Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old February 18th, 2017, 11:45   #46
GoFaster
Moderator at Large
Yes, the smaller engines are at higher specific load more of the time and that means more operation in enrichment.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old February 18th, 2017, 12:07   #47
whitedog
So it makes me wonder if these smaller engines can pass the emissions test, but actually put out higher pollutants in Real World Driving than a larger engine working less hard and not going into the enrichment operation. Magic 8 Ball says, "Signs point to Yes."
Old February 18th, 2017, 16:19   #48
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
And that's why downsizing is being reversed, now, in Europe, where this has been taken to extremes.
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline   Reply With Quote
Old February 18th, 2017, 18:55   #49
whitedog
And if I had read the article, I would have known that.
Old February 19th, 2017, 06:44   #50
tikal
Fuel Economy: 37 MPG (~ 45% city)
Default Not so "clean gasoline vehicles" either
Here is an overall comparative graph with the so called "Clean Gasoline vehicles" and "Clean Gasoline-Hybrid Vheicles" vs the BMW X5 35d and other types of passenger vehicles:
Originally Posted by wxman View Post
You're welcome, tikal.
Thanks to a comment by bhtooefr, I searched for, and was able to find, a document that provided damage cost factors for both urban and rural emission scenarios, albeit it is calculated for Ireland ("Air Pollutant Marginal Damage Values Guidebook for Ireland 2015"). I'm still not able to run the APEEP model, which would still probably provide the best estimate of each vehicle technology/fuel pathway.
GREET provides total and urban emissions for both WTW and vehicle manufacturing. Thus, urban and rural damages can be calculated individually (rural emissions calculated by subtracting the urban emissions from the total emissions), and a "composite" damage derived from combining the urban and rural damages.
Using that methodology, here is a graphic of the results I get:
This shows EV in a better light, especially if it's a very clean grid like California (virtually no coal generation), since a higher percentage of emissions are generated in rural locations.
Edit: The "Diesel @X5" uses the average overall "real world" exhaust emission profile of the BMW X5 35d measured by WVU in the ICCT report.
tikal is online now   Reply With Quote
Old February 19th, 2017, 07:42   #51
GoFaster
Moderator at Large
Are those graphs extrapolated from emissions established during something akin to EPA test procedures, or are they established from "real driving emissions"?
Brian P.
Old February 19th, 2017, 08:06   #52
GoFaster
Moderator at Large
An empty and gently-driven Ford F150 3.5 Ecoboost will probably use less fuel than an empty and gently-driven Ford F150 5.0 V8.
Hitch up a big trailer, and everything changes.
There are some engineering changes that can be done to control piston and exhaust valve and catalyst temperature and we are starting to see them in newer engine designs. The trickery is being able to raise the compression ratio without encountering knock while still being able to use a premixed charge (to minimize soot formation).
Example 1 http://newatlas.com/toyota-tnga-engines/46830/ 13:1 compression ...
Example 2 http://motorchase.com/en/2016/09/fia...nes-in-brazil/ This engine has many interesting design features. 13.2:1 compression ... and without direct-injection and without 4 valves per cylinder, just a well-optimized twisted-hemi 2 valve design.
Example 3 http://www.allpar.com/mopar/V6/PUG-2015.php 11.3:1 compression ... this wasn't a ground-up redesign like the above two were.
Brian P.
Old February 19th, 2017, 09:24   #53
atc98002
atc98002's Avatar
Can't say for every column, but wxman noted at the very bottom that the X5 diesel was real world testing from the same university that started the mess for VW.
2018 Subaru Outback 3.6R Touring
2005 Ram 1500
2013 VW GTI: daughter
2010 Routan gone, replaced with 2018 Pacifica Hybrid: other daughter has 3 kids
atc98002 is offline   Reply With Quote
Old February 19th, 2017, 09:39   #54
wxman
TDI(s): Other Diesel
The "vehicle operations" damages are based on emission factors established by EPA (see http://greet.es.anl.gov/files/vehicles-13 (Tables A2 & A3)).
The past few versions of GREET have started to deviate from the EPA emission factors somewhat, as can be seen in this screen capture of the GREET1_2016 output file:
Please note that the assumed NOx emission rate is still almost twice the T2B5 FTP "regulatory limit".
wxman is offline   Reply With Quote
Old February 20th, 2017, 04:26   #55
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
And don't forget the Yaris engine linked above (or here) - 13.5:1, with port injection, and I've seen claims that it's set up for 90 RON, so worse than the fuel available here.
Old February 20th, 2017, 04:28   #56
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yep, but Ford realizes better who is actually buying and driving their trucks, and how they are using them....which is the vast majority of the time mostly empty. So who cares if the fuel economy tanks that 2% of the time the truck actually gets used as a truck?
