Old February 20th, 2017, 18:30   #1
MrShip
Fuel Economy: 6.2 L/100km
Default EA288 DPF Ash Loading
I've been tracking my DPF loading ever since I got VCDS. I'm curious to see if the graph will change much after the Phase1/Phase 2 fixes.
Currently it looks like I'll fill up my DPF (80g) around 330,000km.
Here's the raw data so far:
Code:
Date Mileage (km) Ash Load (g) Ash Volume (l)
2016-09-06 55121 13.4 0.03
2016-10-11 59676 14.4 0.03
2016-11-27 64747 15.7 0.03
2017-02-15 74946 18.2 0.04
Ash load can be measured in: Engine -> Advanced Measurement Values -> IDE06059. Ash volume is IDE00433.
Anyone else have results to share?
MrShip is offline   Reply With Quote
Old February 21st, 2017, 15:25   #2
adjat84th
adjat84th's Avatar
I'd be curious to see what our wagon gets. It's a 6MT but does a lot more short trips. Almost 40k miles on it, and just got the fix a couple weeks ago. Has been flawless so far though. I really like the advanced measuring values the newer cars use too btw. Being able to log 12 values at once is pretty neat IMO.
Hopefully the cars being turned in will find their way back into the market, and we'll start getting some more activity here in this subforum...awfully lonely in here with most folks opting for the buyback
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old February 24th, 2017, 13:20   #3
Union
TDI(s): A3
My 2013 mk7 2.0 golf with 27k miles has 10g. If I am reading VCDS correctly it has not done any regen's yet!!!!
Union is offline   Reply With Quote
Does my EA288 do DPF regens? Mark Hubley VW MKVI-A6 Jetta Sedan (~ 2011+) 16 May 6th, 2016 18:34
CR170 DPF soot loading rates: standard vs. Stage 1 muddyboots TDI Power Enhancements 7 July 1st, 2015 04:26
DPF Ash Volume Reset? sdlucky7 TDI (Diesel) Emissions 7 June 22nd, 2015 19:55
DPF Ash Source Bob_Fout TDI (Diesel) Emissions 16 January 28th, 2014 07:40
Ash in my DPF Jim'stdi VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 October 30th, 2010 19:33
Page generated in 0.15486 seconds with 10 queries
[Output: 58.82 Kb. compressed to 53.54 Kb. by saving 5.27 Kb. (8.97%)]
