Page generated in 0.12097 seconds with 10 queries
[Output: 59.25 Kb. compressed to 54.08 Kb. by saving 5.16 Kb. (8.71%)]