I live in the middle of truck country, F150s are like mosquitoes here. Rarely do you see one loaded down with any sort of load nor see one towing a heavy trailer. Heck, we service fleets of F150s that never, ever see any kind of load coming even close to what even a half-ton truck could handle. For those people, a V8 is pretty useless. Even the Ecoboost options are overkill, most get by just fine with the standard 3.7L (and now 3.5L, and soon to be 3.3L) naturally aspirated V6.
oilhammer
www.cardocautomotive.com
Old February 20th, 2017, 07:49   #57
NSTDI
Oilhammer, are the smaller engines better on fuel than the turbo V8 or the V8's in real world driving with similar loads- mostly none?
Don
1998 Beetle TDI, 325,000 KM, Upsolute (sold), 2003 Passat 1.8T, 340,000KM Upsolute (sold), 62 Bel Air 409, 4 speed, 1963 Parisienne 409 4 speed
2013 Passat 6MT TDI Comfortline with Sport, Sept 18/12 New. Buyback at 150,000 KM's June 2017. Replaced turbo, sway bar links front and rear, Adblue heater went.
2015 Passat, Highline, 6MT, new June 2017. June 2018 32000 KMs, needed a new adblue line.
NSTDI is offline   Reply With Quote
Old February 20th, 2017, 07:52   #58
NSTDI
I keep reading about direct injection causing valve carbon buildup on the back side of the valves and then a need for an expensive cleaning of the valves. How common is that?
Don
Old February 20th, 2017, 08:10   #59
oilhammer
oilhammer's Avatar
The F150's last generation had 3.7L V6 non-turbo, 3.5L V6 twin turbo, and a 5.0L V8. The Raptor also got a hyped up version of the 6.2L V8, but we'll leave that truck out of the discussion as it has over $3000 worth of shock absorbers, so I really do not think fuel economy was high on the list of attributes for those buyers.
Since there is such a giant span of curb weights with F150s, it is tough to lay a good rule of thumb to ALL of them with ALL the engines. A regular cab long bed 2WD truck is going to weigh less than a crew cab 4WD truck, even if that crew cab has that stunted useless 5ft bed on it. They also have different tire and wheel options, rear axle ratio options, etc. They call get the same 6sp slushbox.
The current generation went on a major weight savings plan with the aluminum body, so all versions are lighter. They also replaced the 3.7L with a non-turbo 3.5L, as well as added the 2.7L "Nano" V6. The 3.5L turbo and 5.0L V8 are carryover, with a couple of minor tweaks.
Driven with little to no load, the V6s (all of them) are going to use less fuel than the V8. The difference comes when they are loaded, then obviously the turbo engines will suffer more, because they have more available power to be made. I think the 3.5L turbo can do everything the 5.0L V8 can, but how much fuel it uses is largely dependent on how much load you are asking of it. Personally if you are driving around with a heavy load most of the time, a 1/2 ton truck is probably not the best choice anyway.
The Nano V6 seems pretty frugal, that is what my Dad bought. It is peppy to drive unloaded, and has good punch to get up to speed when you need it. It is surprisingly quick for its size. It can get into the mid 20s MPGs with light load and moderate speeds. His is a supercab, short bed, 4WD. Their previous F150, a 1994 model with the same cab configuration only 2WD and it had the optional 4sp slushbox would get about 19 asking it to do the same task. And it wasn't nearly as peppy (not even close). However, I doubt this new truck will give them the 300k miles of very low cost of service that the '94 did. Seriously, the 4.9L I6 in that truck never needed anything but oil changes and ignition parts changes, a thermostat, and I think a TPS once. That is about it. Didn't leak oil, didn't burn oil, didn't do anything bad. Big low tech lump of iron.
oilhammer
Old February 20th, 2017, 08:16   #60
NSTDI
"The Nano V6 seems pretty frugal, that is what my Dad bought. It is peppy to drive unloaded, and has good punch to get up to speed when you need it. It is surprisingly quick for its size. It can get into the mid 20s MPGs with light load and moderate speeds. His is a supercab, short bed, 4WD."
That's better fuel economy than my 3.4L V6 2002 4WD extended cab manual transmission Tacoma.
Don
Race520 7H nozzles.For sale Downsizing. ItAintRodKnock Private TDI Items for Sale/Wanted 3 June 9th, 2013 20:05
Downsizing ErlingK TDI Power Enhancements 0 March 28th, 2011 05:10
Power Service is Downsizing its Bottles PDJetta Fuels & Lubricants 60 January 15th, 2010 19:34
Downsizing nozzles Gearhead51 TDI Power Enhancements 12 December 11th, 2009 15:39
Diesel Downsizing in Villa Park, IL. All of Us Mid-west USA 1 June 27th, 2007 07:01
Page generated in 0.25422 seconds with 10 queries
[Output: 141.44 Kb. compressed to 119.58 Kb. by saving 21.86 Kb. (15.46%)]
