shoebear
- Joined
- Aug 1, 2002
- Location
- Colorado Springs, CO
- TDI
- 1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
While doing research for a possible HID projector upgrade for my 2003 Jetta wagon, I found found many posts saying that headlight projecters are designed differently for halogen vs HID, and that it would be bad to install HID bulbs into halogen projectors. This didn't make sense to me -- a projector is a projector, right? But nobody that I found actually said WHAT was different.
So now I've educated myself, and I'm here to explain it to you. In a nutshell, a projector designed for halogen bulbs concentrates the light in a spot directly ahead, while HID projectors cast a fairly even semi-circular flood.
Here's the headlight pattern from my 2005 New Beetle factory halogen projectors:
Here are some examples of HID projector patterns. These are all e-code beam patterns, but a DOT beam pattern would have the same even flood of light, just in a different shape. Some of these projectors are a bit out of focus and exhibit a darker center. This is probably a quality issue with the projector or bulb, but it might be correctable with a thin spacer between the bulb and the projector (or a spacer might make it worse).
I ordered some headlights off eBay advertised as HID for my Jetta wagon. I found that they had a DOT halogen projector, not the e-code HID pattern I was expecting. A dead giveaway is the electrode shadow -- an HID projector would spin the bulb to get the electrode out of the beam. Since the projector lens flips everything upside down, this photo shows the electrode on top. Putting the electrode on the bottom would eliminate the shadow. Note the DOT pattern: mostly flat on top with just a little step up on the right.
So what's wrong with putting an HID light into a halogen projector? Here's where I speculate a bit. An HID bulb puts out 3-4 times as much light as halogens. So halogen projectors focus the light in a spot up front, where you need it most. By contrast, HID emits enough light to create a flood and still illuminate directly ahead sufficiently.
Flashing your lights in other drivers' eyes, even with properly adjusted projectors, is sometimes unavoidable, especially in hilly areas. With regular headlights and halogen projectors, the light will be annoying, but not blinding. But if you have an HID bulb in a halogen projector, most of the light from the HID bulb will be concentrated in a spot. This is enough to blind other drivers if the beam hits them.
If you have a set of projector headlights designed for halogen, and you want to upgrade to HID, you can do so by getting a pair of salvage HID projectors that fit your headlights. While the details of this are beyond the scope of this post, you can get info and projectors from a place like The Retrofit Source, or hit the junkyard and scavenge projectors from high-end cars. Replacing the projectors will probably cost roughly $50-$150 and will require removing the headlight lens to get access to the projector.
When I was trying to figure this out, one theory I had was that halogen and HID bulbs place the light source at different distances from the base, so that installing the wrong bulb would result in an out of focus beam. This turned out to be false. When I tried halogen and HID bulbs in the same headlight, I got the same beam pattern either way. Also, this photo shows that the light sources are pretty much the same distance from the base either way.
Here's a link that shows the difference between a DOT and e-code (ECE) beam pattern: https://www.retrofitlab.com/blog/dot-vs-ece-beam-pattern/
I hope this helps someone -- I couldn't find this info explained plainly anywhere else.
